Introduction
If your Huawei P9 Plus won't hold a charge you can use this guide to replace the worn-out battery.
Before disassembling your phone, discharge the battery below 25%. The battery can catch fire and/or explode if accidentally punctured, but the chances of that happening are much lower if discharged.
After separating the rear case flip the other half open to get to the flex connectors.
With a spudger unplug the flex connector of the fingerprint sensor and the one of the side buttons.
Remove the rear case.
Remove the sticker that sits on top of the left screw above the battery.
Remove the three Phillips #00 screws that hold the metal plates in place.
Both metal plates have little hooks. Use a tweezer to free them and unhinge the plates by carefully moving them upwards.
Use a spudger to unplug the screen flex cable.
Unplug the motherboard flex cable and the battery flex cable afterwards.
Loosen the end of the other adhesive strip with a tweezer and pull it out. If needed use the iOpener again to soften the glue a little.
