How to Open Your Logitech M240 Wireless Mouse
    1. How to Open Your Logitech M240 Wireless Mouse, Turn off your mouse: step 1, image 1 of 1
      • Before starting, flip the power switch on the bottom of your mouse to the left, so it's in the OFF position.
      Ask FixBot
    2. How to Open Your Logitech M240 Wireless Mouse, Remove the battery cover: step 2, image 1 of 3 How to Open Your Logitech M240 Wireless Mouse, Remove the battery cover: step 2, image 2 of 3 How to Open Your Logitech M240 Wireless Mouse, Remove the battery cover: step 2, image 3 of 3
      • Press down on the battery cover with your thumb and slide it away from the mouse to unclip it.
      • Remove the battery cover.
      Ask FixBot
    3. How to Open Your Logitech M240 Wireless Mouse, Remove the battery: step 3, image 1 of 3 How to Open Your Logitech M240 Wireless Mouse, Remove the battery: step 3, image 2 of 3 How to Open Your Logitech M240 Wireless Mouse, Remove the battery: step 3, image 3 of 3
      • Use your fingers to lift the end of the battery and slide it out of its recess.
      • During reassembly, slide the battery in negative (-) end first, as shown in the recess.
      Ask FixBot
    1. How to Open Your Logitech M240 Wireless Mouse, Remove the sticker: step 4, image 1 of 1
      • The sticker in the battery recess hides a screw. If you don't mind damaging the sticker, you can skip this step and pierce through it with your screwdriver.
      • Use a pair of tweezers to slowly peel up and remove the sticker from the battery recess.
      • If you're having trouble, heat the sticker with an iOpener or hair dryer to make it easier to remove.
      Ask FixBot
    2. How to Open Your Logitech M240 Wireless Mouse, Remove the case screw: step 5, image 1 of 2 How to Open Your Logitech M240 Wireless Mouse, Remove the case screw: step 5, image 2 of 2
      • Use a Phillips screwdriver to remove the 5.5 mm‑long screw from the battery recess.
      Ask FixBot
    3. How to Open Your Logitech M240 Wireless Mouse, Separate the two halves: step 6, image 1 of 3 How to Open Your Logitech M240 Wireless Mouse, Separate the two halves: step 6, image 2 of 3 How to Open Your Logitech M240 Wireless Mouse, Separate the two halves: step 6, image 3 of 3
      • The two halves of the mouse are secured by two clips near the front.
      • Hold the bottom half of the mouse steady and pull the top half away and down to separate it.
      Ask FixBot
    4. How to Open Your Logitech M240 Wireless Mouse: step 7, image 1 of 1
      • Your mouse is now open.
      Ask FixBot
Reuse or Recycle—Never put discarded electronic parts in household waste. Visit Logitech Recycling to find your nearest recycling points, including the option to mail back old devices to Logitech for free if there’s no convenient solution in your area. You can also take your e-waste to any R2 or e-Stewards certified recycler. And don’t let good working parts or repaired devices die a slow death in your sock drawer—pass them along to someone who can use them.
Share your experience—Leave a comment here or send your feedback directly to Logitech at repair@logitech.com to help shape future repair guides and product design.
Spencer Day
205,716 Reputation
1,267 Guides authored
0 Guide Comments
Past 24 Hours: 8
Past 7 Days: 76
Past 30 Days: 378
All Time: 2,364
