Introduction
Use this guide to replace the Bezel in your Framework Laptop 13 Pro.
Slide your fingernail under the inside edge of either bottom corner of the Bezel.
Pull the Bezel away from the screen to release the first few magnets.
Before continuing, check if cables next to the hinges are routed properly:
The Display Cable should be routed just above the hinge without any large gaps.
The Display Cable should be routed between the metal clips.
The Webcam Cable should be routed just above the hinge without any large gaps and shouldn't overlap with the antenna cables.
Align the bottom edge of the Bezel with the top edge of the Input Cover and press down so the Bezel covers the hinges and cables.
Lay the rest of the Bezel over the screen and let the magnets pull it into place.
If there are any plastic liners covering the webcam and microphone, remove them.
You finished fixing your Framework Laptop!
If you need help, contact Framework support.
