InFocus Screenplay 4805 Lamp Rebuild
View statistics:
Past 24 Hours:
Past 7 Days:
11
Past 30 Days:
54
All Time:
264
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 20 minutes
Difficulty: Moderate
Introduction
Go to step 1 ↓
This guide shows how to rebuild the projector lanp in your InFocus Scereenplay 4805 projector. You will need a replacement bulb and an iFixit tool kit.
Parts
Tools
    1. InFocus Screenplay 4805 Lamp Rebuild, **REBUILD ONLY** Housing disassembly: step 1, image 1 of 2 InFocus Screenplay 4805 Lamp Rebuild, **REBUILD ONLY** Housing disassembly: step 1, image 2 of 2
      • This guide assumes tht you have removed the lamp unit from the projector. If you have not, refer to this guide first: InFocus Screenplay 4805 Lamp Replacement
      • Slide the bulb housing out of the projector.
      • Use the Phillips #1 screwdriver to remove the three 1 cm gold screws on the bulb housing.
      Ask FixBot
    2. InFocus Screenplay 4805 Lamp Rebuild, **REBUILD ONLY** Housing disassembly: step 2, image 1 of 2 InFocus Screenplay 4805 Lamp Rebuild, **REBUILD ONLY** Housing disassembly: step 2, image 2 of 2
      • This step is only required when rebuilding the old lamp with a replacement bulb.
      • Gently pull the top of the bulb housing off.
      • Lift up the middle of the bulb housing to remove it.
      • Be careful of loose parts, such as the metal housing and the glass focusing lens.
      Ask FixBot
    3. InFocus Screenplay 4805 Lamp Rebuild, **REBUILD ONLY** Housing disassembly: step 3, image 1 of 3 InFocus Screenplay 4805 Lamp Rebuild, **REBUILD ONLY** Housing disassembly: step 3, image 2 of 3 InFocus Screenplay 4805 Lamp Rebuild, **REBUILD ONLY** Housing disassembly: step 3, image 3 of 3
      • Unhook the spring from the bulb housing.
      • Gently remove the bulb.
      Ask FixBot
To reassemble the device, follow these instructions in reverse order.
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 11
Past 30 Days: 54
All Time: 264
