Keurig B60 Puncture Needle Replacement
  1. Keurig B60 Puncture Needle Replacement, Handle: step 1, image 1 of 1
    • Lift the handle
  2. Keurig B60 Puncture Needle Replacement: step 2, image 1 of 3 Keurig B60 Puncture Needle Replacement: step 2, image 2 of 3 Keurig B60 Puncture Needle Replacement: step 2, image 3 of 3
    • Locate and remove the two 9.5 mm Torx T15 screws on both sides of the handle.
  3. Keurig B60 Puncture Needle Replacement: step 3, image 1 of 2 Keurig B60 Puncture Needle Replacement: step 3, image 2 of 2
    • Remove the broken handle and replace with the new one
  4. Keurig B60 Puncture Needle Replacement, Puncture Needle: step 4, image 1 of 1
  5. Keurig B60 Puncture Needle Replacement: step 5, image 1 of 1
    • Locate and remove the two 9.5 mm Phillips #1 screws.
    • Remove the plastic ring around the K-Cup Pack Holder
  6. Keurig B60 Puncture Needle Replacement: step 6, image 1 of 1
    • Remove the two 9.5 mm Phillips #1 screws on the underside of the lid.
  7. Keurig B60 Puncture Needle Replacement: step 7, image 1 of 2 Keurig B60 Puncture Needle Replacement: step 7, image 2 of 2
    • Detach the lid from the Keurig.
  8. Keurig B60 Puncture Needle Replacement: step 8, image 1 of 1
    • Locate and remove the two 9.5 mm Phillips #1 screws on the top of the puncture needle.
  9. Keurig B60 Puncture Needle Replacement: step 9, image 1 of 3 Keurig B60 Puncture Needle Replacement: step 9, image 2 of 3 Keurig B60 Puncture Needle Replacement: step 9, image 3 of 3
    • Squeeze and pull on the hose to remove it from the Puncture Needle
    • Puncture needle should now be exposed
  10. Keurig B60 Puncture Needle Replacement: step 10, image 1 of 3 Keurig B60 Puncture Needle Replacement: step 10, image 2 of 3 Keurig B60 Puncture Needle Replacement: step 10, image 3 of 3
    • Remove the Puncture Needle Assembly from Keurig
Jake Wynn
830 Reputation
5 Guides authored
Cal Poly, Team 1-7, Maness Spring 2016 Member of Cal Poly, Team 1-7, Maness Spring 2016
CPSU-MANESS-S16S1G7
5 Members
5 Guides authored
Past 24 Hours: 6
Past 7 Days: 44
Past 30 Days: 225
All Time: 29,866
