Introduction
This guide is intended to help you replace the belt on your vacuum. Please see the troubleshooting guide to determine if this needs replacing. Begin by removing the brush roll.
Push the red release lever to the right.
Turn the red switch counterclockwise.
Tilt the bottom of the plastic tray out towards you and pull it off the vacuum.
Remove the belt that's to the right of where the brush roll was by pulling the bottom off of the pin.
