You're viewing a previously published version of this guide.  View latest version
Older Newer
Introduction
Use this guide to remove and replace the display in your Huawei P10 smartphone.
To protect your eyes from glass shreds and get a better grip to open the phone you might want to apply some tape onto the screen.
When reassembling apply new adhesive where it is necessary.
  1. Switch off your phone. Remove the two Pentalobe P2 screws at the bottom. Remove the SIM card tray.
    • Switch off your phone.
    • Remove the two Pentalobe P2 screws at the bottom.
    • Remove the SIM card tray.
  2. Insert a plastic opening tool between the display and the case starting at the bottom area of your phone. Carefully pry the display with its parts out of the case. After you pried out the bottom end, use the opening tool to open the clamps on both sides.
    • Insert a plastic opening tool between the display and the case starting at the bottom area of your phone.
    • Carefully pry the display with its parts out of the case.
    • After you pried out the bottom end, use the opening tool to open the clamps on both sides.
  3. Don't open the phone all the way, yet. The cable for the standby and volume buttons is still connected to the back cover. Swing open the phone backwards.
    • Don't open the phone all the way, yet. The cable for the standby and volume buttons is still connected to the back cover.
    • Swing open the phone backwards.
    • Use a spudger to disconnect the power- and volume button flex cable.
  4. Remove the two Phillips #00 screws. Use tweezers to remove both metal plates. Use tweezers to remove both metal plates.
    • Remove the two Phillips #00 screws.
    • Use tweezers to remove both metal plates.
  5. Use a spudger to disconnect the interconnect, the battery and the display flex cable. Use a spudger to disconnect the interconnect, the battery and the display flex cable. Use a spudger to disconnect the interconnect, the battery and the display flex cable.
    • Use a spudger to disconnect the interconnect, the battery and the display flex cable.
  6. Remove the four Phillips #00 screws. Use Tweezers to remove the metal plate.
    • Remove the four Phillips #00 screws.
    • Use Tweezers to remove the metal plate.
  7. Use a spudger to disconnect the main flex cable. Use tweezers to disconnect the antenna cable and pull it out of the clamp holding it down to the charging board.
    • Use a spudger to disconnect the main flex cable.
    • Use tweezers to disconnect the antenna cable and pull it out of the clamp holding it down to the charging board.
  8. Use a spudger to disconnect the headphone jack and the loudspeaker flex cables. Use a spudger to disconnect the headphone jack and the loudspeaker flex cables.
    • Use a spudger to disconnect the headphone jack and the loudspeaker flex cables.
  9. Do not damage any components sitting on the charging board while removing it. Use a spudger to pry out the charging board.
    • Do not damage any components sitting on the charging board while removing it.
    • Use a spudger to pry out the charging board.
    • Remove the charging board.
  10. Only insert the spudger as deep as 1/16 of an inch to avoid damage. Use a spudger to carefully pry out the loudspeaker. There is some adhesive underneath so it might be a little bit sticky. You can  use an iOpener to loosen it.
    • Only insert the spudger as deep as 1/16 of an inch to avoid damage.
    • Use a spudger to carefully pry out the loudspeaker. There is some adhesive underneath so it might be a little bit sticky. You can use an iOpener to loosen it.
    • Remove the loudspeaker.
    • When reassembling your phone, apply new adhesive where it's necessary.
  11. Remove the antenna cable if you haven't already. Use tweezers to remove the interconnect cable.
    • Remove the antenna cable if you haven't already.
    • Use tweezers to remove the interconnect cable.
    • Use an iOpener to loosen the adhesive beneath the display. Especially take care of the upper and lower part of the display.
  12. Insert the tip of an opening pick between the display and the midframe on the bottom of the phone, near the home button. Slide the opening pick along the bottom edge, to cut the adhesive. Slide the opening pick to the bottom right corner and leave it there.
    • Insert the tip of an opening pick between the display and the midframe on the bottom of the phone, near the home button.
    • Slide the opening pick along the bottom edge, to cut the adhesive.
    • Slide the opening pick to the bottom right corner and leave it there.
    • Insert another opening pick under the screen on the bottom left corner.
  13. Slide the opening pick under the screen around all edges of the phone. If the adhesive gets tough to pry it is likely too cold. Use your iOpener or heat gun to reheat it. If the adhesive gets tough to pry it is likely too cold. Use your iOpener or heat gun to reheat it.
    • Slide the opening pick under the screen around all edges of the phone.
    • If the adhesive gets tough to pry it is likely too cold. Use your iOpener or heat gun to reheat it.
  14. Carefully pull the display assembly away from the frame. Remove the display assembly.
    • Carefully pull the display assembly away from the frame.
    • Remove the display assembly.
Dominik Schnabelrauch
41,902 Reputation
207 Guides authored
iFixit Member of iFixit
Community
101 Members
9,068 Guides authored
Past 24 Hours: 16
Past 7 Days: 143
Past 30 Days: 687
All Time: 14,292
