Introduction
Follow this guide to replace the daughterboard (otherwise known as the charging assembly or charging port board) for the Google Pixel XL.
The Pixel XL’s unreinforced display panel is fragile and is attached to the frame with strong adhesive, making repairs difficult. There is a considerable chance of breaking the display, especially if it already has micro-fractures. Be sure to apply plenty of heat and be extremely careful during the prying stage.
Heat an iOpener and apply it to the top edge of the display for two minutes.
Take note of the following regions before you begin prying:
Thin adhesive lined against the display panel
Thick adhesive
The OLED display panel, which is very prone to damage
The display cable, which can be damaged during prying
Once the edge is warm to the touch, apply a suction cup close to the edge.
Lift on the suction cup, and insert an opening pick into the gap.
If you have trouble creating a gap, reheat the edge and try again.
Slide the opening clip across the top edge to slice through the adhesive.
Leave an opening pick in the edge to prevent the adhesive from resealing.
Heat an iOpener and apply it to the right edge of the phone for two minutes.
Insert an opening pick near the top edge of the phone, where you have already sliced the adhesive.
Slowly guide the pick around the right corner.
Carefully slide the pick down the right edge of the phone to slice through the adhesive.
Repeat the step for the left edge of the phone.
Heat the bottom edge with an iOpener for two minutes.
Insert a pick near the right edge where you have already loosened the adhesive.
Carefully guide the pick around the corner.
Slide the pick along the bottom edge to slice through the adhesive.
Once you have sliced around the perimeter of the phone, carefully lift the display assembly up slightly by the right corners.
Use an opening pick to slice through any remaining adhesive.
Lift the display assembly from the top end and swing it around such that it rests upside down on the frame.
Remove the following screws that secure the midframe to the back:
Seven black 4 mm T5 screws
Two silver 3 mm T5 screws
The midframe is held tightly in place by plastic clips which push into the edge of the back case.
Find the small notch in the bottom left corner of the frame and insert an opening pick.
Slide the opening pick along the bottom edge of the phone towards the bottom right corner and leave it there.
Insert a separate opening pick into the right edge of the phone, near the bottom.
Slowly push the pick upwards along the seam until the first clip pops free.
Once you've released the clip, leave the opening pick in place to prevent the midframe from resealing.
Insert an opening pick into the right edge of the phone and slide it upwards towards the top right clip.
Slowly slide the pick past the clip to disengage it from the frame.
Grasp the right edge of the midframe by the corners and slowly hinge the edge up.
When the left edge feels loose, stop hinging and lift the midframe upwards.
Remove the midframe.
Use the point of a spudger to pry up and disconnect the battery connector.
Bend the battery flex cable slightly so that it will not accidentally touch the motherboard.
Use the point of a spudger to pry up and disconnect the interconnect cable from the motherboard.
To reconnect during reinstallation, align the cable with the socket and use your finger to press down on one side, followed by the other. If done correctly, the cable should be firmly held in place by the socket.
Use the point of a spudger to pry up and disconnect the interconnect cable from the bottom daughterboard.
Continue peeling the interconnect cable from the bottom daughterboard.
Remove the interconnect cable.
Use the edge of an opening tool to carefully push the vibration motor connector out of its socket.
Use the flat end of a spudger to pry up and loosen the right edge of the daughterboard.
Swing the daughterboard to the left to move it out of its recess.
Slowly lift the left edge of the daughterboard up, pulling the antenna patch off of the loudspeaker.
You can insert an opening pick under the antenna patch to help separate it from the loudspeaker.
Flip the daughterboard over.
Use the point of a spudger to pry up and disconnect the black antenna cable from its socket.
Release the antenna cable from its retaining clip.
Use the point of a spudger to pry up and disconnect the white antenna cable from its socket.
Use the edge of an opening tool to gently push up and loosen the barometric vent from the board.
You may need to use some adhesive or double-sided tape in order to attach the vent to the new part. If you do, be sure not to cover the bottom vent hole.
