Introduction
This guide requires removal of 3x3mm screws from the fan assembly.
Flip the laptop with the base of the laptop is facing you.
Using the #00 screwdriver, unscrew these screws.
Start from the top right corner of the laptop and work clockwise with an iFixit opening tool or spudger to pry the keyboard from the frame of the laptop.
Gently pull the keyboard in the opposite direction of the screen, so the wires beneath are exposed.
Lift the black flap and pull the blue ribbon gently towards you until it is disconnected.
Lift the white flap and pull the blue ribbon towards you until it is disconnected.
Remove the 3 screws around the fan, indicated by red circles in the picture.
Using your fingers or the spudger, disconnect the cable connecting the fan to the motherboard. The connector is indicated by the blue rectangle in the picture.
