Introduction
This will show you how to tear down the Keychron K3 keyboard.
Unplug the keyboard and toggle the leftmost switch to the 'Off" Position
Check that your switches are hot-swappable. If they are not, trying to remove them will damage your keyboard.
The optical switches are hot-swappable, and they have a larger colored stem which is mostly square.
Use a switch puller to remove the switches.
Each switch has small tabs on the corners to grab and remove them. (The Included switch puller might require extra strength to remove)
Use a spudger or another wedge tool to pry open the plastic base from the aluminum chassis.
Remove the 14 screws with a # 1 Philips screw driver bit
To remove the PCB from the aluminum frame, use a spudger to wedge it out.
