HP Chromebook 14-Q010DX Fan Replacement
  1. HP Chromebook 14-Q010DX Fan Replacement, Keyboard and Touchpad: step 1, image 1 of 2 HP Chromebook 14-Q010DX Fan Replacement, Keyboard and Touchpad: step 1, image 2 of 2
    • Flip the laptop with the base of the laptop is facing you.
    • Using the #00 screwdriver, unscrew these screws.
  2. HP Chromebook 14-Q010DX Fan Replacement: step 2, image 1 of 3 HP Chromebook 14-Q010DX Fan Replacement: step 2, image 2 of 3 HP Chromebook 14-Q010DX Fan Replacement: step 2, image 3 of 3
    • Warning! When prying open a laptop it could require some force, but it also has fragile connectors underneath. Use caution so as to avoid breaking these connectors.
    • Start from the top right corner of the laptop and work clockwise with an iFixit opening tool or spudger to pry the keyboard from the frame of the laptop.
  3. HP Chromebook 14-Q010DX Fan Replacement: step 3, image 1 of 3 HP Chromebook 14-Q010DX Fan Replacement: step 3, image 2 of 3 HP Chromebook 14-Q010DX Fan Replacement: step 3, image 3 of 3
    • Warning! Handle the flaps and ribbon cables with care to prevent damage.
    • Gently pull the keyboard in the opposite direction of the screen, so the wires beneath are exposed.
    • Lift the black flap and pull the blue ribbon gently towards you until it is disconnected.
    • Lift the white flap and pull the blue ribbon towards you until it is disconnected.
  4. HP Chromebook 14-Q010DX Fan Replacement: step 4, image 1 of 1
    • Lift keyboard slightly and remove the strip gently to prevent damaging any parts.
    • The tape has no function other than to keep the wire tucked away.
  5. HP Chromebook 14-Q010DX Fan Replacement: step 5, image 1 of 1
    • Set aside the detached keyboard.
  6. HP Chromebook 14-Q010DX Fan Replacement, Fan: step 6, image 1 of 2 HP Chromebook 14-Q010DX Fan Replacement, Fan: step 6, image 2 of 2
    • Remove the 3 screws around the fan, indicated by red circles in the picture.
    • Using your fingers or the spudger, disconnect the cable connecting the fan to the motherboard. The connector is indicated by the orange rectangle in the picture.
  7. HP Chromebook 14-Q010DX Fan Replacement: step 7, image 1 of 1
    • Gently remove fan.
Kevin Piper
1,599 Reputation
6 Guides authored
USF Tampa, Team 17-2, Watkins Winter 2015 Member of USF Tampa, Team 17-2, Watkins Winter 2015
USFT-WATKINS-W15S17G2
4 Members
8 Guides authored
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 13
All Time: 3,875
