Introduction
You may need to replace the battery if you have a faulty battery. It will require you to take the back of the computer off and replace the battery internally. There are no hazards accompanied with this task as long as the Chromebook is not charging.
Next, unscrew the battery cable. The one screw should be located on the far right of it. This will ensure that the battery comes out easily and affectively.
