HP EliteBook 840 G9 Right Speaker Replacement
  1. HP EliteBook 840 G9 Right Speaker Replacement, Before you begin: step 1, image 1 of 2 HP EliteBook 840 G9 Right Speaker Replacement, Before you begin: step 1, image 2 of 2
    • Before starting your repair, allow your laptop's battery to drain below 25%—a charged lithium-ion battery is a potential safety hazard if accidentally damaged.
    • Save your work, fully shut down your laptop, and unplug all cables.
  2. HP EliteBook 840 G9 Right Speaker Replacement, Unfasten the bottom cover: step 2, image 1 of 2 HP EliteBook 840 G9 Right Speaker Replacement, Unfasten the bottom cover: step 2, image 2 of 2
    • Despite the standards, Phillips screwdrivers can vary in size and shape—two drivers labeled as the same size may fit differently in the same screw. Use the size that fits the most snug into the screw head to avoid stripping it.
    • Use a Phillips screwdriver to fully loosen (not remove) the five captive screws securing the bottom cover.
  3. HP EliteBook 840 G9 Right Speaker Replacement, Release the bottom cover clips: step 3, image 1 of 2 HP EliteBook 840 G9 Right Speaker Replacement, Release the bottom cover clips: step 3, image 2 of 2
    • Position your laptop so the rear edge (with the screen hinge) is closest to you.
    • Insert the flat end of a spudger between the rear edge of the bottom cover and the frame, near the middle screw and ELITEBOOK text.
    • If you're having trouble inserting your spudger, make sure the screw is fully loosened. If necessary, use your fingers to gently pull the screw up.
    • Use your spudger to pry up the cover to release the clip securing it.
    • Leave the spudger inserted under the bottom cover for the next step.
  4. HP EliteBook 840 G9 Right Speaker Replacement: step 4, image 1 of 3 HP EliteBook 840 G9 Right Speaker Replacement: step 4, image 2 of 3 HP EliteBook 840 G9 Right Speaker Replacement: step 4, image 3 of 3
    • Slide your spudger along the rear edge toward one of the corners to release the rear edge clips.
    • Rotate your spudger around the corner and up the edge to release the clips securing the short edge of the cover.
  5. HP EliteBook 840 G9 Right Speaker Replacement: step 5, image 1 of 3 HP EliteBook 840 G9 Right Speaker Replacement: step 5, image 2 of 3 HP EliteBook 840 G9 Right Speaker Replacement: step 5, image 3 of 3
    • Reinsert the flat end of a spudger near the ELITEBOOK text.
    • Repeat the previous step for the other side of the cover to release the remaining clips.
  6. HP EliteBook 840 G9 Right Speaker Replacement, Remove the bottom cover: step 6, image 1 of 3 HP EliteBook 840 G9 Right Speaker Replacement, Remove the bottom cover: step 6, image 2 of 3 HP EliteBook 840 G9 Right Speaker Replacement, Remove the bottom cover: step 6, image 3 of 3
    • Slide the cover towards the screen hinge to disengage the clips on the opposite edge.
    • Lift and remove the cover.
    • The cover should come away easily. If you feel resistance, use the flat end of a spudger to release any remaining clips.
    • During reassembly, slide the clips along the front edge of the cover (opposite the hinge) into their slots on the frame, then lay the cover down. Firmly press around the perimeter of the cover to engage all the clips.
  7. HP EliteBook 840 G9 Right Speaker Replacement, Disconnect the battery: step 7, image 1 of 3 HP EliteBook 840 G9 Right Speaker Replacement, Disconnect the battery: step 7, image 2 of 3 HP EliteBook 840 G9 Right Speaker Replacement, Disconnect the battery: step 7, image 3 of 3
    • Position your laptop so the front edge (opposite the screen hinges) is closest to you.
    • Use the point of a spudger to push on alternating sides of the battery's sliding connector to walk it completely out of its socket.
  8. HP EliteBook 840 G9 Right Speaker Replacement, Disconnect the speaker: step 8, image 1 of 3 HP EliteBook 840 G9 Right Speaker Replacement, Disconnect the speaker: step 8, image 2 of 3 HP EliteBook 840 G9 Right Speaker Replacement, Disconnect the speaker: step 8, image 3 of 3
    • The right speaker will be on your left‑hand side while working, as the laptop is laying upside down.
    • Use the point of a spudger to push on alternating sides of the right speaker's sliding connector to walk it completely out of its socket.
  9. HP EliteBook 840 G9 Right Speaker Replacement, Remove the speaker screws: step 9, image 1 of 2 HP EliteBook 840 G9 Right Speaker Replacement, Remove the speaker screws: step 9, image 2 of 2
    • Use a Phillips screwdriver to remove the two 2.5 mm‑long screws securing the right speaker.
  10. HP EliteBook 840 G9 Right Speaker Replacement, Remove the right speaker: step 10, image 1 of 3 HP EliteBook 840 G9 Right Speaker Replacement, Remove the right speaker: step 10, image 2 of 3 HP EliteBook 840 G9 Right Speaker Replacement, Remove the right speaker: step 10, image 3 of 3
    • Grommets secure the top and bottom of the speaker.
    • Lift the speaker straight up and off its posts to remove it.
    • During reassembly:
    • Make sure the new speaker has grommets. If it doesn't, transfer over the original grommets.
    • Align the grommets over their screw posts and press down gently to secure the speaker in place.
    • Don't press down on the rectangular rubber diaphragm on the top edge, or you'll damage the speaker.
Compare your new replacement part to the original part—you may need to transfer remaining components or remove adhesive backings from the new part before you install it.
Take your e-waste to an R2 or e-Stewards certified recycler. Depending on your region, used HP devices and parts can be returned for reuse or recycling through the HP Planet Partners program.
Spencer Day
162,686 Reputation
1,043 Guides authored
iFixit Member of iFixit
Staff
124 Members
24,166 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 5
Past 30 Days: 30
All Time: 317
