InFocus Screenplay 4805 Lamp Replacement
Views: 2.1K
View statistics:
Past 24 Hours:
4
Past 7 Days:
22
Past 30 Days:
93
All Time:
2,111
Comments: 3
3 guide comments.
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 20 minutes
Difficulty: Moderate
Introduction
Go to step 1 ↓
This guide shows how to replace the projector's bulb if you are experiencing no image being betrayed by the projector. You will need a replacement bulb and an iFixit tool kit.
Parts
Tools
    1. InFocus Screenplay 4805 Lamp Replacement, Remove the lamp door: step 1, image 1 of 1
      • Front panel assembly removal is not required.
      • To remove the lamp door, use a metal or plastic pry tool and unclip the lamp door from the projector. Set this aside for reassembly.
      Ask FixBot
    2. InFocus Screenplay 4805 Lamp Replacement, Disconnect the lamp: step 2, image 1 of 3 InFocus Screenplay 4805 Lamp Replacement, Disconnect the lamp: step 2, image 2 of 3 InFocus Screenplay 4805 Lamp Replacement, Disconnect the lamp: step 2, image 3 of 3
      • Beyond this step, the lamp can be replaced as an assembly and the guide is complete. If you want to rebuild the lamp with a new bulb and reuse the old housing, refer to this guide: InFocus Screenplay 4805 Lamp Rebuild
      • If you are replacing the lamp as an assembly, follow this guide in reverse from this step.
      • Remove the two gold 1 cm screws and washers on the side of lens housing using the 4.0 flat-head bit
      • Pinch the white wire tab to gently detach the side that connects with the lens housing.
      Ask FixBot
    3. InFocus Screenplay 4805 Lamp Replacement, **REBUILD ONLY** Housing disassembly: step 3, image 1 of 2 InFocus Screenplay 4805 Lamp Replacement, **REBUILD ONLY** Housing disassembly: step 3, image 2 of 2
      • This step is only required when rebuilding the old lamp with a replacement bulb.
      • Slide the bulb housing out of the projector.
      • Use the Phillips #1 screwdriver to remove the three 1 cm gold screws on the bulb housing.
      Ask FixBot
    4. InFocus Screenplay 4805 Lamp Replacement, **REBUILD ONLY** Housing disassembly: step 4, image 1 of 2 InFocus Screenplay 4805 Lamp Replacement, **REBUILD ONLY** Housing disassembly: step 4, image 2 of 2
      • Gently pull the top of the bulb housing off.
      • Lift up the middle of the bulb housing to remove it.
      • Be careful of loose parts, such as the metal housing and the glass focusing lens.
      Ask FixBot
    5. InFocus Screenplay 4805 Lamp Replacement, **REBUILD ONLY** Housing disassembly: step 5, image 1 of 3 InFocus Screenplay 4805 Lamp Replacement, **REBUILD ONLY** Housing disassembly: step 5, image 2 of 3 InFocus Screenplay 4805 Lamp Replacement, **REBUILD ONLY** Housing disassembly: step 5, image 3 of 3
      • Unhook the spring from the bulb housing.
      • Gently remove the bulb.
      Ask FixBot
To reassemble the device, follow these instructions in reverse order.
3 Guide Comments
To remove and later disassemble the lamp, you don’t need to remove whole cover. Just open the lamp bay door and follow the steps starting  from 6!
madyogi - Reply Share
madyogi, exactly. You are absolutely right!
ilya.zhizhin - Reply Share
I was able to fix an old projector I got for $40. Thank you so much for the tutorial.
Madelyn Tapia - Reply Share
Past 24 Hours: 4
Past 7 Days: 22
Past 30 Days: 93
All Time: 2,111
