Huawei P10 Lite Loudspeaker / Vibration Motor Replacement
  1. Huawei P10 Lite Loudspeaker / Vibration Motor Replacement, Back cover: step 1, image 1 of 3 Huawei P10 Lite Loudspeaker / Vibration Motor Replacement, Back cover: step 1, image 2 of 3 Huawei P10 Lite Loudspeaker / Vibration Motor Replacement, Back cover: step 1, image 3 of 3
    • Insert the tip of an opening pick between the back cover and the mid frame and slide it around the phone, to cut the adhesive.
    • Using a suction handle to lift the back cover may help to get an initial gap for the opening pick to put in.
    • If the adhesive is hard to cut, use an iOpener to loosen it.
  2. Huawei P10 Lite Loudspeaker / Vibration Motor Replacement: step 2, image 1 of 3 Huawei P10 Lite Loudspeaker / Vibration Motor Replacement: step 2, image 2 of 3 Huawei P10 Lite Loudspeaker / Vibration Motor Replacement: step 2, image 3 of 3
    • After you cut the adhesive on every edge, twist your opening pick, to separate the rear cover from the phone.
    • Flip the rear cover over to the right side of the phone.
  3. Huawei P10 Lite Loudspeaker / Vibration Motor Replacement: step 3, image 1 of 2 Huawei P10 Lite Loudspeaker / Vibration Motor Replacement: step 3, image 2 of 2
    Tool used on this step:
    Buy
    • Use a pair of tweezers to remove the sticker.
    • Remove the two Phillips #00 screws.
    • Remove the four 2.5 mm Phillips #00 screws.
  4. Huawei P10 Lite Loudspeaker / Vibration Motor Replacement: step 4, image 1 of 2 Huawei P10 Lite Loudspeaker / Vibration Motor Replacement: step 4, image 2 of 2
    • Use tweezers to remove the mainboard shield.
    • Use the flat end of a spudger to disconnect the finger print sensor flex cable.
    • When reassembling apply new adhesive where it is necessary.
  5. Huawei P10 Lite Loudspeaker / Vibration Motor Replacement, Battery Disconnection: step 5, image 1 of 3 Huawei P10 Lite Loudspeaker / Vibration Motor Replacement, Battery Disconnection: step 5, image 2 of 3 Huawei P10 Lite Loudspeaker / Vibration Motor Replacement, Battery Disconnection: step 5, image 3 of 3
    • Remove the Phillips screw holding the battery connector plate in place.
    • Remove the battery connector plate.
    • Use the flat end of a spudger to disconnect the battery flex cable.
  6. Huawei P10 Lite Loudspeaker / Vibration Motor Replacement, Loudspeaker / Vibration Motor: step 6, image 1 of 1
    • Remove the seven Philipps #000 screws.
  7. Huawei P10 Lite Loudspeaker / Vibration Motor Replacement: step 7, image 1 of 3 Huawei P10 Lite Loudspeaker / Vibration Motor Replacement: step 7, image 2 of 3 Huawei P10 Lite Loudspeaker / Vibration Motor Replacement: step 7, image 3 of 3
    • Insert an opening pick under the right edge of the loudspeaker unit and lever it up.
    • Grab the loudspeaker unit and remove it.
  8. Huawei P10 Lite Loudspeaker / Vibration Motor Replacement: step 8, image 1 of 2 Huawei P10 Lite Loudspeaker / Vibration Motor Replacement: step 8, image 2 of 2
    • Use an iOpener to loosen the glue under the vibration motor.
    • Remove the vibration motor.
Dominik Schnabelrauch
205,610 Reputation
682 Guides authored
iFixit Member of iFixit
Staff
137 Members
17,464 Guides authored
Past 24 Hours: 1
Past 7 Days: 3
Past 30 Days: 30
All Time: 4,254
