Prerequisite Only
This is a prerequisite-only guide! This guide is part of another procedure and isn’t meant to be used alone.
Remove the sticker that sits on top of the left screw above the battery.
Remove the three Phillips #00 screws that hold the metal plates in place.
Use a tweezer to remove the sticker that sits on top of the screw next to the antenna cable.
Unplug the antenna cable and release it from the bracket on the metal plate covering the main flex cable.
Remove the four Phillips #00 screws.
To reassemble your device, follow these instructions in reverse order. Reapply adhesive where necessary.
