HP EliteBook 845 G9 Display Assembly Replacement
  1. HP EliteBook 845 G9 Display Assembly Replacement, Before you begin: step 1, image 1 of 2 HP EliteBook 845 G9 Display Assembly Replacement, Before you begin: step 1, image 2 of 2
    • Before starting your repair, allow your laptop's battery to drain below 25%—a charged lithium-ion battery is a potential safety hazard if accidentally damaged.
    • Save your work, fully shut down your laptop, and unplug all cables.
  2. HP EliteBook 845 G9 Display Assembly Replacement, Unfasten the bottom cover: step 2, image 1 of 2 HP EliteBook 845 G9 Display Assembly Replacement, Unfasten the bottom cover: step 2, image 2 of 2
    • Despite the standards, Phillips screwdrivers can vary in size and shape—two drivers labeled as the same size may fit differently in the same screw. Use the size that fits the most snug into the screw head to avoid stripping it.
    • Use a Phillips screwdriver to fully loosen (not remove) the five captive screws securing the bottom cover.
  3. HP EliteBook 845 G9 Display Assembly Replacement, Release the bottom cover clips: step 3, image 1 of 2 HP EliteBook 845 G9 Display Assembly Replacement, Release the bottom cover clips: step 3, image 2 of 2
    • Position your laptop so the rear edge (with the screen hinge) is closest to you.
    • Insert the flat end of a spudger between the rear edge of the bottom cover and the frame, near the middle screw and ELITEBOOK text.
    • If you're having trouble inserting your spudger, make sure the screw is fully loosened. If necessary, use your fingers to gently pull the screw up.
    • Use your spudger to pry up the cover to release the clip securing it.
    • Leave the spudger inserted under the bottom cover for the next step.
  4. HP EliteBook 845 G9 Display Assembly Replacement: step 4, image 1 of 3 HP EliteBook 845 G9 Display Assembly Replacement: step 4, image 2 of 3 HP EliteBook 845 G9 Display Assembly Replacement: step 4, image 3 of 3
    • Slide your spudger along the rear edge toward one of the corners to release the rear edge clips.
    • Rotate your spudger around the corner and up the edge to release the clips securing the short edge of the cover.
  5. HP EliteBook 845 G9 Display Assembly Replacement: step 5, image 1 of 3 HP EliteBook 845 G9 Display Assembly Replacement: step 5, image 2 of 3 HP EliteBook 845 G9 Display Assembly Replacement: step 5, image 3 of 3
    • Reinsert the flat end of a spudger near the ELITEBOOK text.
    • Repeat the previous step for the other side of the cover to release the remaining clips.
  6. HP EliteBook 845 G9 Display Assembly Replacement, Remove the bottom cover: step 6, image 1 of 3 HP EliteBook 845 G9 Display Assembly Replacement, Remove the bottom cover: step 6, image 2 of 3 HP EliteBook 845 G9 Display Assembly Replacement, Remove the bottom cover: step 6, image 3 of 3
    • Slide the cover towards the screen hinge to disengage the clips on the opposite edge.
    • Lift and remove the cover.
    • The cover should come away easily. If you feel resistance, use the flat end of a spudger to release any remaining clips.
    • During reassembly, slide the clips along the front edge of the cover (opposite the hinge) into their slots on the frame, then lay the cover down. Firmly press around the perimeter of the cover to engage all the clips.
  7. HP EliteBook 845 G9 Display Assembly Replacement, Disconnect the battery: step 7, image 1 of 3 HP EliteBook 845 G9 Display Assembly Replacement, Disconnect the battery: step 7, image 2 of 3 HP EliteBook 845 G9 Display Assembly Replacement, Disconnect the battery: step 7, image 3 of 3
    • Position your laptop so the front edge (opposite the screen hinges) is closest to you.
    • Use the point of a spudger to push on alternating sides of the battery's sliding connector to walk it completely out of its socket.
  8. HP EliteBook 845 G9 Display Assembly Replacement, Disconnect the display cable: step 8, image 1 of 3 HP EliteBook 845 G9 Display Assembly Replacement, Disconnect the display cable: step 8, image 2 of 3 HP EliteBook 845 G9 Display Assembly Replacement, Disconnect the display cable: step 8, image 3 of 3
    • Use your fingers to grip the plastic pull tab on the left display cable press connector, located below the fan.
    • Pull straight up to disconnect the connector.
    • During reassembly, align the connector carefully over its socket and press down with your fingertip—first on one side, then the other—until it clicks into place. Don't try to force the connector into place. If you're having trouble, reposition it and try again. Don't use excessive force.
  9. HP EliteBook 845 G9 Display Assembly Replacement, Disconnect the WWAN cables: step 9, image 1 of 3 HP EliteBook 845 G9 Display Assembly Replacement, Disconnect the WWAN cables: step 9, image 2 of 3 HP EliteBook 845 G9 Display Assembly Replacement, Disconnect the WWAN cables: step 9, image 3 of 3
    • Slide one arm of a pair of angled tweezers under the metal neck of one of the coaxial connectors on the WWAN (cellular) module.
    • Lift straight up to disconnect the cable.
    • Repeat the process to disconnect the three remaining coaxial connectors.
    • During reassembly:
    • Use the numbered pieces of tape on the cables and their corresponding markings on the WWAN module to correctly connect each cable.
    • Use tweezers to hold a connector in place over its socket and gently press down with your finger or a spudger—the connector should "snap" into place. If you're having trouble, reposition the head and try again. Don't use excessive force.
  10. HP EliteBook 845 G9 Display Assembly Replacement, De‑route the cables: step 10, image 1 of 3 HP EliteBook 845 G9 Display Assembly Replacement, De‑route the cables: step 10, image 2 of 3 HP EliteBook 845 G9 Display Assembly Replacement, De‑route the cables: step 10, image 3 of 3
    • Use your fingers to pull the display cable and four coaxial cables out of their clips on the left side of the fan.
    • During reassembly, use this photo as a reference to properly route the cables into their clips.
  11. HP EliteBook 845 G9 Display Assembly Replacement, Disconnect the WLAN module cables: step 11, image 1 of 3 HP EliteBook 845 G9 Display Assembly Replacement, Disconnect the WLAN module cables: step 11, image 2 of 3 HP EliteBook 845 G9 Display Assembly Replacement, Disconnect the WLAN module cables: step 11, image 3 of 3
    • Slide an arm of a pair of angled tweezers under the metal neck of one of the coaxial connectors on the WLAN (Wi-Fi) module, near the right hinge.
    • Repeat the process to disconnect the remaining coaxial connector.
    • Connect the cable with black tape to the socket with a black arrow below it, and the white cable to the socket with a white arrow.
  12. HP EliteBook 845 G9 Display Assembly Replacement, Disconnect the display cable: step 12, image 1 of 2 HP EliteBook 845 G9 Display Assembly Replacement, Disconnect the display cable: step 12, image 2 of 2
    • Use your fingers to grip the plastic pull tab on the right display cable press connector, located near the right hinge.
  13. HP EliteBook 845 G9 Display Assembly Replacement: step 13, image 1 of 3 HP EliteBook 845 G9 Display Assembly Replacement: step 13, image 2 of 3 HP EliteBook 845 G9 Display Assembly Replacement: step 13, image 3 of 3
    • Use your fingers to pull the display cable and two coaxial cables out of their clips along the top edge of your laptop.
  14. HP EliteBook 845 G9 Display Assembly Replacement, Hang the screen over an edge: step 14, image 1 of 3 HP EliteBook 845 G9 Display Assembly Replacement, Hang the screen over an edge: step 14, image 2 of 3 HP EliteBook 845 G9 Display Assembly Replacement, Hang the screen over an edge: step 14, image 3 of 3
    • Make sure there aren't any loose components or rogue screws that might fall out of your laptop when you open it.
    • Grab the main body of your laptop and open it to a 90-degree angle.
    • Lay your laptop keyboard-side down on the edge of a flat, clean work surface, with the screen hanging over the edge, straight down.
    • During reassembly, if your screen clicks or snaps when it's opened or closed, loosen the screws and re‑align the screen.
  15. HP EliteBook 845 G9 Display Assembly Replacement, Remove the hinge screws: step 15, image 1 of 3 HP EliteBook 845 G9 Display Assembly Replacement, Remove the hinge screws: step 15, image 2 of 3 HP EliteBook 845 G9 Display Assembly Replacement, Remove the hinge screws: step 15, image 3 of 3
    • Hold your laptop steady with your free hand while removing or installing hinge screws—don't let it fall off of your work surface.
    • Use a Phillips screwdriver to remove the six 4.6 mm‑long hinge screws—three in each hinge.
    • During reassembly, make sure the display is properly aligned before tightening the hinge screws.
  16. HP EliteBook 845 G9 Display Assembly Replacement, Remove the screen: step 16, image 1 of 3 HP EliteBook 845 G9 Display Assembly Replacement, Remove the screen: step 16, image 2 of 3 HP EliteBook 845 G9 Display Assembly Replacement, Remove the screen: step 16, image 3 of 3
    • Lift the screen hinges out of their recesses one at a time to remove the screen.
    • During reassembly, make sure both hinges on your replacement display assembly are open to a 90‑degree angle before lowering them into their recesses.
Compare your new replacement part to the original part—you may need to transfer remaining components or remove adhesive backings from the new part before you install it.
Take your e-waste to an R2 or e-Stewards certified recycler. Depending on your region, used HP devices and parts can be returned for reuse or recycling through the HP Planet Partners program.
Matt Zieminski
48,372 Reputation
28 Guides authored
iFixit Member of iFixit
Staff
123 Members
23,738 Guides authored
0 Guide Comments
Past 24 Hours: 10
Past 7 Days: 18
Past 30 Days: 61
All Time: 379
