HP Chromebook 11 G8 EE Battery Replacement
  1. HP Chromebook 11 G8 EE Battery Replacement, Keyboard & Touchpad Assembly: step 1, image 1 of 1
    • Use a Phillips #1 screwdriver to remove:
    • Four 7 mm screws.
    • Two 8 mm screws.
  2. HP Chromebook 11 G8 EE Battery Replacement: step 2, image 1 of 2 HP Chromebook 11 G8 EE Battery Replacement: step 2, image 2 of 2
    • Flip the device over and open the lid.
    • Use a plastic opening tool to pry the keyboard assembly away from the bottom case, prying around the perimeter until it fully separates.
    • Lift the keyboard assembly from the laptop towards you, away from the screen.
  3. HP Chromebook 11 G8 EE Battery Replacement: step 3, image 1 of 3 HP Chromebook 11 G8 EE Battery Replacement: step 3, image 2 of 3 HP Chromebook 11 G8 EE Battery Replacement: step 3, image 3 of 3
    Tool used on this step:
    Buy
    • Lift the keyboard ribbon lock bar and use tweezers to disconnect the keyboard ribbon from the motherboard.
    • Lift the lock bar and use tweezers to remove the touchpad ribbon.
    • Remove the keyboard.
  4. HP Chromebook 11 G8 EE Battery Replacement, Battery: step 4, image 1 of 1
    • Do not puncture or damage any parts of the battery.
    • Disconnect the battery cable from the motherboard by pulling the connector straight out of its motherboard port.
    • The speakers are removed in these images, but they don't need to be to replace the battery.
  5. HP Chromebook 11 G8 EE Battery Replacement: step 5, image 1 of 3 HP Chromebook 11 G8 EE Battery Replacement: step 5, image 2 of 3 HP Chromebook 11 G8 EE Battery Replacement: step 5, image 3 of 3
    • Remove the four 3.5 mm Phillips #1 screws securing the battery.
    • If you've already removed the speakers, you'll only need to remove the two screws on the top of the battery, near the motherboard.
  6. HP Chromebook 11 G8 EE Battery Replacement: step 6, image 1 of 2 HP Chromebook 11 G8 EE Battery Replacement: step 6, image 2 of 2
    • Carefully lift the battery up and out.
Julia Latura
334 Reputation
3 Guides authored
UMass Dartmouth, Team 4-2, Sinclaire Fall 2022 Member of UMass Dartmouth, Team 4-2, Sinclaire Fall 2022
UMASSD-SINCLAIRE-F22S4G2
5 Members
13 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 15
Past 30 Days: 71
All Time: 1,541
