Introduction
Follow this guide to remove or replace the glass back cover for the Pixel 3. This procedure is necessary to access the Pixel’s internals.
Heat an iOpener and apply it to the bottom of the back of the phone for one minute.
When prying above the power button, be careful not to insert the pick too deeply, or you will damage the fingerprint sensor cable.
Apply a suction cup to the heated bottom edge of the back cover.
Lift on the suction cup with strong, steady force to create a gap.
Insert an opening pick into the gap.
Slice the adhesive along the bottom edge of the phone and around the right corner.
Leave a pick in the bottom edge to prevent the adhesive from re-sealing.
Continue heating and slicing through the rest of the phone perimeter. Leave a pick in each edge to prevent the adhesive from resealing.
When slicing above the power button, do not insert the pick more than halfway in to avoid damaging the fingerprint sensor cable.
Once you have sliced around the perimeter of the phone, carefully lift the left edge of the back cover.
Flip the back cover along its long axis and rest it so that the fingerprint sensor cable is not strained.
Use the point of a spudger to slide the fingerprint connector bracket out from under the NFC coil.
Remove the fingerprint connector bracket.
Use the point of a spudger to pry up and disconnect the fingerprint connector from its socket.
