This teardown is not a repair guide. To repair your Microsoft Surface Pro 4, use our service manual.
    1. Microsoft Surface Pro 4 Teardown, Microsoft Surface Pro 4 Teardown: step 1, image 1 of 3 Microsoft Surface Pro 4 Teardown, Microsoft Surface Pro 4 Teardown: step 1, image 2 of 3 Microsoft Surface Pro 4 Teardown, Microsoft Surface Pro 4 Teardown: step 1, image 3 of 3
      • With the top-of-the-line model coming in at over $2600, the Surface Pro 4 had better be a cut above the rest—the spec sheet looks promising so far:
      • 12.3" PixelSense 2736 × 1824 (267 ppi) IPS LCD display
      • Intel Skylake Core m3 (4M Cache, 2.20 GHz) up to Core i7 (8M Cache, 3.80 GHz) CPU
      • 4 GB/8 GB/16 GB DDR3L 1600 MHz RAM
      • 128 GB/256 GB/512 GB/1 TB of PCIe solid state storage
      • 8 MP rear-facing 1080p camera, and 5 MP front-facing camera
      • USB 3.0 port, micro-SD slot, mini DisplayPort, and SurfaceConnect charging port
      • 802.11a/b/g/n/ac Dual Band Wi-Fi and Bluetooth 4.0
      Ask FixBot
    2. Microsoft Surface Pro 4 Teardown: step 2, image 1 of 3 Microsoft Surface Pro 4 Teardown: step 2, image 2 of 3 Microsoft Surface Pro 4 Teardown: step 2, image 3 of 3
      • At first glance, the Surface Pro 4 appears to outshine its predecessors with its forward sensor array.
      • We spy at least four nodes of interest. One's a camera, one's probably a microphone, but the rest?
      • On the rear of the new Surface, we find a familiar arrangement of circles—the 8 MP rear-facing camera accompanied by a status LED and microphone.
      • Anxious to see the camera array but too impatient to open the device? X-ray it.
      Ask FixBot
    3. Microsoft Surface Pro 4 Teardown: step 3, image 1 of 2 Microsoft Surface Pro 4 Teardown: step 3, image 2 of 2
      • That's something we don't see too often—grease! The Pro 4's exposed kickstand hinges are lubricated to meet your transforming computational needs.
      • Just try not to get any lint, or pet hair, or sand in there...
      • To get such a wide spread of kickstand angles, with the resistance required to support the tablet's weight, Microsoft's engineers probably spent a lot of time on these hinges. So we X-rayed them.
      Ask FixBot
    4. Microsoft Surface Pro 4 Teardown: step 4, image 1 of 3 Microsoft Surface Pro 4 Teardown: step 4, image 2 of 3 Microsoft Surface Pro 4 Teardown: step 4, image 3 of 3
      Tool used on this step:
      iOpener
      $14.95
      Buy
      • Sticky nightmares still haunt our teardown engineers after the harrowing Surface Pro 3 teardown, and this year we've prepared for the worst.
      • Things start to heat up in the teardown room as the iOpener battles to weaken the display's adhesive.
      • Our iSclack joins the fight to provide us the leverage we need to make our entrance, and dare we say it, things seem easier than before.
      • Not even a Pro can keep us out. As soon as we get an opening pick underneath the edge of the display it's off to the races!
      • We strain our ears to listen for the telltale cracking of glass, but it seems like we're getting away with this opening procedure shard-free!
      Ask FixBot
    5. Microsoft Surface Pro 4 Teardown: step 5, image 1 of 3 Microsoft Surface Pro 4 Teardown: step 5, image 2 of 3 Microsoft Surface Pro 4 Teardown: step 5, image 3 of 3
      • Well, these are new. The last time we tore down a Surface Pro, we encountered a display connector trapped beneath a springy metal bracket.
      • This time around, there are two cables holding the display to the body, preventing it from being opened like a book on any hinge. Our only recourse: tackle those connectors.
      • And of course, Microsoft has modified their connector design. The display connectors are relatively common press-on connectors—similar to an iPhone display—but they're trapped under snap-on metal shields.
      • Luckily, we only have to juggle the display for the first connector, this display is nearly free!
      Ask FixBot
    6. Microsoft Surface Pro 4 Teardown: step 6, image 1 of 2 Microsoft Surface Pro 4 Teardown: step 6, image 2 of 2
      • It's not exactly a greeting card, but the underside of the display is adorned with heartfelt-looking barcodes.
      • Maybe it's a congratulatory message! More likely, it's proof of some intense quality controls.
      • As a matter of curiosity, and bragging rights, we measure the display glass at a mere .4 mm. That's only four human hairs thick. And we didn't break it.
      • Time for our favorite silicon-based snack—chips! Among them, a number of N-trig IC's, likely control hardware for the Surface Pen.
      • N-trig DS-D5000 touchscreen row driver (likely)
      • N-trig DS-A5048 touchscreen line driver (likely)
      • Macronix MX25U1635F 1.8V 16 Mb MXSMIO serial flash memory
      Ask FixBot
    7. Microsoft Surface Pro 4 Teardown: step 7, image 1 of 3 Microsoft Surface Pro 4 Teardown: step 7, image 2 of 3 Microsoft Surface Pro 4 Teardown: step 7, image 3 of 3
      • Turning our attention to the rest of the Pro 4, we spy a suspicious blank space beside the motherboard (and heat sink tubing!).
      • Presumably, this is for the fan that drives the hybrid cooling system, absent from our 4.5-watt Core m3 model.
      • The motherboard is so close, yet so far. Unable to wait, we skip to dessert and pop off some shields to get a closer look.
      • The rest of the motherboard is nestled too snugly to investigate, but that SSD looks ripe for the picking...
      Ask FixBot
    8. Microsoft Surface Pro 4 Teardown: step 8, image 1 of 3 Microsoft Surface Pro 4 Teardown: step 8, image 2 of 3 Microsoft Surface Pro 4 Teardown: step 8, image 3 of 3
      • Oh Surface, look how you've grown!
      • The Surface 4's Samsung branded SSD is considerably larger than the little whipper snapper we saw in the previous generation.
      • Awww, they brought us more chips. The 128 GB Samsung PM951 SSD is packing the following:
      • Samsung S4LN058A01-8030 PCIe 3.0 x4 NVMe flash controller
      • Samsung K9CHGY8S5C-CCK0 64 GB NAND flash
      • Samsung K4E4E324EE-SGCF 4 Gb (512 MB) DRAM
      • Texas Instruments TPS22966 5.5V, 6A, 16mΩ, 2-channel load switch
      • Silergy power management (likely)
      Ask FixBot
    9. Microsoft Surface Pro 4 Teardown: step 9, image 1 of 2 Microsoft Surface Pro 4 Teardown: step 9, image 2 of 2
      • The Surface Pro 4's heat sink shows off its impressive makeover, flaunting longer copper heat pipes and a large copper plate for added heat dissipation.
      • Most likely, these changes were made to address the heat-related throttling issues observed in the Surface Pro 3.
      • Designed with a hybrid cooling system, the Pro 4 takes advantage of both passive and active cooling.
      • Well, some of them do. Our unit uses a combination of passive cooling and...well, passive cooling. More powerful models include a fan that activates when temperatures get too high for passive cooling.
      Ask FixBot
    10. Microsoft Surface Pro 4 Teardown: step 10, image 1 of 3 Microsoft Surface Pro 4 Teardown: step 10, image 2 of 3 Microsoft Surface Pro 4 Teardown: step 10, image 3 of 3
      • Fittingly, the Surface has a pro line-up of cameras and sensors:
      • Infrared emitter
      • Infrared camera
      • Front-facing camera
      • "Privacy light" indicator LED (mounted on the rear-facing camera)
      • Microphone
      • Ambient light sensor
      • We're pretty sure the lil' guy marked in red is an IR emitter, like the one found in Project Tango. It should work with the IR camera to recognize your face and unlock your computer. Aw, he knows his mummy.
      Ask FixBot
    11. Microsoft Surface Pro 4 Teardown: step 11, image 1 of 3 Microsoft Surface Pro 4 Teardown: step 11, image 2 of 3 Microsoft Surface Pro 4 Teardown: step 11, image 3 of 3
      • Amidst this sea of tech, the tablet's three cameras all float to the surface.
      • From left to right:
      • Infrared face-detection camera supporting Windows Hello
      • Front-facing 5 MP camera
      • Rear-facing 8 MP main camera
      Ask FixBot
    12. Microsoft Surface Pro 4 Teardown: step 12, image 1 of 3 Microsoft Surface Pro 4 Teardown: step 12, image 2 of 3 Microsoft Surface Pro 4 Teardown: step 12, image 3 of 3
      • We tweeze out the two stereo speakers from the corners of the case and make an interesting discovery...
      • It looks like the volume and power buttons are integrated directly into one of the speakers.
      • The Good: These integrated buttons are much less fidgity to replace as one piece than each button individually.
      • The Bad: The entire speaker will have to be replaced to replace one of the buttons, increasing the cost of repair.
      Ask FixBot
    13. Microsoft Surface Pro 4 Teardown: step 13, image 1 of 2 Microsoft Surface Pro 4 Teardown: step 13, image 2 of 2
      • With the peripherals deftly dissected, we can move on to the main event—the motherboard!
      • Intel SR2EN Core m3-6Y30 (4M Cache, up to 2.20 GHz)
      • Samsung K4E8E304EE-EGCF 8 Gb LPDDR3 (4 chips × 1 GB for a total of 4 GB)
      • Marvell Avastar 88W8897 802.11ac, NFC and Bluetooth SoC
      • Freescale Kinetis KL17 MKL17Z256VFM4 48 MHz ARM Cortex-M0+
      • ITE Tech, Inc. IT8528VG Embedded Controller
      • Realtek ALC3269 Audio Codec
      • Realtek RTS5304 micro-SD Card Reader Controller
      Ask FixBot
    14. Microsoft Surface Pro 4 Teardown: step 14, image 1 of 2 Microsoft Surface Pro 4 Teardown: step 14, image 2 of 2
      • Chip ID continued...
      • Winbond W25Q128FV Serial NOR Flash
      • Texas Instruments TPS51367 Integrated FET Converter
      • Infineon Technologies SLB96659TT20 Trusted Platform Module
      • Monolithic Power Systems MP3388S 50V, 8-String, Step-Up, White LED Driver
      • And on the reverse...
      • Intersil ISL95857 1+2+1 Voltage Regulator for Intel IMVP8 CPUs
      • This huge array of spring contacts connects the motherboard to the battery and the keyboard dock cable.
      Ask FixBot
    15. Microsoft Surface Pro 4 Teardown: step 15, image 1 of 2 Microsoft Surface Pro 4 Teardown: step 15, image 2 of 2
      • IC Identification—even more!
      • Bosch Sensortec BMI160 3-Axis Accelerometer/Gyroscope
      • Monolithic Power Systems MP2370DGT White LED Driver
      • Texas Instruments BQ24770 Battery Charge Controller w/ System Power Monitor
      • ON Semiconductor and Winbond Serial Memory
      • Texas Instruments TPS51285A Dual-Synchronous Buck Controller
      • Texas Instruments TPS62140, TPS62175, TPS62134A, TPS62134C, and TPS62134D Step-Down Converter
      • ON Semiconductor NCP380HMUAJAATBG Adj. Current‐Limiting Power‐Distribution Switch
      Ask FixBot
    16. Microsoft Surface Pro 4 Teardown: step 16, image 1 of 2 Microsoft Surface Pro 4 Teardown: step 16, image 2 of 2
      • The iOpener comes out for an encore performance, loosening the tough adhesive that holds the battery in place.
      • The battery finally comes loose after a great deal of sweat, tears, and prying.
      • Not much has changed here—the adhesive is still extremely challenging to overcome, even with the proper tools.
      Ask FixBot
    17. Microsoft Surface Pro 4 Teardown: step 17, image 1 of 2 Microsoft Surface Pro 4 Teardown: step 17, image 2 of 2
      • This 38.2 Wh, 7.5 V battery is rated at 5087 mAh—a 9 percent decrease from the 5547 mAh battery in the Surface Pro 3.
      • Despite the smaller battery capacity, the 4 generally outperforms the 3 in terms of battery life.
      • We attribute the majority of this to improved efficiency in the design and size of the processor.
      • Just to compare Apples to oranges, the iPad Air 2 weighs in with a 27.62 Wh battery, however the upcoming iPad Pro is probably a more apt comparison, function-wise. We'll have to wait and see!
      Ask FixBot
    18. Microsoft Surface Pro 4 Teardown: step 18, image 1 of 2 Microsoft Surface Pro 4 Teardown: step 18, image 2 of 2
      • Microsoft Surface Pro 4 Repairability Score: 2 out of 10 (10 is easiest to repair).
      • The SSD is replaceable.
      • The battery is not soldered to the motherboard, but very strong adhesive makes removal and replacement a hazardous chore.
      • Non-standard connectors make for tricky display removal.
      • The display removal procedure, while difficult, and required for any repair, is not as hard as in previous generations, due to less stubborn adhesive.
      • The display assembly consists of a fused glass panel and LCD, and is difficult to remove and replace.
      • Adhesive holds many components in place, including the display and battery.
      Ask FixBot
82 Guide Comments
Looks great, much better than last year's. Pity about the glue for the screen. Would love to see screws. Know it's hard, because these are miracles of engineering, but there are lots of very smart men and women working on this, I'm sure they could find a way, especially since these are billed as enterprise devices, and having worked in an IT department, devices get broken a lot. No pen teardown? I'd imagine it's super similar to last year.
I want one of these even more now. Can't wait to see the Surface Book, if they managed to get one.
Thanks everyone at iFixit, keep up the good work. You're an inspiration to us all.
Is the set of huge connectors on the back of the motherboard in step 14 where the battery connects? They look too large for anything else.
Ian Rasmussen - Reply Share
Glad you liked it! They're tough to get ahold of, but we're definitely gunning for a Surface Book as soon as we can! Those are spring contacts on the reverse of the motherboard, that press against the battery cable and also the keyboard dock connector cable. I updated step 14 to mark them up and explain that, thanks for the reminder!
Andrew Optimus Goldheart - Reply Share
Nice Tear Down!
Step 1 indicates that the Samsung SSD is 128 GB PCIe NVMe solid state storage.
Step 8 indicates that Samsung SSD chip is S4LN058A01 CIe 3.0 x4 AHCI flash controller.
Should the flash controller protocol be NVMe instead of AHCI?!
Alex - Reply Share
Hi,
I am curious about the copper plate over the battery. Is there some insulation against heat radiation to the battery? Does the plate radiate against the lcd (the battery also tells that the temperatures should not be higher then 140°F. Thinking about how they manage this)?
Thank you for the nice teardown (and fast!).
ddink - Reply Share
Hi ddink! The flat plate does diffuse heat into the battery and LCD plate. It actually works as one of two condensers that make up the hybrid cooling system. This article shows a bit more about how that works: http://www.techspot.com/news/62361-surfa...
Past 24 Hours: 31
Past 7 Days: 238
Past 30 Days: 886
All Time: 486,004
