While holding the battery release button, pull the bottom end of the phone out of the body.
Insert the plastic opening tool into the bottom seam
Pry the plastic from the base only a slight amount.
Insert the plastic opening tool into the seam between the two plastic layers.
Pry the plastic from the body.
Insert the plastic opening tool into the seam under the metal charging port.
Pry the metal charging port from the body.
