Google Pixel Watch 4 Back Sensor Glass Replacement
Views: 1.9K
View statistics:
Past 24 Hours:
8
Past 7 Days:
45
Past 30 Days:
176
All Time:
1,921
Comments: 2
2 comments on steps.
Completed: 3
3 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 15 - 30 minutes
Difficulty: Moderate
Introduction
Go to step 1 ↓
This repair guide was authored by the iFixit staff and hasn’t been endorsed by Google. Learn more about our repair guides here.
Use this guide to replace a cracked, chipped, scratched, or broken back sensor glass (aka Bio Sensor Hub) on your Google Pixel Watch 4.
If the biometric sensors on your watch aren't working, you may need to replace the back sensor glass.
This guide was written using a 41 mm LTE model Pixel Watch 4. While some photos may contain slight visual discrepancies, procedures for all 41 mm and 45 mm models are functionally the same.
Parts
Tools
    1. Google Pixel Watch 4 Back Sensor Glass Replacement, Prepare your watch for disassembly: step 1, image 1 of 3 Google Pixel Watch 4 Back Sensor Glass Replacement, Prepare your watch for disassembly: step 1, image 2 of 3 Google Pixel Watch 4 Back Sensor Glass Replacement, Prepare your watch for disassembly: step 1, image 3 of 3
      • Before starting your repair:
      • Remove your watch from the charger.
      • Press and hold the crown button, then tap Power off to shut down your watch.
      Ask FixBot
    2. Google Pixel Watch 4 Back Sensor Glass Replacement, Remove the watch bands: step 2, image 1 of 3 Google Pixel Watch 4 Back Sensor Glass Replacement, Remove the watch bands: step 2, image 2 of 3 Google Pixel Watch 4 Back Sensor Glass Replacement, Remove the watch bands: step 2, image 3 of 3
      • Remove each watch band by depressing the release button and sliding the band out of its groove.
      Ask FixBot
    3. Google Pixel Watch 4 Back Sensor Glass Replacement: step 3, image 1 of 1
      • Throughout the rest of your repair, consider placing your watch on something soft like a clean cloth to help stabilize it and prevent scratches to the front glass.
      Ask FixBot
    4. Google Pixel Watch 4 Back Sensor Glass Replacement, Remove the back sensor glass screws: step 4, image 1 of 3 Google Pixel Watch 4 Back Sensor Glass Replacement, Remove the back sensor glass screws: step 4, image 2 of 3 Google Pixel Watch 4 Back Sensor Glass Replacement, Remove the back sensor glass screws: step 4, image 3 of 3
      • Use a Torx Plus 2IP screwdriver to remove the 3.0 mm‑long screw from both watch band grooves (two screws total).
      • Both screws have a tiny O‑ring. If they don't lift away with the screw, use a pair of tweezers to carefully remove them from the band groove and set them aside. These O-rings are required to maintain waterproofing.
      • Handle these O-rings carefully. Avoid pinching or slicing them with your tool.
      • During reassembly:
      • Make sure the O‑rings are on the screws before installing them.
      • Push down firmly on the back glass while installing the screws to make sure the glass gets properly seated.
      • If there's a gap between the back glass and frame, remove the screws and reinstall them.
      Ask FixBot
    5. Google Pixel Watch 4 Back Sensor Glass Replacement, Separate the back sensor glass: step 5, image 1 of 2 Google Pixel Watch 4 Back Sensor Glass Replacement, Separate the back sensor glass: step 5, image 2 of 2
      • Insert the point of a spudger (or a clean fingernail) into the seam between the back sensor glass and frame and pry up until the cover detaches.
      Ask FixBot
    6. Google Pixel Watch 4 Back Sensor Glass Replacement, Reposition the back sensor glass: step 6, image 1 of 3 Google Pixel Watch 4 Back Sensor Glass Replacement, Reposition the back sensor glass: step 6, image 2 of 3 Google Pixel Watch 4 Back Sensor Glass Replacement, Reposition the back sensor glass: step 6, image 3 of 3
      • Gently lift the back glass and flip it over the side of the watch opposite the crown.
      • Be careful not to strain the cable connecting the back sensor glass.
      Ask FixBot
    1. Google Pixel Watch 4 Back Sensor Glass Replacement, Disconnect the back sensor glass: step 7, image 1 of 3 Google Pixel Watch 4 Back Sensor Glass Replacement, Disconnect the back sensor glass: step 7, image 2 of 3 Google Pixel Watch 4 Back Sensor Glass Replacement, Disconnect the back sensor glass: step 7, image 3 of 3
      • Use a spudger to lift the small, hinged locking‑flap on the back sensor glass ZIF connector.
      Ask FixBot
    2. Google Pixel Watch 4 Back Sensor Glass Replacement, Remove the back sensor glass: step 8, image 1 of 3 Google Pixel Watch 4 Back Sensor Glass Replacement, Remove the back sensor glass: step 8, image 2 of 3 Google Pixel Watch 4 Back Sensor Glass Replacement, Remove the back sensor glass: step 8, image 3 of 3
      • Gently slide the cable out of its socket and remove the back sensor glass.
      • During reassembly, make sure the locking flap is lifted before sliding the cable fully into its connector—it should snap into place.
      Ask FixBot
3 other people completed this guide.
Spencer Day
207,682 Reputation
1,266 Guides authored
0 Guide Comments
Past 24 Hours: 8
Past 7 Days: 45
Past 30 Days: 176
All Time: 1,921
