LG G5 Charging Port Replacement
  1. LG G5 Charging Port Replacement, Battery: step 1, image 1 of 3 LG G5 Charging Port Replacement, Battery: step 1, image 2 of 3 LG G5 Charging Port Replacement, Battery: step 1, image 3 of 3
    • Power down the phone by holding the power button for several seconds.
    • While holding the battery release button, pull the bottom end of the phone out of the body.
  2. LG G5 Charging Port Replacement: step 2, image 1 of 2 LG G5 Charging Port Replacement: step 2, image 2 of 2
    • Separate the battery from bottom half.
    • Insert the new battery in the same position and orientation as the old battery. Match up the arrows to be sure the orientation is correct.
  3. LG G5 Charging Port Replacement, Charging Port: step 3, image 1 of 2 LG G5 Charging Port Replacement, Charging Port: step 3, image 2 of 2
    • Remove the two 5.5mm Phillips #00 screws from the base of the phone.
  4. LG G5 Charging Port Replacement: step 4, image 1 of 2 LG G5 Charging Port Replacement: step 4, image 2 of 2
    • Insert the plastic opening tool into the bottom seam
    • Pry the plastic from the base only a slight amount.
  5. LG G5 Charging Port Replacement: step 5, image 1 of 2 LG G5 Charging Port Replacement: step 5, image 2 of 2
    • Remove the one 5.5mm Phillips #000 screw.
  6. LG G5 Charging Port Replacement: step 6, image 1 of 3 LG G5 Charging Port Replacement: step 6, image 2 of 3 LG G5 Charging Port Replacement: step 6, image 3 of 3
    • Insert the plastic opening tool into the seam between the two plastic layers.
    • Pry the plastic from the body.
  7. LG G5 Charging Port Replacement: step 7, image 1 of 2 LG G5 Charging Port Replacement: step 7, image 2 of 2
    • Insert the plastic opening tool into the seam under the metal charging port.
    • Pry the metal charging port from the body.
Joshua Zalmanowitz
1,811 Reputation
4 Guides authored
Cal Poly, Team 18-2, Forte Fall 2016 Member of Cal Poly, Team 18-2, Forte Fall 2016
CPSU-FORTE-F16S18G2
4 Members
15 Guides authored
Past 24 Hours: 3
Past 7 Days: 20
Past 30 Days: 40
All Time: 23,842
