Shop the Holiday Gift Guide
Headphone Jack (Prereq)
View statistics:
Past 24 Hours:
Past 7 Days:
2
Past 30 Days:
11
All Time:
125
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 1 - 2 hours
Difficulty: Moderate
Prerequisite Only
This is a prerequisite-only guide! This guide is part of another procedure and isn’t meant to be used alone.
Introduction
Go to step 1 ↓
Use this guide to replace the headphone jack in your iPad 9 Wi-Fi.
Note: this guide is for the Wi-Fi version only. For the LTE version, click here.
For your safety, discharge the battery below 25% before disassembling your iPad. This reduces the risk of fire if the battery is accidentally damaged during the repair. If your battery is swollen, take appropriate precautions.
Be very careful when you isolate the battery using a battery blocker. The battery contacts are easily damaged, resulting in irreversible damage. If you choose to complete the guide without isolating the battery, avoid using metal tools except when completely necessary (like when removing screws) to prevent shorting the battery and damaging sensitive circuit components.
Some photos in this guide are from a different model and may contain slight visual discrepancies, but they won't affect the guide procedure.
Tools
    1. Headphone Jack (Prereq), Disconnect the headphone jack: step 1, image 1 of 2 Headphone Jack (Prereq), Disconnect the headphone jack: step 1, image 2 of 2
      • Peel back any tape covering the headphone jack's press connector.
      Ask FixBot
    2. Headphone Jack (Prereq): step 2, image 1 of 2 Headphone Jack (Prereq): step 2, image 2 of 2
      • Use the flat end of the spudger to pry up and disconnect the headphone jack's press connector.
      Ask FixBot
    3. Headphone Jack (Prereq), Reposition the headphone jack: step 3, image 1 of 3 Headphone Jack (Prereq), Reposition the headphone jack: step 3, image 2 of 3 Headphone Jack (Prereq), Reposition the headphone jack: step 3, image 3 of 3
      Tool used on this step:
      Buy
      • The headphone jack cable is lightly adhered to the frame.
      • Use tweezers, or your fingers, to peel the headphone jack cable up from the frame.
      Ask FixBot
Repair didn’t go as planned? Try some basic troubleshooting, or ask our iPad 9 Answers community for help.
Author
with
Alex Diaz-Kokaisl
252,776 Reputation
1,200 Guides authored
Guide Team Member of Guide Team
Staff
10 Members
62,189 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 2
Past 30 Days: 11
All Time: 125
