Google Pixel 9a Rear Cover Replacement
Views: 3.1K
View statistics:
Past 24 Hours:
7
Past 7 Days:
39
Past 30 Days:
203
All Time:
3,053
Comments: 4
2 comments on steps, 2 guide comments.
Go to guide comments
Completed: 2
2 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 20 - 40 minutes
Difficulty: Moderate
Introduction
Go to step 1 ↓
This repair guide was authored by the iFixit staff and hasn’t been endorsed by Google. Learn more about our repair guides here.
Follow this guide to replace a broken or cracked rear cover on your Google Pixel 9a.
If your back cover is bulging out, it may be a swollen battery. If you suspect it might be, take appropriate precautions.
You'll need replacement rear cover adhesives to complete this repair.
Note: Any repair can compromise the water resistance of your phone. Retaining water resistance after the repair depends on how accurately the new adhesives are applied and how clean the mating surfaces are.
Parts
Tools
    1. Google Pixel 9a Rear Cover Replacement, Safety precautions: step 1, image 1 of 2 Google Pixel 9a Rear Cover Replacement, Safety precautions: step 1, image 2 of 2
      • Let your Pixel's battery drain below 25% before starting this repair. A charged lithium‑ion battery may catch fire if damaged.
      • Unplug all cables and completely power down your phone.
      Ask FixBot
    1. Google Pixel 9a Rear Cover Replacement, Heat the rear cover: step 2, image 1 of 3 Google Pixel 9a Rear Cover Replacement, Heat the rear cover: step 2, image 2 of 3 Google Pixel 9a Rear Cover Replacement, Heat the rear cover: step 2, image 3 of 3
      • Adhesive secures the rear cover to the frame. Heating the cover softens the adhesive, making it easier to separate.
      • Use a hair dryer to heat the entire rear cover.
      • Only heat your phone so it's just hot to the touch. Extreme heat can damage the rear cover, screen, or battery.
      Ask FixBot
    2. Google Pixel 9a Rear Cover Replacement, Apply a suction handle: step 3, image 1 of 2 Google Pixel 9a Rear Cover Replacement, Apply a suction handle: step 3, image 2 of 2
      • Apply a suction handle near the center of the rear cover's right edge, as close to the edge as possible.
      Ask FixBot
    3. Google Pixel 9a Rear Cover Replacement, Insert an opening pick: step 4, image 1 of 3 Google Pixel 9a Rear Cover Replacement, Insert an opening pick: step 4, image 2 of 3 Google Pixel 9a Rear Cover Replacement, Insert an opening pick: step 4, image 3 of 3
      • Pull up on the suction handle with strong, steady force until a gap forms between the cover and frame.
      • Insert the tip of an opening pick into the gap.
      Ask FixBot
    4. Google Pixel 9a Rear Cover Replacement, Adhesive information: step 5, image 1 of 3 Google Pixel 9a Rear Cover Replacement, Adhesive information: step 5, image 2 of 3 Google Pixel 9a Rear Cover Replacement, Adhesive information: step 5, image 3 of 3
      • The rear cover is secured with adhesive around the perimeter of the frame and near the cameras. Use this picture as a reference while you separate the adhesive.
      • When separating the left and right edge adhesive, don't insert your pick more than 3 mm to avoid damaging the wireless charging coil and its graphite film.
      Ask FixBot
    5. Google Pixel 9a Rear Cover Replacement, Separate the rear cover adhesive: step 6, image 1 of 3 Google Pixel 9a Rear Cover Replacement, Separate the rear cover adhesive: step 6, image 2 of 3 Google Pixel 9a Rear Cover Replacement, Separate the rear cover adhesive: step 6, image 3 of 3
      • If you ever have trouble separating the adhesive, apply more heat and try again.
      • Slide the opening pick up the right edge, around the top right corner, and along the top edge to separate the adhesive securing the rear cover.
      Ask FixBot
    6. Google Pixel 9a Rear Cover Replacement: step 7, image 1 of 3 Google Pixel 9a Rear Cover Replacement: step 7, image 2 of 3 Google Pixel 9a Rear Cover Replacement: step 7, image 3 of 3
      • Insert an opening pick in the initial gap you created near the center of the rear cover's right edge.
      • Slide the opening pick down the right edge, along the bottom edge, and up the left edge to separate the adhesive securing the cover.
      Ask FixBot
    7. Google Pixel 9a Rear Cover Replacement, Separate the camera bezel adhesive: step 8, image 1 of 3 Google Pixel 9a Rear Cover Replacement, Separate the camera bezel adhesive: step 8, image 2 of 3 Google Pixel 9a Rear Cover Replacement, Separate the camera bezel adhesive: step 8, image 3 of 3
      • Insert the flat edge of an opening pick under the top of the rear cover's left edge, near the camera bezel.
      • Twist the pick and apply constant pressure to separate the adhesive around the camera bezel.
      Ask FixBot
    8. Google Pixel 9a Rear Cover Replacement, Remove the rear cover: step 9, image 1 of 2 Google Pixel 9a Rear Cover Replacement, Remove the rear cover: step 9, image 2 of 2
      • Remove the rear cover.
      • If you feel resistance, go back around the perimeter of the cover and use a pick to separate any remaining adhesive.
      Ask FixBot
    9. Google Pixel 9a Rear Cover Replacement, Remove the camera bezel: step 10, image 1 of 3 Google Pixel 9a Rear Cover Replacement, Remove the camera bezel: step 10, image 2 of 3 Google Pixel 9a Rear Cover Replacement, Remove the camera bezel: step 10, image 3 of 3
      • If the camera bezel detached from the rear cover and stayed stuck to your phone, follow this step to remove it. Otherwise, skip this step.
      • Slide an opening pick under the camera bezel and pry up to remove it.
      • Only insert the pick a few millimeters under the bezel, or you risk damaging the cameras.
      • If you're having trouble, lightly heat the camera bezel.
      Ask FixBot
    1. Google Pixel 9a Rear Cover Replacement, Disassembly complete: step 11, image 1 of 1
      • Congratulations on completing disassembly! The remaining steps will show how to reassemble your phone.
      Ask FixBot
    1. Google Pixel 9a Rear Cover Replacement, Remove the old adhesive: step 12, image 1 of 3 Google Pixel 9a Rear Cover Replacement, Remove the old adhesive: step 12, image 2 of 3 Google Pixel 9a Rear Cover Replacement, Remove the old adhesive: step 12, image 3 of 3
      • Be very careful not to smudge the rear cameras. If you accidentally do, use a clean cloth to wipe them.
      • Use a spudger to scrape up and remove the six small pieces of adhesive around the rear cameras.
      • Use high‑concentration (>90%) isopropyl alcohol and a lint‑free cloth (or coffee filter) to clean up and remove any residue from the adhesives you just removed.
      Ask FixBot
    2. Google Pixel 9a Rear Cover Replacement, Apply the adhesive: step 13, image 1 of 3 Google Pixel 9a Rear Cover Replacement, Apply the adhesive: step 13, image 2 of 3 Google Pixel 9a Rear Cover Replacement, Apply the adhesive: step 13, image 3 of 3
      • Remove the larger, clear liner from the inner housing adhesive and put it in place.
      • Use the cutouts for the small silver pads to help align the adhesive.
      • Hold the adhesive in place with your fingers and use the flat end of a spudger to firmly push down on each piece of adhesive, securing them in place. The rear cameras can make it tricky to secure the adhesive, so take your time and make sure they're firmly secured.
      • Slowly remove the colored liner using the pull tab on the top edge.
      • If the adhesive starts to pull up with the liner, lay it back in place and use your spudger to secure it again.
      Ask FixBot
    3. Google Pixel 9a Rear Cover Replacement, Secure the adhesive: step 14, image 1 of 3 Google Pixel 9a Rear Cover Replacement, Secure the adhesive: step 14, image 2 of 3 Google Pixel 9a Rear Cover Replacement, Secure the adhesive: step 14, image 3 of 3
      • Use a spudger to firmly press down on each of the six pieces of inner housing adhesive to secure them.
      • These pieces of adhesive can easily be pulled up when removing the final liners, so make sure they're firmly in place.
      Ask FixBot
    1. Google Pixel 9a Rear Cover Replacement, Remove the old rear cover adhesive: step 15, image 1 of 3 Google Pixel 9a Rear Cover Replacement, Remove the old rear cover adhesive: step 15, image 2 of 3 Google Pixel 9a Rear Cover Replacement, Remove the old rear cover adhesive: step 15, image 3 of 3
      • Take your time during the next two steps. A clean frame allows replacement adhesive to lay evenly, ensuring a better bond.
      • When removing the rear cover adhesive during this step, be very careful not to damage the battery or any of the fragile components near the perimeter of the frame.
      • Use a spudger and tweezers to scrape up and remove all the old rear cover adhesive from the perimeter of your phone.
      • If you scrape up a piece big enough to grip with your fingers, you can pull long sections of the adhesive up. Pull slowly and straight in the opposite direction of the adhesive.
      Ask FixBot
    2. Google Pixel 9a Rear Cover Replacement, Clean the frame: step 16, image 1 of 1
      • Using some high-concentration (>90%) isopropyl alcohol and a lint‑free cloth (or coffee filter), clean the areas of the frame where the adhesive was.
      Ask FixBot
    3. Google Pixel 9a Rear Cover Replacement, Find the adhesive orientation: step 17, image 1 of 2 Google Pixel 9a Rear Cover Replacement, Find the adhesive orientation: step 17, image 2 of 2
      • Before applying the rear cover adhesive, make sure you know how it will sit on the frame. If you apply the adhesive incorrectly, you'll need to restart with new adhesive.
      • Hold the adhesive above the frame to find its orientation. Use the camera cutout in the liner to help visualize how it will lay on the frame.
      Ask FixBot
    4. Google Pixel 9a Rear Cover Replacement, Peel the liner halfway down: step 18, image 1 of 1
      • Peel down the top half of the large, clear liner to expose the adhesive—don't fully remove the liner yet.
      Ask FixBot
    5. Google Pixel 9a Rear Cover Replacement, Apply the adhesive: step 19, image 1 of 3 Google Pixel 9a Rear Cover Replacement, Apply the adhesive: step 19, image 2 of 3 Google Pixel 9a Rear Cover Replacement, Apply the adhesive: step 19, image 3 of 3
      • Take your time aligning the adhesive with the frame—it's very sticky and can't be moved once you apply it.
      • With the larger, clear liner folded towards the bottom of the phone, lay the exposed top edge of the adhesive onto the frame.
      • Use the lip of the frame to help align the adhesive.
      • Once the top edge is properly aligned, gently press down on the top corners with your fingers to secure the adhesive.
      Ask FixBot
    6. Google Pixel 9a Rear Cover Replacement: step 20, image 1 of 3 Google Pixel 9a Rear Cover Replacement: step 20, image 2 of 3 Google Pixel 9a Rear Cover Replacement: step 20, image 3 of 3
      • Slowly lay the rest of the adhesive onto the frame, pressing it into place and peeling away the larger liner as you go.
      Ask FixBot
    7. Google Pixel 9a Rear Cover Replacement, Remove the top liner: step 21, image 1 of 3 Google Pixel 9a Rear Cover Replacement, Remove the top liner: step 21, image 2 of 3 Google Pixel 9a Rear Cover Replacement, Remove the top liner: step 21, image 3 of 3
      • Use the pull tab to remove the large, colored liner.
      Ask FixBot
    8. Google Pixel 9a Rear Cover Replacement, Secure the adhesive: step 22, image 1 of 3 Google Pixel 9a Rear Cover Replacement, Secure the adhesive: step 22, image 2 of 3 Google Pixel 9a Rear Cover Replacement, Secure the adhesive: step 22, image 3 of 3
      • Use a spudger to press down firmly on the adhesive around the perimeter of your phone to secure it to the frame.
      Ask FixBot
    1. Google Pixel 9a Rear Cover Replacement, Remove all the rear cover liners: step 23, image 1 of 3 Google Pixel 9a Rear Cover Replacement, Remove all the rear cover liners: step 23, image 2 of 3 Google Pixel 9a Rear Cover Replacement, Remove all the rear cover liners: step 23, image 3 of 3
      • Remove all the remaining plastic liners from the bottom of the rear cover before installing it.
      • Check very carefully on the camera bezel and flash unit cutout! You don't want these to get stuck in front of your camera.
      Ask FixBot
    1. Google Pixel 9a Rear Cover Replacement, Remove the remaining liners: step 24, image 1 of 3 Google Pixel 9a Rear Cover Replacement, Remove the remaining liners: step 24, image 2 of 3 Google Pixel 9a Rear Cover Replacement, Remove the remaining liners: step 24, image 3 of 3
      • Use the point of a spudger to lift and remove the plastic liners from the adhesive around the rear cameras.
      Ask FixBot
    2. Google Pixel 9a Rear Cover Replacement: step 25, image 1 of 2 Google Pixel 9a Rear Cover Replacement: step 25, image 2 of 2
      • Use the pull tabs to remove the final liner from the rear cover adhesive.
      Ask FixBot
    3. Google Pixel 9a Rear Cover Replacement, Install the rear cover: step 26, image 1 of 3 Google Pixel 9a Rear Cover Replacement, Install the rear cover: step 26, image 2 of 3 Google Pixel 9a Rear Cover Replacement, Install the rear cover: step 26, image 3 of 3
      • Align the rear cover over the frame and press it into place.
      Ask FixBot
    4. Google Pixel 9a Rear Cover Replacement: step 27, image 1 of 3 Google Pixel 9a Rear Cover Replacement: step 27, image 2 of 3 Google Pixel 9a Rear Cover Replacement: step 27, image 3 of 3
      Ask FixBot
Congratulations on completing your repair!
To run a diagnostics test with the built-in Pixel Diagnostic tool, click here.
2 other people completed this guide.
Spencer Day
206,621 Reputation
1,266 Guides authored
iFixit Member of iFixit
Staff
121 Members
72,885 Guides authored
2 Guide Comments
The bezel on my 9a is cracked. Does this kit (Google Pixel 9a Rear Cover ‑ Genuine) include a bezel?
Artemis - Reply Share
it does not include a bezel, just the rear cover and camera glass
Colby Eckert - Reply Share
Past 24 Hours: 7
Past 7 Days: 39
Past 30 Days: 203
All Time: 3,053
