GameSir Cyclone 2 Battery Replacement
    1. GameSir Cyclone 2 Battery Replacement, Face Plate: step 1, image 1 of 3 GameSir Cyclone 2 Battery Replacement, Face Plate: step 1, image 2 of 3 GameSir Cyclone 2 Battery Replacement, Face Plate: step 1, image 3 of 3
      • Flip the controller around so the back part is facing you.
      • Use a T6 Torx screwdriver to remove seven screws from the back of the controller.
      • One of the screws is hidden under the sticker. Use a pair of tweezers to lift the sticker and reveal the screw.
      Ask FixBot
    2. GameSir Cyclone 2 Battery Replacement: step 2, image 1 of 1
      • The screws holding the face plate are of two different lengths:
      • The two longer screws belong to the two top screw sockets on the controller.
      • The five shorter screws belong in the five bottom screw sockets, two per handle, and on in the center of on the controller.
      Ask FixBot
    3. GameSir Cyclone 2 Battery Replacement: step 3, image 1 of 2 GameSir Cyclone 2 Battery Replacement: step 3, image 2 of 2
      • Face the controller toward you.
      • Gently lift the face plate off the controller.
      • The d-pad and action buttons will become loose once the face plate is lifted.
      Ask FixBot
    1. GameSir Cyclone 2 Battery Replacement, Joystick Covers: step 4, image 1 of 3 GameSir Cyclone 2 Battery Replacement, Joystick Covers: step 4, image 2 of 3 GameSir Cyclone 2 Battery Replacement, Joystick Covers: step 4, image 3 of 3
      • Pull both joystick covers straight up to remove them from the controller.
      Ask FixBot
    1. GameSir Cyclone 2 Battery Replacement, Left and Right Bumpers and Triggers: step 5, image 1 of 1
      • Note the bumpers and triggers on the controller.
      Ask FixBot
    2. GameSir Cyclone 2 Battery Replacement: step 6, image 1 of 1
      • Use a Phillips #00 screwdriver to remove two screws on either side of the power button.
      • Remove the assembly that includes the power button and the top bumper buttons.
      Ask FixBot
    3. GameSir Cyclone 2 Battery Replacement: step 7, image 1 of 1
      • Remove the bumpers and triggers from the controller.
      Ask FixBot
    1. GameSir Cyclone 2 Battery Replacement, LED: step 8, image 1 of 1
      • Locate the two black boxes towards the bottom of the controller.
      • Remove these two boxes by pulling them away from the controller. They should snap right off.
      Ask FixBot
    2. GameSir Cyclone 2 Battery Replacement: step 9, image 1 of 1
      • Locate the LED diffusers on either side of the controller face. They are clear, cylindrical strips that help spread light from the LED beneath the black boxes removed in the previous step.
      • Lift the upper ends of each LED diffuser and remove them.
      Ask FixBot
    1. GameSir Cyclone 2 Battery Replacement, Battery: step 10, image 1 of 1
      • Use a Phillips #00 screwdriver to remove the four screws that secure the LED diffuser tracks.
      • Remove the LED diffuser tracks.
      Ask FixBot
    2. GameSir Cyclone 2 Battery Replacement: step 11, image 1 of 1
      • Use a Phillips #00 screwdriver to remove the single screw in the center of the motherboard.
      • Remove the motherboard from the controller case.
      Ask FixBot
    3. GameSir Cyclone 2 Battery Replacement: step 12, image 1 of 2 GameSir Cyclone 2 Battery Replacement: step 12, image 2 of 2
      • Disconnect the battery connector from the socket on the motherboard.
      • Remove the battery.
      Ask FixBot
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
JasmineM
373 Reputation
4 Guides authored
UMass Dartmouth, Team 2-6, Bowman Fall 2025 Member of UMass Dartmouth, Team 2-6, Bowman Fall 2025
UMASSD-BOWMAN-F25S2G6
4 Members
77 Guides authored
4 Guide Comments
Which battery is used there. I mean the specs so I can buy it.
Davi Ribeiro - Reply Share
Hi @daviribeiro, we don't have the specific battery details, but it uses a 860mAh rechargeable Lithium-ion battery.
Sarah Westberg - Reply Share
¡Gracias por compartir las instrucciones detalladas para reemplazar la batería del GameSir Cyclone 2! La información es muy útil, especialmente para jugadores como yo. ¿Sabes cómo guardar correctamente la batería después de reemplazarla para prolongar su vida útil?
Gerald Warren - Reply Share
@geraldwarren Hi!
There exist a lot of different tips in battery hygiene, the most effective tip is to not let the battery discharge "below" 0%, as that can damage the battery, and in extension, make sure that there is always some charge on the battery. This usually comes more into effect when a battery sits unused for a long period of time, as batteries will naturally discharge over time. But batteries will always eventually need to be replaced.
[El siguiente texto ha sido traducido automáticamente al español desde el inglés, pueden producirse inexactitudes]
¡Hola!
Hay muchos consejos sobre el cuidado de la batería. El más eficaz es no dejar que la batería se descargue "por debajo" del 0%, ya que eso puede dañarla, y asegurarse de que siempre haya algo de carga en la batería. Esto suele ser más importante cuando una batería permanece sin usarse durante un largo período de tiempo, ya que las baterías se descargan de forma natural con el paso del tiempo.
Pero las baterías siempre terminarán necesitando ser reemplazadas.
MeekVixen - Reply Share
Past 24 Hours: 17
Past 7 Days: 64
Past 30 Days: 320
All Time: 1,756
