Introduction
This will show you how to tear down the Keychron K3 keyboard.
Check that your switches are hot-swappable. If they are not, trying to remove them will damage your keyboard.
The optical switches are hot-swappable, and they have a larger colored stem which is mostly square.
Use a switch puller to remove the switches. If you have the included switch puller from Keychrone, it can be tough removing these switches.
Each switch has small tabs on the corners to grab and remove them. (Included switch puller might require extra strength to remove)
Use a # 1 philips drill bit to remove the 4 screws on the keyboard
Use a spudger or another wedge tool to pry open the plastic base from the aluminum chassis.
Remove the 14 screws with a # 1 Philips screw driver bit
To remove the PCB from the aluminum frame, use a spudger to wedge it out.
