Introduction
Use this guide to replace the screen and digitizer in your Huawei Mate 10 Pro.
Opening the Mate 10 Pro will damage the waterproof sealing on the device. If you do not replace the adhesive seals, your phone will function normally, but will loose its water-protection.
Before disassembling your phone, discharge the battery below 25%. The battery can catch fire and/or explode if accidentally punctured, but the chances of that happening are much lower if discharged.
Switch off your phone.
Prepare an iOpener and apply it to the back of the phone for about two minutes to loosen the adhesive beneath the back cover.
Lift up the back cover with a suction cup until you can insert the flat end of a halberd spudger.
Use the halberd spudger to cut the adhesive beneath the back cover on all sides of the phone.
Faire attention à ne pas enfoncer trop le cutter/spatule hallebarde. Surtout à l’approche des boutons ON/OFF et volume, la nappe ne passe pas loin et se branche à coté de l’empreinte digitale.
Bilan, j’ai coupé cette nappe et n’ai plus de bouton volume et on/off.
Plus qu’à chercher la piece de rechange pendant que le telephone est ouvert ;)
I found it easiest to insert the first pick on the side of the phone, not the top as shown in the pictures. The side is slightly more flexible than the ends because it is longer.
Flip the back cover over to the side.
Remove the Phillips #00 screw which holds down the metal shield, sitting on top of the connection of the fingerprint sensor cable.
When re-assembling, you can test the phone before putting the covers back on. If you test it before you connect the fingerprint reader then you need to re-start the phone before the fingerprint reader will work.
Remove the twelve Phillips #00 screws.
Carefully remove the shields on top of the motherboard and the charging board.
When re-assembling, you can test the phone before putting the covers back on. However, if you test it before you fit the top inner cover (the one in the middle picture above) the speaker will not work.
The top and bottom inner covers both have tiny flanges which you need to insert into slots in the outside edge of the phone before you drop the rest of the cover into place. If you don't put the flanges in first the covers will not fit properly.
Use a spudger to disconnect the charging port flex cable from the motherboard and from the daughterboard.
Use a pair of tweezers to carefully remove the charging port including its flex cable.
Do I need to apply a new sealer / adhesive tape in order to assemble the phone back together? If yes, where can this be purchased for Huawei Mate 10 Pro?
If the adhesive on the back cover is damaged too much and/or doesn’t stick any more it is recommended to remove the old adhesive from the back cover and clean off any residue with isopropyl alcohol (>90%). Then use thin double sided adhesive tape and apply new strips of adhesive.
Hi David,
opening the Mate 10 Pro will damage the waterproof sealing on the device. If you do not replace the adhesive seals, your phone will function normally, but will loose its water-protection.
Hi there, I completed the battery replacement nicely with all your steps, the phone could turn on and function normally, the only issue after the battery replacement is the phone has no sound and vibration. I have ensure all connectors are back to place securely. Does anyone have any clue of the cause of no sound and no vibration?
Use a spudger to disconnect the battery flex cable.
Apply an iOpener on the screen for at least one minute to loosen the adhesive beneath the battery.
Hier auf KEINEN Fall ein Werkzeug aus Metall (wie den iSesame) verwenden!
Die Funken die dabei sprühen sollten sehr klar machen, daß das keine Gute Idee für den Akku ist. XD
Use a spudger to carefully pry up the battery and slide along the side to separate the adhesive.
Remove the battery.
I left the phone on top of a hot-water bottle all the way through the dismantling, right from the start. That way, the phone was nice and warm and the battery came out fairly easily. There is a slightly wider gap in the housing, just where the spudger is being inserted in the first picture above, which makes the job easy.
Use a spudger to disconnect the display flex cable.
Prepare an iOpener and apply it to the display for at least two minutes to loosen the adhesive underneath. Especially take care of the upper and lower part.
If your display is broken or cracked protect your eyes from glass shreds apply some clear tape onto the screen to also get a better grip to open the phone.
Push a spudger against the back of the display through the cutout in the midframe, where the charging port was located, to create a gap between the display and the frame.
Insert the tip of an opening pick into the gap you just created.
Der Kleber löst sich erst bei 90°C!!
(Quelle: Herstellerangaben zu ähnlichen Klebern, z.B. den bekannten T-8000 und T-7000.)
Daher ist es so problematisch mit gewöhnlichen Warmkompressen bzw dem iOpener! Da diese nur bis 100° warm werden können, und schnell auf unter 90°C abkühlen! Deswegen ist es so schwer! Und deswegen geht der Bildschirm so leicht kaputt!
Wenn ihr also die Möglichkeit habt, versucht, das Ding auf ausreichend weit über 90° zu erhitzen, aber das so kurz und so niedrig wie möglich zu halten, da der Rest des Geräts bei den Temperaturen sonst auch leicht Schaden nehmen kann!
Also z.B auf 99°C erhitzen (mit einem Bratenthermometer zwischen Wärmequelle und Bildschirm leicht festzustellen), die Wärmequelle überall außer an einer Stelle weiter auf dem Bildschirm belassen(!), und dann eilig aber vorsichtig, den Kleber an der freien Stelle (Ladebuchse) lösen, und sich so voranarbeiten.
If possible, turn on your phone and test your repair before installing new adhesive and resealing the phone.
If the frame is bent, or if any glue or glass remnants are left behind, the new display will not mount correctly and may be damaged. If necessary, replace the frame.
The best way to secure the new screen is with a sheet of custom-cut double-sided tape. Apply the tape to the back of the screen, then carefully feed the display cable through the frame. Align the screen and press it into place.
18 other people completed this guide.
2 Comments
Nicely written guide, I am curious about trying this myself in the near future. I have sadly got a tiny scratch in my screen in the last couple days where I haven’t had a screen protector on! Very frustrating.
I’ve replaced almost everything for an iPhone 6+ and done a complete teardown. How difficult is this repair compared to something like that?
Perfect tutorial, my only problem was doing it without an opener was difficult. I don’t know if this kind of comment is allowed, and it it isn’t, please just edit this part instead of taking down the whole comment. An icepack in the microwave worked VERY well for me in the end.
That said, breaking the screen to take it off was VERY hurtful in my soul.
Thanks for the instructions!!!
Erm… Simply impossible to open the phone this way…
I used the iOpener for 2 mins as instructed, I’ve used even an hair drier for 30 secs on max power (could barely touch the phone after) and still with the suction tool I was not able to open the phone.
It simply doesn’t budge!!!
Miguel Oliveira - Reply
This was much easier than I expected! ;-)
I put the phone on a hot-water bottle for about 5 minutes. I put the first pick in the side of the phone, not the top as shown in the next section. Then I kept the phone on the hot water bottle through all the following steps so that the battery glue was nice and warm when it came to that section.
Oliver Moffatt - Reply
