How to Upgrade the Expandable Storage in Your PlayStation 5 Pro
  1. How to Upgrade the Expandable Storage in Your PlayStation 5 Pro, Before you begin: step 1, image 1 of 3 How to Upgrade the Expandable Storage in Your PlayStation 5 Pro, Before you begin: step 1, image 2 of 3 How to Upgrade the Expandable Storage in Your PlayStation 5 Pro, Before you begin: step 1, image 3 of 3
    • Before starting your repair:
    • Shut down your PlayStation and unplug all cables and accessories.
    • Remove any stands supporting your console and lay it down so the right side is facing up.
  2. How to Upgrade the Expandable Storage in Your PlayStation 5 Pro, Remove the fan and SSD cover: step 2, image 1 of 3 How to Upgrade the Expandable Storage in Your PlayStation 5 Pro, Remove the fan and SSD cover: step 2, image 2 of 3 How to Upgrade the Expandable Storage in Your PlayStation 5 Pro, Remove the fan and SSD cover: step 2, image 3 of 3
    • The cover is secured with hooks along the back edge and clips along the front edge.
    • Firmly pull up the front edge of the smaller, upper cover to release the clips.
    • You'll hear distinct "pops" as the clips disengage.
    • Remove the cover.
    • To reinstall the cover, place the hooks into their cutouts along the rear edge and firmly press the front edge of the cover into place to re‑engage the two clips.
  3. How to Upgrade the Expandable Storage in Your PlayStation 5 Pro, Remove the expansion slot cover screw: step 3, image 1 of 2 How to Upgrade the Expandable Storage in Your PlayStation 5 Pro, Remove the expansion slot cover screw: step 3, image 2 of 2
    • Use a Phillips screwdriver to remove the 17.4 mm‑long screw securing the expansion slot cover.
  4. How to Upgrade the Expandable Storage in Your PlayStation 5 Pro, Remove the expansion slot cover: step 4, image 1 of 3 How to Upgrade the Expandable Storage in Your PlayStation 5 Pro, Remove the expansion slot cover: step 4, image 2 of 3 How to Upgrade the Expandable Storage in Your PlayStation 5 Pro, Remove the expansion slot cover: step 4, image 3 of 3
    • Use your fingers to lift the expansion slot cover near the notch by the screw hole and remove it.
  5. How to Upgrade the Expandable Storage in Your PlayStation 5 Pro, Remove the SSD screw: step 5, image 1 of 2 How to Upgrade the Expandable Storage in Your PlayStation 5 Pro, Remove the SSD screw: step 5, image 2 of 2
    • Use a Phillips screwdriver to remove the 10.9 mm‑long SSD screw securing the spacer.
  6. How to Upgrade the Expandable Storage in Your PlayStation 5 Pro, Move the spacer: step 6, image 1 of 3 How to Upgrade the Expandable Storage in Your PlayStation 5 Pro, Move the spacer: step 6, image 2 of 3 How to Upgrade the Expandable Storage in Your PlayStation 5 Pro, Move the spacer: step 6, image 3 of 3
    Tool used on this step:
    Buy
    • Multiple indents along the expansion slot allow for compatibility with any sized SSD. Each indent is labeled with its corresponding size.
    • Use tweezers or your fingers to move the spacer to its proper indent based on the size of your SSD.
    • Don't install the SSD without the spacer.
  7. How to Upgrade the Expandable Storage in Your PlayStation 5 Pro, Install the SSD: step 7, image 1 of 2 How to Upgrade the Expandable Storage in Your PlayStation 5 Pro, Install the SSD: step 7, image 2 of 2
    • Make sure your SSD is compatible with your PlayStation and has a heat-dissipation mechanism such as a heatsink or thermal pad.
    • Insert the SSD into its M.2 socket at a slight downward angle.
    • Both the SSD and M.2 socket are keyed, which means the SSD only fits into the socket one way.
    • It's normal for the SSD to sit up at an angle before it's secured in place.
    • With one hand, push the SSD down so its cutout is aligned on top of the spacer.
    • With your free hand, use your Phillips screwdriver to tighten the SSD screw.
    • Don't overtighten this screw, or you may damage the SSD.
To reassemble your device, follow these instructions in reverse order starting with the expansion slot cover.
If it's your first time using the SSD with your PlayStation, you'll need to format it after installation.
If you're moving games to your new SSD, follow Sony's guide.
3 other people completed this guide.
Spencer Day
149,751 Reputation
995 Guides authored
iFixit Member of iFixit
Staff
123 Members
23,629 Guides authored
0 Guide Comments
Past 24 Hours: 10
Past 7 Days: 168
Past 30 Days: 553
All Time: 1,799
