Google Pixel Watch 4 Vibration Motor Replacement
  1. Google Pixel Watch 4 Vibration Motor Replacement, Prepare your watch for disassembly: step 1, image 1 of 3 Google Pixel Watch 4 Vibration Motor Replacement, Prepare your watch for disassembly: step 1, image 2 of 3 Google Pixel Watch 4 Vibration Motor Replacement, Prepare your watch for disassembly: step 1, image 3 of 3
    • Before starting your repair:
    • Remove your watch from the charger.
    • Press and hold the crown button, then tap Power off to shut down your watch.
  2. Google Pixel Watch 4 Vibration Motor Replacement, Remove the watch bands: step 2, image 1 of 3 Google Pixel Watch 4 Vibration Motor Replacement, Remove the watch bands: step 2, image 2 of 3 Google Pixel Watch 4 Vibration Motor Replacement, Remove the watch bands: step 2, image 3 of 3
    • Remove each watch band by depressing the release button and sliding the band out of its groove.
  3. Google Pixel Watch 4 Vibration Motor Replacement: step 3, image 1 of 1
    • Throughout the rest of your repair, consider placing your watch on something soft like a clean cloth to help stabilize it and prevent scratches to the front glass.
  4. Google Pixel Watch 4 Vibration Motor Replacement, Remove the back sensor glass screws: step 4, image 1 of 3 Google Pixel Watch 4 Vibration Motor Replacement, Remove the back sensor glass screws: step 4, image 2 of 3 Google Pixel Watch 4 Vibration Motor Replacement, Remove the back sensor glass screws: step 4, image 3 of 3
    • Use a Torx Plus 2IP screwdriver to remove the 3.0 mm‑long screw from both watch band grooves (two screws total).
    • Both screws have a tiny O‑ring. If they don't lift away with the screw, use a pair of tweezers to carefully remove them from the band groove and set them aside. These O-rings are required to maintain waterproofing.
    • Handle these O-rings carefully. Avoid pinching or slicing them with your tool.
    • During reassembly:
    • Make sure the O‑rings are on the screws before installing them.
    • Push down firmly on the back glass while installing the screws to make sure the glass gets properly seated.
    • If there's a gap between the back glass and frame, remove the screws and reinstall them.
  5. Google Pixel Watch 4 Vibration Motor Replacement, Separate the back sensor glass: step 5, image 1 of 2 Google Pixel Watch 4 Vibration Motor Replacement, Separate the back sensor glass: step 5, image 2 of 2
    • Insert the point of a spudger (or a clean fingernail) into the seam between the back sensor glass and frame and pry up until the cover detaches.
  6. Google Pixel Watch 4 Vibration Motor Replacement, Reposition the back sensor glass: step 6, image 1 of 3 Google Pixel Watch 4 Vibration Motor Replacement, Reposition the back sensor glass: step 6, image 2 of 3 Google Pixel Watch 4 Vibration Motor Replacement, Reposition the back sensor glass: step 6, image 3 of 3
    • Gently lift the back glass and flip it over the side of the watch opposite the crown.
    • Be careful not to strain the cable connecting the back sensor glass.
  7. Google Pixel Watch 4 Vibration Motor Replacement, Remove the vibration motor screws: step 7, image 1 of 2 Google Pixel Watch 4 Vibration Motor Replacement, Remove the vibration motor screws: step 7, image 2 of 2
    • Optionally, you can disconnect the back glass to give you more room to work—though you can complete the repair just fine with it still connected.
    • Use a Torx Plus 2IP screwdriver to remove the two 2.2 mm‑long screws securing the vibration motor.
  8. Google Pixel Watch 4 Vibration Motor Replacement, Remove the vibration motor: step 8, image 1 of 2 Google Pixel Watch 4 Vibration Motor Replacement, Remove the vibration motor: step 8, image 2 of 2
Spencer Day
149,317 Reputation
995 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 12
Past 30 Days: 76
All Time: 160
