Chromebook 15 CB3-531-C4A5 Battery Replacement
  1. Chromebook 15 CB3-531-C4A5 Battery Replacement, Case: step 1, image 1 of 2 Chromebook 15 CB3-531-C4A5 Battery Replacement, Case: step 1, image 2 of 2
    • Remove the 18 Phillips screws using a screwdriver with a PH0 bit.
  2. Chromebook 15 CB3-531-C4A5 Battery Replacement: step 2, image 1 of 2 Chromebook 15 CB3-531-C4A5 Battery Replacement: step 2, image 2 of 2
    • Using a spudger, gently pry open the back from the top.
  3. Chromebook 15 CB3-531-C4A5 Battery Replacement, Battery: step 3, image 1 of 1
    • Once it is opened up, locate the battery and the cable that is attached to it.
  4. Chromebook 15 CB3-531-C4A5 Battery Replacement: step 4, image 1 of 2 Chromebook 15 CB3-531-C4A5 Battery Replacement: step 4, image 2 of 2
    • Next, unscrew the battery cable. The one screw should be located on the far right of it. This will ensure that the battery comes out easily and affectively.
  5. Chromebook 15 CB3-531-C4A5 Battery Replacement: step 5, image 1 of 1
    • Take the battery out easily for replacement.
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 15
All Time: 2,089
