Introduction
Use this guide to replace the charging board in your Huawei P10 Lite smartphone. When reassembling your phone apply new adhesive where it is necessary.
Insert the tip of an opening pick between the back cover and the mid frame and slide it around the phone, to cut the adhesive.
Using a suction handle to lift the back cover may help to get an initial gap for the opening pick to put in.
After you cut the adhesive on every edge, twist your opening pick, to separate the rear cover from the phone.
Flip the rear cover over to the right side of the phone.
Use tweezers to remove the mainboard shield.
Use the flat end of a spudger to disconnect the finger print sensor flex cable.
Remove the Phillips screw holding the battery connector plate in place.
Remove the battery connector plate.
Use the flat end of a spudger to disconnect the battery flex cable.
Insert an opening pick under the right edge of the loudspeaker unit and lever it up.
Grab the loudspeaker unit and remove it.
Use the flat end of a spudger to disconnect the interconnect cable.
Use tweezers to disconnect the antenna cable.
