How to Remove the SSD in Your Xbox Series X (Digital Edition)
    1. How to Remove the SSD in Your Xbox Series X (Digital Edition), Uncover the back panel screws: step 1, image 1 of 2 How to Remove the SSD in Your Xbox Series X (Digital Edition), Uncover the back panel screws: step 1, image 2 of 2
      • Before you begin, completely power down and unplug all cables from your console.
      • Two stickers cover the back panel screws. You can remove the stickers without heating them, though it makes them much easier to remove cleanly.
      • Heat an iOpener and lay it on the smaller sticker near the bottom of the back panel for two minutes.
      • Alternatively, you can use a hair dryer to heat the sticker.
      Ask FixBot
    2. How to Remove the SSD in Your Xbox Series X (Digital Edition): step 2, image 1 of 3 How to Remove the SSD in Your Xbox Series X (Digital Edition): step 2, image 2 of 3 How to Remove the SSD in Your Xbox Series X (Digital Edition): step 2, image 3 of 3
      • Use a pair of angled tweezers to remove the sticker hiding the first screw on the back panel, near the base.
      Ask FixBot
    3. How to Remove the SSD in Your Xbox Series X (Digital Edition): step 3, image 1 of 3 How to Remove the SSD in Your Xbox Series X (Digital Edition): step 3, image 2 of 3 How to Remove the SSD in Your Xbox Series X (Digital Edition): step 3, image 3 of 3
      • Use an iOpener or hair dryer to heat the larger sticker near the center of the back panel.
      Ask FixBot
    4. How to Remove the SSD in Your Xbox Series X (Digital Edition): step 4, image 1 of 3 How to Remove the SSD in Your Xbox Series X (Digital Edition): step 4, image 2 of 3 How to Remove the SSD in Your Xbox Series X (Digital Edition): step 4, image 3 of 3
      • Use the flat end of a spudger to scrape up a corner of the larger sticker until you can grip it with a pair of blunt tweezers.
      • Use blunt tweezers to peel back the sticker to reveal the second screw.
      • You only need to peel this sticker to where you can access the hidden screw. You don't need to pull it completely off.
      • Technically, these are tamper-evident stickers, but don't worry—Microsoft can't legally void your warranty, as long as you don't damage anything. Have fun!
      Ask FixBot
    5. How to Remove the SSD in Your Xbox Series X (Digital Edition), Remove the back panel screws: step 5, image 1 of 2 How to Remove the SSD in Your Xbox Series X (Digital Edition), Remove the back panel screws: step 5, image 2 of 2
      Tool used on this step:
      Magnetic Project Mat
      $19.95
      Buy
      • Throughout this repair, keep track of each screw and make sure it goes back exactly where it came from to avoid damaging your console.
      • Use a T8 Torx driver to remove the two 7.4 mm‑long screws securing the back panel.
      Ask FixBot
    6. How to Remove the SSD in Your Xbox Series X (Digital Edition), Unclip the back panel: step 6, image 1 of 3 How to Remove the SSD in Your Xbox Series X (Digital Edition), Unclip the back panel: step 6, image 2 of 3 How to Remove the SSD in Your Xbox Series X (Digital Edition), Unclip the back panel: step 6, image 3 of 3
      • Insert the flat end of a spudger into the gap between the back panel and the shell, near the left side of the base.
      • Pry up the back panel to release it from the locking clips.
      Ask FixBot
    7. How to Remove the SSD in Your Xbox Series X (Digital Edition): step 7, image 1 of 3 How to Remove the SSD in Your Xbox Series X (Digital Edition): step 7, image 2 of 3 How to Remove the SSD in Your Xbox Series X (Digital Edition): step 7, image 3 of 3
      • Insert the flat end of a spudger into the gap between the back panel and the shell, near the right side of the base.
      Ask FixBot
    8. How to Remove the SSD in Your Xbox Series X (Digital Edition), Remove the back panel: step 8, image 1 of 3 How to Remove the SSD in Your Xbox Series X (Digital Edition), Remove the back panel: step 8, image 2 of 3 How to Remove the SSD in Your Xbox Series X (Digital Edition), Remove the back panel: step 8, image 3 of 3
      • Grip the back panel at the opening you just created and pull it up and away from the shell to unclip the long edges.
      • During reassembly, press along the edges of the back panel to snap it into place.
      Ask FixBot
    9. How to Remove the SSD in Your Xbox Series X (Digital Edition): step 9, image 1 of 3 How to Remove the SSD in Your Xbox Series X (Digital Edition): step 9, image 2 of 3 How to Remove the SSD in Your Xbox Series X (Digital Edition): step 9, image 3 of 3
      • The back panel slots into a gap at the top of the shell.
      • Tilt the back panel up and pull it away from the top edge of the shell to release it from the gap.
      • Remove the back panel.
      Ask FixBot
    1. How to Remove the SSD in Your Xbox Series X (Digital Edition), Remove the fan screws: step 10, image 1 of 2 How to Remove the SSD in Your Xbox Series X (Digital Edition), Remove the fan screws: step 10, image 2 of 2
      • Use a T8 Torx driver to remove the three screws securing the fan to the center chassis:
      • One 10.3 mm‑long pancake screw
      • Two 9 mm‑long screws
      Ask FixBot
    2. How to Remove the SSD in Your Xbox Series X (Digital Edition), Disconnect the fan cable: step 11, image 1 of 3 How to Remove the SSD in Your Xbox Series X (Digital Edition), Disconnect the fan cable: step 11, image 2 of 3 How to Remove the SSD in Your Xbox Series X (Digital Edition), Disconnect the fan cable: step 11, image 3 of 3
      • Use your fingernails or a pair of angled tweezers to firmly grip the edges of the fan cable connector.
      • Grip your tweezers close the connector to get a better grip.
      • Pull the connector straight out of the socket to disconnect it.
      • If you're having trouble, gently rock the connector side to side to loosen it.
      • Always pull cables by their connectors and not the wires themselves.
      • During reassembly, route the fan cable underneath its small cable guide on the fan housing so it doesn't interfere with the back panel.
      Ask FixBot
    3. How to Remove the SSD in Your Xbox Series X (Digital Edition), Remove the fan: step 12, image 1 of 3 How to Remove the SSD in Your Xbox Series X (Digital Edition), Remove the fan: step 12, image 2 of 3 How to Remove the SSD in Your Xbox Series X (Digital Edition), Remove the fan: step 12, image 3 of 3
      Dust Blower
      $19.99
      Buy
      • Slide the fan out of its slot to remove it.
      • During reassembly:
      • Before installing the fan, make sure it's clean! Use a dust blower or compressed air to blow off any dust or debris, and wipe the fan clean with a clean cloth.
      • Use a finger to keep the fan blades steady—it makes them easier to clean.
      • Note that the fan can only be installed one way—make sure Master Chief is facing you.
      Ask FixBot
    1. How to Remove the SSD in Your Xbox Series X (Digital Edition), Unlatch the base: step 13, image 1 of 3 How to Remove the SSD in Your Xbox Series X (Digital Edition), Unlatch the base: step 13, image 2 of 3 How to Remove the SSD in Your Xbox Series X (Digital Edition), Unlatch the base: step 13, image 3 of 3
      • Use the flat end of a spudger to pry up the locking tab holding the base to the shell.
      • Keep the locking tab held open for the next step.
      Ask FixBot
    2. How to Remove the SSD in Your Xbox Series X (Digital Edition), Twist and remove the base: step 14, image 1 of 3 How to Remove the SSD in Your Xbox Series X (Digital Edition), Twist and remove the base: step 14, image 2 of 3 How to Remove the SSD in Your Xbox Series X (Digital Edition), Twist and remove the base: step 14, image 3 of 3
      • With the locking tab held open, grip the base and rotate it counterclockwise to unlock it from the shell.
      • Remove the base.
      • During reassembly, put the base tabs into their holes on the shell and twist clockwise until the base snaps into the interior locking tab.
      • When locked in place, the Hello from Seattle line will be parallel with the device's sides.
      Ask FixBot
    1. How to Remove the SSD in Your Xbox Series X (Digital Edition), Disconnect the USB port cable: step 15, image 1 of 3 How to Remove the SSD in Your Xbox Series X (Digital Edition), Disconnect the USB port cable: step 15, image 2 of 3 How to Remove the SSD in Your Xbox Series X (Digital Edition), Disconnect the USB port cable: step 15, image 3 of 3
      • The ribbon cables and their connectors are extremely fragile, so always open locking tabs gently and pull cables slowly.
      • Use a spudger to flip open the metal locking tab on the USB port ribbon cable.
      • During reassembly, gently snap the metal locking tab back into place once the cable has been inserted.
      Ask FixBot
    2. How to Remove the SSD in Your Xbox Series X (Digital Edition), Heat the USB port cable: step 16, image 1 of 3 How to Remove the SSD in Your Xbox Series X (Digital Edition), Heat the USB port cable: step 16, image 2 of 3 How to Remove the SSD in Your Xbox Series X (Digital Edition), Heat the USB port cable: step 16, image 3 of 3
      • The USB port cable is secured to the chassis with two pieces of mild adhesive.
      • Use an iOpener or a hair dryer to heat the USB port cable.
      Ask FixBot
    3. How to Remove the SSD in Your Xbox Series X (Digital Edition), Detach the USB port cable: step 17, image 1 of 3 How to Remove the SSD in Your Xbox Series X (Digital Edition), Detach the USB port cable: step 17, image 2 of 3 How to Remove the SSD in Your Xbox Series X (Digital Edition), Detach the USB port cable: step 17, image 3 of 3
      Tesa 61395 Tape
      $2.95
      Buy
      • Slide an opening pick under the USB port cable to separate the adhesive securing it.
      • During reassembly, use thin double‑sided adhesive to secure the cable. If there's adhesive left and it's still sticky, you can reuse it. If you have a new cable, check it for pre‑installed adhesive and remove any liners.
      Ask FixBot
    4. How to Remove the SSD in Your Xbox Series X (Digital Edition): step 18, image 1 of 3 How to Remove the SSD in Your Xbox Series X (Digital Edition): step 18, image 2 of 3 How to Remove the SSD in Your Xbox Series X (Digital Edition): step 18, image 3 of 3
      • Use a pair of tweezers to gently pull up on the black plastic pull tab to disconnect the USB port cable.
      • Pull only on the pull tab, not the cable itself.
      • Move the USB port cable out of the way of the chassis.
      Ask FixBot
    5. How to Remove the SSD in Your Xbox Series X (Digital Edition), Disconnect the power button cable: step 19, image 1 of 3 How to Remove the SSD in Your Xbox Series X (Digital Edition), Disconnect the power button cable: step 19, image 2 of 3 How to Remove the SSD in Your Xbox Series X (Digital Edition), Disconnect the power button cable: step 19, image 3 of 3
      • Use the pointed end of a spudger to depress the metal tab on the side of the power button cable's board connector.
      • With the metal tab depressed, use a pair of tweezers to pull up on the pull tab to disconnect the power button cable from the center chassis.
      • Don't pull on the cable without depressing the metal tab, otherwise you risk damaging either the cable or the connector.
      • During reassembly, the cable should lightly "snap" into place when inserted.
      Ask FixBot
    6. How to Remove the SSD in Your Xbox Series X (Digital Edition), Remove the chassis screws: step 20, image 1 of 2 How to Remove the SSD in Your Xbox Series X (Digital Edition), Remove the chassis screws: step 20, image 2 of 2
      • Use a T8 Torx driver to remove the three 7.4 mm‑long green screws securing the center chassis assembly to the shell.
      Ask FixBot
    7. How to Remove the SSD in Your Xbox Series X (Digital Edition), Remove the chassis: step 21, image 1 of 3 How to Remove the SSD in Your Xbox Series X (Digital Edition), Remove the chassis: step 21, image 2 of 3 How to Remove the SSD in Your Xbox Series X (Digital Edition), Remove the chassis: step 21, image 3 of 3
      • The center chassis assembly is aligned to the bottom of the shell with guide pegs. These pegs will need to slide out of their slots to allow the chassis to be lifted out.
      • Grip the chassis and pull it towards the top of the shell, uncoupling the guide pegs from the shell.
      • Use two hands to lift out the chassis to remove it from the shell.
      • Make sure neither of the ribbon cables get pinched as you lower the center chassis into the shell.
      • Use the alignment pegs and cutouts to properly orient the chassis in the shell:
      • Two pegs on the chassis with cutouts on the bottom of the shell.
      • Three pegs in the shell with cutouts on the chassis.
      Ask FixBot
    8. How to Remove the SSD in Your Xbox Series X (Digital Edition): step 22, image 1 of 2 How to Remove the SSD in Your Xbox Series X (Digital Edition): step 22, image 2 of 2
      Dust Blower
      $5.99
      Buy
      • Gently place the chassis heatsink-side down on a clean work surface.
      • During reassembly, this is a good point to clean the heatsink fins of any dust, dirt, or debris that may have built up over time. Use a dust blower or compressed air to clear out the fins.
      Ask FixBot
    1. How to Remove the SSD in Your Xbox Series X (Digital Edition), Remove the antenna board screws: step 23, image 1 of 2 How to Remove the SSD in Your Xbox Series X (Digital Edition), Remove the antenna board screws: step 23, image 2 of 2
      • Use a T8 Torx driver to remove the three 9.6 mm‑long screws securing the antenna board to the center chassis.
      Ask FixBot
    2. How to Remove the SSD in Your Xbox Series X (Digital Edition), Remove the accessory antenna board: step 24, image 1 of 3 How to Remove the SSD in Your Xbox Series X (Digital Edition), Remove the accessory antenna board: step 24, image 2 of 3 How to Remove the SSD in Your Xbox Series X (Digital Edition), Remove the accessory antenna board: step 24, image 3 of 3
      • Grip the top right corner of the antenna board and pull it directly away from the center chassis to disconnect it.
      • During reassembly, align the board's connector with the port on the center chassis and press to reconnect.
      Ask FixBot
    1. How to Remove the SSD in Your Xbox Series X (Digital Edition), Remove the power cable port: step 25, image 1 of 2 How to Remove the SSD in Your Xbox Series X (Digital Edition), Remove the power cable port: step 25, image 2 of 2
      • Use a T8 Torx driver to remove the three screws securing the power cable port to the chassis:
      • Two 13.1 mm‑long screws
      • One 35 mm‑long screw
      Ask FixBot
    2. How to Remove the SSD in Your Xbox Series X (Digital Edition): step 26, image 1 of 2 How to Remove the SSD in Your Xbox Series X (Digital Edition): step 26, image 2 of 2
      • Lift the power connector out of its recess in the chassis.
      Ask FixBot
    3. How to Remove the SSD in Your Xbox Series X (Digital Edition), De-route the power cables: step 27, image 1 of 2 How to Remove the SSD in Your Xbox Series X (Digital Edition), De-route the power cables: step 27, image 2 of 2
      • Unlatch and open the lid on the power cable's plastic guide.
      Ask FixBot
    4. How to Remove the SSD in Your Xbox Series X (Digital Edition): step 28, image 1 of 2 How to Remove the SSD in Your Xbox Series X (Digital Edition): step 28, image 2 of 2
      • Lift the power cable out from underneath the extra section of the cable guide.
      Ask FixBot
    5. How to Remove the SSD in Your Xbox Series X (Digital Edition), Remove the board shield: step 29, image 1 of 2 How to Remove the SSD in Your Xbox Series X (Digital Edition), Remove the board shield: step 29, image 2 of 2
      • Use a T8 Torx driver to remove the ten screws securing the board shield:
      • Seven 8.7 mm‑long screws
      • Two 35 mm‑long screws
      • These screws are very tight and may take significant force to loosen.
      • One 13 mm‑long screw
      Ask FixBot
    6. How to Remove the SSD in Your Xbox Series X (Digital Edition): step 30, image 1 of 3 How to Remove the SSD in Your Xbox Series X (Digital Edition): step 30, image 2 of 3 How to Remove the SSD in Your Xbox Series X (Digital Edition): step 30, image 3 of 3
      • Hold the power supply cable out of the way and lift the board shield straight up to remove it.
      Ask FixBot
    1. How to Remove the SSD in Your Xbox Series X (Digital Edition), Disconnect the power supply cables: step 31, image 1 of 3 How to Remove the SSD in Your Xbox Series X (Digital Edition), Disconnect the power supply cables: step 31, image 2 of 3 How to Remove the SSD in Your Xbox Series X (Digital Edition), Disconnect the power supply cables: step 31, image 3 of 3
      • Open the lid on the power supply's plastic cable guide.
      Ask FixBot
    2. How to Remove the SSD in Your Xbox Series X (Digital Edition): step 32, image 1 of 3 How to Remove the SSD in Your Xbox Series X (Digital Edition): step 32, image 2 of 3 How to Remove the SSD in Your Xbox Series X (Digital Edition): step 32, image 3 of 3
      • Use your fingers to pinch the power supply's 10‑pin power connector, so the locking tab opens outward.
      • With the locking tab open, lift the connector straight up and out of its socket.
      Ask FixBot
    3. How to Remove the SSD in Your Xbox Series X (Digital Edition), Disconnect the interconnect cable: step 33, image 1 of 3 How to Remove the SSD in Your Xbox Series X (Digital Edition), Disconnect the interconnect cable: step 33, image 2 of 3 How to Remove the SSD in Your Xbox Series X (Digital Edition), Disconnect the interconnect cable: step 33, image 3 of 3
      • Use your fingers to pinch the locking tab in the center of the interconnect cable connector.
      • While pinching the tab, insert the flat end of a spudger between the top of the socket and the connector's tab.
      • Twist the spudger to lift the connector out of its socket until the clip in the center disengages.
      Ask FixBot
    4. How to Remove the SSD in Your Xbox Series X (Digital Edition): step 34, image 1 of 2 How to Remove the SSD in Your Xbox Series X (Digital Edition): step 34, image 2 of 2
      • Use your fingers to pull the connector straight up and out of its socket.
      • During reassembly, insert the interconnect cable connector into its socket and press down on both edges until the connector snaps into place.
      Ask FixBot
    5. How to Remove the SSD in Your Xbox Series X (Digital Edition), Unlatch the chassis strap: step 35, image 1 of 3 How to Remove the SSD in Your Xbox Series X (Digital Edition), Unlatch the chassis strap: step 35, image 2 of 3 How to Remove the SSD in Your Xbox Series X (Digital Edition), Unlatch the chassis strap: step 35, image 3 of 3
      • Pull the rubber strap down and away from the chassis to unlatch it.
      Ask FixBot
    6. How to Remove the SSD in Your Xbox Series X (Digital Edition): step 36, image 1 of 3 How to Remove the SSD in Your Xbox Series X (Digital Edition): step 36, image 2 of 3 How to Remove the SSD in Your Xbox Series X (Digital Edition): step 36, image 3 of 3
      • Pull the chassis strap off its three alignment posts and unlatch it from the sides of the power supply.
      • You can leave the strap under the chassis or remove it.
      • During reassembly, make sure the nubs in the middle of the strap go unto their cutouts on the heat sink fins.
      Ask FixBot
    7. How to Remove the SSD in Your Xbox Series X (Digital Edition), Remove the silver power supply screws: step 37, image 1 of 2 How to Remove the SSD in Your Xbox Series X (Digital Edition), Remove the silver power supply screws: step 37, image 2 of 2
      • Use a T8 Torx driver to remove the three 35 mm‑long silver screws from the power supply—leave the fourth black screw in place.
      Ask FixBot
    8. How to Remove the SSD in Your Xbox Series X (Digital Edition), Remove the center chassis: step 38, image 1 of 3 How to Remove the SSD in Your Xbox Series X (Digital Edition), Remove the center chassis: step 38, image 2 of 3 How to Remove the SSD in Your Xbox Series X (Digital Edition), Remove the center chassis: step 38, image 3 of 3
      • Grip the edges of the center chassis (not the power supply) and lift it off the motherboard and heatsink assembly, routing the interconnect cable through its cutout.
      Ask FixBot
    1. How to Remove the SSD in Your Xbox Series X (Digital Edition), Remove the SSD: step 39, image 1 of 2 How to Remove the SSD in Your Xbox Series X (Digital Edition), Remove the SSD: step 39, image 2 of 2
      • Use a T8 Torx driver to remove the 5.1 mm‑long screw securing the SSD.
      • With the SSD screw removed, the SSD will pop up at a shallow angle.
      Ask FixBot
    2. How to Remove the SSD in Your Xbox Series X (Digital Edition): step 40, image 1 of 2 How to Remove the SSD in Your Xbox Series X (Digital Edition): step 40, image 2 of 2
      • Grip the end of the SSD and pull it away from its M.2 board connector to remove it.
      • During reassembly, insert the SSD at a shallow angle into its board connector, and secure it back into its horizontal position with the SSD screw.
      Ask FixBot
Spencer Day
199,440 Reputation
1,243 Guides authored
iFixit Member of iFixit
Staff
123 Members
67,215 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 19
Past 30 Days: 67
All Time: 916
