At the top of the outer frame, insert the plastic spudger into the groove in the center.
Lever the frame gently until it pops out of the case.
To remove the ribbon cable, lift the black latch using the spudger tool.
Separate the connection using either your fingers, tweezers, or the spudger.
Slide the spudger tool under the first flexible tab located on the right side of the bottom of the screen.
The tab is denoted by a red box in the photo.
There are two tabs at the top of the screen that are not flexible
Rotate the spudger outward until the tab is no longer holding the screen.
Push the screen out from the front.
Find the second flexible tab near the screen's wires and slide the spudger tool under tab.
Rotate the spudger tool outward until the tab is no longer holding the screen.
Have your new screen ready to insert, making sure it is fully unwrapped.
Find the tabs used to secure the screen as highlighted in the photo.
Slide the bottom of the screen under the permanent tabs.
The permanent tabs are denoted by blue boxes in the photo.
Use the spudger tool to raise the flexible tabs in order to reinsert the screen completely into the front cover.
Reinsert the ribbon cable into the slot you removed it from.
Lower the black latch using the spudger tool.
Screw the front panel back onto the base using the four screws you removed in step 2.
Use the black screws.
