Garmin StreetPilot c330 Screen Replacement
    1. Garmin StreetPilot c330 Screen Replacement, Outer Casing: step 1, image 1 of 3 Garmin StreetPilot c330 Screen Replacement, Outer Casing: step 1, image 2 of 3 Garmin StreetPilot c330 Screen Replacement, Outer Casing: step 1, image 3 of 3
      • At the top of the outer frame, insert the plastic spudger into the groove in the center.
      • Lever the frame gently until it pops out of the case.
      Ask FixBot
    2. Garmin StreetPilot c330 Screen Replacement: step 2, image 1 of 3 Garmin StreetPilot c330 Screen Replacement: step 2, image 2 of 3 Garmin StreetPilot c330 Screen Replacement: step 2, image 3 of 3
      • Use a Phillips #00 screwdriver to remove the four screws around the screen.
      Ask FixBot
    3. Garmin StreetPilot c330 Screen Replacement: step 3, image 1 of 2 Garmin StreetPilot c330 Screen Replacement: step 3, image 2 of 2
      • Gently pull from both ends of the casing to separate the front and back panels.
      • Do not force the pieces apart wider than the length of the connecting wires, or you will damage the wiring.
      Ask FixBot
    4. Garmin StreetPilot c330 Screen Replacement: step 4, image 1 of 3 Garmin StreetPilot c330 Screen Replacement: step 4, image 2 of 3 Garmin StreetPilot c330 Screen Replacement: step 4, image 3 of 3
      Tool used on this step:
      Buy
      • Gently unplug the white cable connector using either your fingers or tweezers.
      Ask FixBot
    5. Garmin StreetPilot c330 Screen Replacement: step 5, image 1 of 1
      • Carefully expose both halves of the device.
      • Be sure not to pull the two halves apart further than the black wire can reach.
      Ask FixBot
    1. Garmin StreetPilot c330 Screen Replacement, Screen: step 6, image 1 of 3 Garmin StreetPilot c330 Screen Replacement, Screen: step 6, image 2 of 3 Garmin StreetPilot c330 Screen Replacement, Screen: step 6, image 3 of 3
      • Remove the three screws holding the motherboard in place.
      Ask FixBot
    2. Garmin StreetPilot c330 Screen Replacement: step 7, image 1 of 1
      • Use the spudger to lift up the motherboard.
      Ask FixBot
    3. Garmin StreetPilot c330 Screen Replacement: step 8, image 1 of 3 Garmin StreetPilot c330 Screen Replacement: step 8, image 2 of 3 Garmin StreetPilot c330 Screen Replacement: step 8, image 3 of 3
      Buy
      • To remove the ribbon cable, lift the black latch using the spudger tool.
      • Separate the connection using either your fingers, tweezers, or the spudger.
      Ask FixBot
    4. Garmin StreetPilot c330 Screen Replacement: step 9, image 1 of 2 Garmin StreetPilot c330 Screen Replacement: step 9, image 2 of 2
      • Slide the spudger under the two flexible tabs located on the right and left sides of the bottom of the screen.
      • Rotate the spudger outward until the tabs are no longer holding the screen.
      • When reassembling, slide the bottom of the screen under the two permanent tabs.
      • Push the screen out from the front.
      Ask FixBot
    5. Garmin StreetPilot c330 Screen Replacement: step 10, image 1 of 1
      • Separate the screen from the front cover.
      Ask FixBot
Adrian Leon
173 Reputation
3 Guides authored
Cal Poly, Team 22-1, Maness Fall 2010 Member of Cal Poly, Team 22-1, Maness Fall 2010
CPSU-MANESS-F10S22G1
3 Members
48 Guides authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 20
Past 30 Days: 105
All Time: 1,985
