Introduction
You can remove glued-down components in all kinds of ways. One of the simplest is to use a solvent, such as iFixit Adhesive Remover, to dissolve the glue. Follow this guide for general tips and instructions for using adhesive remover on any device.
Cover or remove any components that may be vulnerable to damage, in case the solvent drips or leaks somewhere it shouldn't. (A sheet of aluminum foil offers good protection.)
If necessary, direct the flow of solvent away from sensitive components by elevating one side of your device.
Now that your device is prepped, it's time to prep yourself.
Wear eye protection when handling and applying the adhesive remover. (Eye protection is included in your kit.)
Do not wear contact lenses without eye protection.
Protective gloves are also included in your kit. If you are concerned about possible skin irritation, put your gloves on now.
Tool used on this step:Plastic Cards$2.99
Gently slide a plastic card or other thin pry tool under the adhered component.
If you're struggling, apply a few more drops of adhesive remover and wait about a minute before trying again.
If your device has an especially tight fit and you have trouble inserting a tool, try working a piece of floss or wire underneath the component, and pull it side-to-side in a sawing motion to separate the adhesive.
Lift and separate your newly-unglued component.
Tool used on this step:Tweezers$4.99
Before installing or gluing down any new components, remove any remaining adhesive residue from your device.
Peel off larger pieces of adhesive using tweezers or gloved fingers.
Scrape away any remaining adhesive with a plastic tool, and clean the underlying areas with adhesive remover or isopropyl alcohol. Wipe in one direction, not back and forth, until all the adhesive residue is gone.
When your device is clean and dry, go ahead and install your new part and reassemble your device.
Nice work! If you have any leftover adhesive remover, you can save it for your next project.
63 other people completed this guide.
13 Guide Comments
Can I use adhesive remover on glued down flex cables? Like the cable for the Touch ID button on the iPhone 7 Plus. Or will this damage the cable? How about isopropyl alcohol based adhesive remover?
Mild heat and/or a little isopropyl alcohol should do the trick. You don’t need to risk using anything more aggressive than that.
Can I used this to pop open my iPhone 8 Plus?
can i use this to remove thermal adhesive from a s70 adata ssd, the dram modules are glue directly to the heatsink
This will not be an ideal or guaranteed solution, but it may be feasible depending on the type and condition of the adhesive used. For this application, I would strongly recommend using isopropyl alcohol, preferably at a concentration of 99.9%. It is significantly safer for electronic components and PCB materials, and in many cases sufficient to soften or remove residual thermal adhesive without risking damage to surrounding components.
