Lenovo N22 Chromebook Keyboard Replacement
  1. Lenovo N22 Chromebook Keyboard Replacement, Keyboard: step 1, image 1 of 3 Lenovo N22 Chromebook Keyboard Replacement, Keyboard: step 1, image 2 of 3 Lenovo N22 Chromebook Keyboard Replacement, Keyboard: step 1, image 3 of 3
    • Power down the Chromebook before starting the repair.
    • Opening the Chromebook voids the manufacturer warranty.
    • Flip the Chromebook so that the bottom is facing up.
    • Use a Phillips #1 screwdriver to remove the six 6.6 mm screws on the bottom.
    • Use a spudger to remove each of the 4 rubber feet.
    • Use a Phillips #1 screwdriver to remove the four additional screws under the rubber feet.
  2. Lenovo N22 Chromebook Keyboard Replacement: step 2, image 1 of 3 Lenovo N22 Chromebook Keyboard Replacement: step 2, image 2 of 3 Lenovo N22 Chromebook Keyboard Replacement: step 2, image 3 of 3
    • Flip the Chromebook back over and open the screen.
    • Wedge the plastic opening tool between the keyboard and the bottom of the Chromebook.
    • Run the plastic opening tool along the seam between the keyboard and the bottom of the Chromebook until the keyboard moves freely. Several tabs will pop out.
    • It is normal for the tabs to make a loud click when released. The corner tabs will be harder to release than the others and will make a louder click.
  3. Lenovo N22 Chromebook Keyboard Replacement: step 3, image 1 of 2 Lenovo N22 Chromebook Keyboard Replacement: step 3, image 2 of 2
    • Once the keyboard is released, grab the two top corners closest to the screen and slowly lift the keyboard up.
    • Do not lift the keyboard quickly or you might break the two cables that connect the keyboard to the motherboard.
    • Disconnect the cables by lifting up the retaining flaps on the black ZIF connectors.
    • Slowly pull the cables up and out of the connectors.
  4. Lenovo N22 Chromebook Keyboard Replacement: step 4, image 1 of 1
    • Lift the keyboard up and off the back panel, exposing the motherboard and battery.
Jackson Tucker
869 Reputation
3 Guides authored
Cal Poly, Team S21-G1, Livingston Spring 2017 Member of Cal Poly, Team S21-G1, Livingston Spring 2017
CPSU-LIVINGSTON-S17S21G1
4 Members
14 Guides authored
Past 24 Hours: 1
Past 7 Days: 14
Past 30 Days: 64
All Time: 13,804
