How to Fix Logitech G403 Double Click Issue
  1. How to Fix Logitech G403 Double Click Issue, How to Fix Logitech G403 Double Click Issue: step 1, image 1 of 1
    • Use a prying tool or your hand to take out both sides of the mouse feet.
    Ask FixBot
  2. How to Fix Logitech G403 Double Click Issue: step 2, image 1 of 1
    • Use a precision screwdriver to remove four screws from the mouse.
    Ask FixBot
  3. How to Fix Logitech G403 Double Click Issue: step 3, image 1 of 2 How to Fix Logitech G403 Double Click Issue: step 3, image 2 of 2
    • Slowly open the mouse, and take care not to tear the ribbon cable.
    • Detach the cable connector.
    Ask FixBot
  4. How to Fix Logitech G403 Double Click Issue: step 4, image 1 of 2 How to Fix Logitech G403 Double Click Issue: step 4, image 2 of 2
    • Remove seven screws from the upper cover.
    Ask FixBot
  5. How to Fix Logitech G403 Double Click Issue: step 5, image 1 of 2 How to Fix Logitech G403 Double Click Issue: step 5, image 2 of 2
    • Remove four screws from the mouse.
    • Remove the mouse click cover.
    Ask FixBot
  6. How to Fix Logitech G403 Double Click Issue: step 6, image 1 of 2 How to Fix Logitech G403 Double Click Issue: step 6, image 2 of 2
    • Remove the five screws attached to the mouse click switches.
    Ask FixBot
  7. How to Fix Logitech G403 Double Click Issue: step 7, image 1 of 2 How to Fix Logitech G403 Double Click Issue: step 7, image 2 of 2
    • Open the mouse switch using a prying tool or your hands.
    • Be careful not to lose the white plastic part from the mouse switch.
    Ask FixBot
  8. How to Fix Logitech G403 Double Click Issue: step 8, image 1 of 2 How to Fix Logitech G403 Double Click Issue: step 8, image 2 of 2
    • Find the place where more tension is needed.
    • Use a prying tool or your hand to give more tension to the copper piece, making sure the copper is curved.
    Ask FixBot
10 other people completed this guide.
Jisuk Kang
415 Reputation
1 Guide authored
10 Guide Comments
Worked, thanks
Катерина Шумакова - Reply Share
step 8 made no sense and had to google it
rel - Reply Share
did you find a video about that? if you could send it pls or if it was some place where talk more about it
Lian López - Reply Share
Worked!!! I had this problem for years, even stoped playing valorant bacause of that. Thanks
VampireKing - Reply Share
I could not open these screws :( What are the screwdriver size to open these?
Siim - Reply Share
Past 24 Hours: 10
Past 7 Days: 54
Past 30 Days: 189
All Time: 36,756
