Introduction
Use this guide to replace the back cover of your Huawei P10 Lite.
Insert the tip of an opening pick between the back cover and the mid frame and slide it around the phone, to cut the adhesive.
After you cut the adhesive on every edge, twist your opening pick, to separate the rear cover from the phone.
Flip the rear cover over to the right side of the phone.
Use tweezers to remove the mainboard shield.
Use the flat end of a spudger to disconnect the finger print sensor flex cable.
