Introduction
Use this guide to replace the motherboard in your Huawei P10 Lite smartphone.
Insert the tip of an opening pick between the back cover and the mid frame and slide it around the phone, to cut the adhesive.
Using a suction handle to lift the back cover may help to get an initial gap for the opening pick to put in.
After you cut the adhesive on every edge, twist your opening pick, to separate the rear cover from the phone.
Flip the rear cover over to the right side of the phone.
Use a pair of tweezers to remove the sticker.
Remove the two Phillips #00 screws.
Remove the four 2.5 mm Phillips #00 screws.
Use tweezers to remove the mainboard shield.
Use the flat end of a spudger to disconnect the finger print sensor flex cable.
Remove the three Phillips #000 screws.
Use tweezers to remove the two metal shields which cover the flex cables on the mainboard.
Use the flat end of a spudger to disconnect the volume and power button, the display and the main flex cable.
Disconnect the headphone jack flex cable with the flat end of a spudger.
Use an opening pick to pry out the motherboard until you can get a good grip.
Remove the motherboard.
