How to Remove the SSD Modules in Your Mac Studio (2023)
  1. How to Remove the SSD Modules in Your Mac Studio (2023), Prepare your Mac Studio for disassembly: step 1, image 1 of 3 How to Remove the SSD Modules in Your Mac Studio (2023), Prepare your Mac Studio for disassembly: step 1, image 2 of 3 How to Remove the SSD Modules in Your Mac Studio (2023), Prepare your Mac Studio for disassembly: step 1, image 3 of 3
    • Completely shut down your Mac Studio.
    • Unplug all cables from your device.
  2. How to Remove the SSD Modules in Your Mac Studio (2023), Flip your Mac Studio over: step 2, image 1 of 1
    • Flip your Mac Studio over and lay it down so the bottom faces up and the SD card slot and two front USB‑C ports are facing you.
  3. How to Remove the SSD Modules in Your Mac Studio (2023), Heat the bottom cover screw pad: step 3, image 1 of 3 How to Remove the SSD Modules in Your Mac Studio (2023), Heat the bottom cover screw pad: step 3, image 2 of 3 How to Remove the SSD Modules in Your Mac Studio (2023), Heat the bottom cover screw pad: step 3, image 3 of 3
    • Adhesive strips secure the bottom cover screw pad.
    • Heat an iOpener and lay it over one of the bottom cover screws for two minutes to soften the adhesive near the screw—this is where you'll insert a spudger in the next step.
    • You can also use a hair dryer or heat gun, but be careful as extreme heat will warp the pad.
  4. How to Remove the SSD Modules in Your Mac Studio (2023), Lift a section of bottom cover screw pad: step 4, image 1 of 3 How to Remove the SSD Modules in Your Mac Studio (2023), Lift a section of bottom cover screw pad: step 4, image 2 of 3 How to Remove the SSD Modules in Your Mac Studio (2023), Lift a section of bottom cover screw pad: step 4, image 3 of 3
    • Insert the point of a spudger under the pad's inner edge, near the screw you applied heat to in the previous step.
    • This may take some force. If you're having trouble, apply more heat and try again.
    • Use the spudger to lift the pad and separate the adhesive.
  5. How to Remove the SSD Modules in Your Mac Studio (2023), Separate the remaining adhesive: step 5, image 1 of 3 How to Remove the SSD Modules in Your Mac Studio (2023), Separate the remaining adhesive: step 5, image 2 of 3 How to Remove the SSD Modules in Your Mac Studio (2023), Separate the remaining adhesive: step 5, image 3 of 3
    • Insert the flat end of a spudger under the pad.
    • Slide the spudger under the entire pad to separate the remaining adhesive.
  6. How to Remove the SSD Modules in Your Mac Studio (2023), Remove the bottom cover screw pad: step 6, image 1 of 1
    • Remove the bottom cover screw pad.
  7. How to Remove the SSD Modules in Your Mac Studio (2023), Reassembly information: step 7, image 1 of 3 How to Remove the SSD Modules in Your Mac Studio (2023), Reassembly information: step 7, image 2 of 3 How to Remove the SSD Modules in Your Mac Studio (2023), Reassembly information: step 7, image 3 of 3
    Tool used on this step:
    Tesa 61395 Tape
    $2.99
    Buy
    • During reassembly:
    • If the adhesive strips are still sticky, you can reuse them.
    • If you're applying new adhesive:
    • Use the flat end of a spudger and your fingers to scrape up and remove the old adhesive strips.
    • Use isopropyl alcohol and a microfiber cloth to remove the old adhesive residue.
    • If you don't have replacement adhesive, you can use strips of thin, double-sided tape 2–3 mm wide.
    • Apply the new adhesive strips to the bottom cover and remove their liners.
    • Firmly press the bottom cover screw pad into its recess to secure it.
  8. How to Remove the SSD Modules in Your Mac Studio (2023), Remove the bottom cover screws: step 8, image 1 of 2 How to Remove the SSD Modules in Your Mac Studio (2023), Remove the bottom cover screws: step 8, image 2 of 2
    FixMat
    $36.95
    Buy
    • While the Mac Studio uses Torx Plus screws, standard Torx bits work. Make sure to apply constant, downward force to prevent stripping.
    • Use a T10 Torx screwdriver to remove the four 8 mm‑long screws securing the bottom cover.
    • Throughout this repair, keep track of each screw and make sure it goes back exactly where it came.
  9. How to Remove the SSD Modules in Your Mac Studio (2023), Remove the bottom cover: step 9, image 1 of 3 How to Remove the SSD Modules in Your Mac Studio (2023), Remove the bottom cover: step 9, image 2 of 3 How to Remove the SSD Modules in Your Mac Studio (2023), Remove the bottom cover: step 9, image 3 of 3
    • Insert the point of a spudger in one of the bottom cover's ventilation holes and lift the cover until you can grab it with your fingers.
    • Remove the bottom cover.
    • To orient the bottom cover, align the Kensington lock cutout in the top left corner with the corresponding one on the internal frame.
  10. How to Remove the SSD Modules in Your Mac Studio (2023), Remove the power supply screws: step 10, image 1 of 2 How to Remove the SSD Modules in Your Mac Studio (2023), Remove the power supply screws: step 10, image 2 of 2
    • Use a T10 Torx screwdriver to remove the six screws securing the power supply:
    • Four 6 mm‑long screws
    • Two 7 mm‑long screws with washers
    • You may need to remove a sticker to access these screws. If you do, save it for reassembly.
  11. How to Remove the SSD Modules in Your Mac Studio (2023), Reposition your Mac Studio: step 11, image 1 of 1
    • Flip your Mac Studio around so the rear ports are facing you.
  12. How to Remove the SSD Modules in Your Mac Studio (2023), Disconnect the power cord port cable: step 12, image 1 of 3 How to Remove the SSD Modules in Your Mac Studio (2023), Disconnect the power cord port cable: step 12, image 2 of 3 How to Remove the SSD Modules in Your Mac Studio (2023), Disconnect the power cord port cable: step 12, image 3 of 3
    • A tight plastic latch secures the power cord port cable.
    • Firmly hold the power supply with one hand and lift up the edge near the power cord port.
    • With your free hand, pinch the head of the power cord port connector to unclip it and pull straight down to disconnect the cable.
  13. How to Remove the SSD Modules in Your Mac Studio (2023), Tilt up the power supply: step 13, image 1 of 1
    • Only grab the power supply by its edges. Various power components and capacitors are left exposed.
    • Carefully tilt the power supply away from the power cord port so it's at a 90-degree angle.
    • Be careful not to strain the cable that's still connected to the power supply.
    • Keep the power supply tilted up for the next step.
  14. How to Remove the SSD Modules in Your Mac Studio (2023), Disconnect the power supply signal cable: step 14, image 1 of 3 How to Remove the SSD Modules in Your Mac Studio (2023), Disconnect the power supply signal cable: step 14, image 2 of 3 How to Remove the SSD Modules in Your Mac Studio (2023), Disconnect the power supply signal cable: step 14, image 3 of 3
    • A delicate plastic clip secures the power supply signal cable.
    • With your free hand, pinch the head of the power supply connector to unclip it and pull straight away from the socket to disconnect the cable.
  15. How to Remove the SSD Modules in Your Mac Studio (2023), Remove the power supply: step 15, image 1 of 1
    • Remove the power supply.
  16. How to Remove the SSD Modules in Your Mac Studio (2023), Reposition your Mac Studio: step 16, image 1 of 1
    • Flip your Mac Studio around so the SD card reader and two front USB‑C ports are facing you.
  17. How to Remove the SSD Modules in Your Mac Studio (2023), Remove the internal frame screws: step 17, image 1 of 2 How to Remove the SSD Modules in Your Mac Studio (2023), Remove the internal frame screws: step 17, image 2 of 2
    • Use a T6 Torx screwdriver to remove the eight screws securing the internal frame:
    • Seven 5 mm‑long screws
    • One 4 mm‑long screw
  18. How to Remove the SSD Modules in Your Mac Studio (2023), Remove the internal frame: step 18, image 1 of 2 How to Remove the SSD Modules in Your Mac Studio (2023), Remove the internal frame: step 18, image 2 of 2
  19. How to Remove the SSD Modules in Your Mac Studio (2023), Unfasten the SSD modules: step 19, image 1 of 1
    • SSD SLEEVE?
    • Your Mac Studio will have one or two SSDs depending on its storage configuration.
    • Use a T8 Torx screwdriver to remove the 3.8 mm‑long screw(s) securing the SSD(s).
  20. How to Remove the SSD Modules in Your Mac Studio (2023), Loosen the SSD: step 20, image 1 of 3 How to Remove the SSD Modules in Your Mac Studio (2023), Loosen the SSD: step 20, image 2 of 3 How to Remove the SSD Modules in Your Mac Studio (2023), Loosen the SSD: step 20, image 3 of 3
    • The socket doesn't spring up the SSD like in some laptops—keep the SSD flat to the laptop when removing or inserting it to prevent damage to the socket.
    • The SSDs are secured tightly in their sockets.
    • Wiggle the SSD side-to-side while pulling it away from the socket to loosen it.
  21. How to Remove the SSD Modules in Your Mac Studio (2023), Remove the SSD: step 21, image 1 of 3 How to Remove the SSD Modules in Your Mac Studio (2023), Remove the SSD: step 21, image 2 of 3 How to Remove the SSD Modules in Your Mac Studio (2023), Remove the SSD: step 21, image 3 of 3
    • Pull the SSD straight out of its socket and remove it.
    • If you have a second SSD, repeat the process to remove it.
Restore your Mac from a backup after reassembly.
Spencer Day
150,254 Reputation
995 Guides authored
iFixit Member of iFixit
Staff
123 Members
23,649 Guides authored
2 Guide Comments
Thanks for the interesting article. You said: "Your Mac Studio will have one or two SSDs depending on its storage configuration".
Does it mean it uses Redundant Array of Independent Disks (RAID) 0, or Just a Bunch Of Disks (JBOD)? In either case, that would mean more than twice the probability of storage failure (compared to a single SSD), since when one SSD fails, the other SSD fails, or the controller fails, all date will be lost. Not good!!!
Peter Gamble - Reply
512GB, 1TB and 2TB configurations have just a single SSD module, the ones with higher capacity have 2 of those. this essentially means those are similar to RAID0/striping - just like it is with the soldered-on storage of MBP: the data is interleaved across the flash chips. I'd say the striping is used to boost the performance only. there are 4TB and 8TB configurations, which would imply that there's a 4TB module that could be also used "alone" to get 4 TB of internal storage. but apple preferred to go with 2+2 and 4+4TB configurations to double the media access bandwidth. these are essentially just bare flash chips (the SSD controller resides in the CPU complex - previously it was in the T2 chip) soldered on a PCB with a few passive components and regulators.
Attila Balogh -
Past 24 Hours: 9
Past 7 Days: 76
Past 30 Days: 368
All Time: 4,219
