Introduction
Use this guide to replace the battery in your HTC One M8.
Please note that your device may have a large amount of copper shielding and tape covering the back of the display assembly, as shown here. If this is the case, you'll need to gently remove it to get at the motherboard.
Insert a SIM card eject tool or a paperclip into the small hole in the SIM card tray, located on the upper left hand side of the phone.
Press to eject the tray.
Insert a SIM card eject tool or a paperclip into the small hole in the microSD card tray, located on the upper right hand side of the phone.
Use an iOpener or heat gun to loosen the adhesive on the upper and lower speaker grilles.
Remove the two silver 3 mm Phillips #00 screws from the top.
Remove the four black 4 mm T5 Torx screws from the bottom.
Work your way around the perimeter of the phone with a spudger and plastic opening picks to free the clips that secure the rear case to the display assembly.
Remove the two silver 2 mm Phillips #00 screws securing the battery connector to the motherboard.
Use a plastic opening tool to gently pry up the battery connector.
Use an iOpener or a heat gun to loosen up the adhesive securing the motherboard to the display assembly.
Use a plastic opening tool to gently pry the motherboard free of the display assembly.
Gently bend the various ribbon cables out of the way of the battery.
Use an iOpener or heat gun to loosen up the adhesive securing the battery to the display assembly.
Use a plastic opening tool to gently pry up the battery from the display assembly.
