Framework Laptop 12 Touchpad Replacement
Views: 1K
View statistics:
Past 24 Hours:
2
Past 7 Days:
17
Past 30 Days:
71
All Time:
1,006
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 15 - 45 minutes
Difficulty: Moderate
OEM Guide
iFixit collaborated with the manufacturer to make this guide.
Introduction
Go to step 1 ↓
Follow this guide to remove and replace a damaged touchpad in your Framework Laptop 12.
If your touchpad isn't registering gestures or taps, and you've troubleshooted the software side of things, you may need to replace the touchpad. The touchpad is part of the Input Cover, but can be replaced independently of it.
The replacement touchpad arrives with a blue plastic alignment tool pre-installed on it. Don't peel this off until you're instructed to in the procedure.
You'll encounter some component terms in this guide:
  • The Input Cover is the part that contains the keyboard and touchpad.
    1. Framework Laptop 12 Touchpad Replacement, Power down your laptop: step 1, image 1 of 3 Framework Laptop 12 Touchpad Replacement, Power down your laptop: step 1, image 2 of 3 Framework Laptop 12 Touchpad Replacement, Power down your laptop: step 1, image 3 of 3
      • Before you begin repairs, unplug your laptop and shut it down from the operating system. This ensures that the laptop isn't in standby/suspend mode.
      • The indicator LEDs along the edges should be unlit. The laptop should be silent.
      • If you accidentally turn on the laptop during repair, hold the power button down for 10 seconds to shut it down.
      • Make sure your Framework Screwdriver has the T5 Torx bit (labeled as T-5) facing outwards. If it's not, pull the bit out and flip it.
      Ask FixBot
    1. Framework Laptop 12 Touchpad Replacement, Set your laptop down: step 2, image 1 of 1
      • Set your Framework Laptop face-down on a clean work surface.
      Ask FixBot
    2. Framework Laptop 12 Touchpad Replacement, Loosen the bottom screws: step 3, image 1 of 2 Framework Laptop 12 Touchpad Replacement, Loosen the bottom screws: step 3, image 2 of 2
      • Use your Framework Screwdriver to fully loosen the eight captive T5 Torx screws on the bottom of your laptop.
      • Most screws in your Framework Laptop (including these) are captive—they're designed to stay in place after you loosen them.
      Ask FixBot
    3. Framework Laptop 12 Touchpad Replacement, Flip your laptop over: step 4, image 1 of 1
      • Flip your laptop over so it's face-up on your work surface.
      Ask FixBot
    4. Framework Laptop 12 Touchpad Replacement, Open your laptop: step 5, image 1 of 2 Framework Laptop 12 Touchpad Replacement, Open your laptop: step 5, image 2 of 2
      • Open the laptop lid so that both the screen and the base lie flat on your work surface.
      Ask FixBot
    5. Framework Laptop 12 Touchpad Replacement, Remove the Input Cover: step 6, image 1 of 3 Framework Laptop 12 Touchpad Replacement, Remove the Input Cover: step 6, image 2 of 3 Framework Laptop 12 Touchpad Replacement, Remove the Input Cover: step 6, image 3 of 3
      • Use your fingers to grip the Input Cover in the hinge cutouts.
      • Lift upwards to swing the Input Cover up from the base of the laptop.
      • Magnets hold the Input Cover down, so you'll feel some resistance. If it feels stuck, check that you've fully loosened all the screws on the bottom of your laptop.
      • Remove the Input Cover.
      Ask FixBot
    1. Framework Laptop 12 Touchpad Replacement, Disconnect the touchpad: step 7, image 1 of 3 Framework Laptop 12 Touchpad Replacement, Disconnect the touchpad: step 7, image 2 of 3 Framework Laptop 12 Touchpad Replacement, Disconnect the touchpad: step 7, image 3 of 3
      • Use the flat end of your Framework Screwdriver or a fingernail to gently pry up the black locking tab on the touchpad cable ZIF connector, located on the back of the touchpad.
      Ask FixBot
    2. Framework Laptop 12 Touchpad Replacement: step 8, image 1 of 2 Framework Laptop 12 Touchpad Replacement: step 8, image 2 of 2
      • Grab the touchpad cable by the brown tab and slide it out of its connector.
      Ask FixBot
    3. Framework Laptop 12 Touchpad Replacement: step 9, image 1 of 3 Framework Laptop 12 Touchpad Replacement: step 9, image 2 of 3 Framework Laptop 12 Touchpad Replacement: step 9, image 3 of 3
      • Use the flat end of your Framework Screwdriver or a fingernail to gently pry up the black locking tab on the keyboard cable ZIF connector, located on the back of the touchpad.
      Ask FixBot
    4. Framework Laptop 12 Touchpad Replacement: step 10, image 1 of 2 Framework Laptop 12 Touchpad Replacement: step 10, image 2 of 2
      • Grab the keyboard cable by the blue tab and slide it out of its connector.
      Ask FixBot
    5. Framework Laptop 12 Touchpad Replacement, Disconnect the keyboard backlight (if present): step 11, image 1 of 3 Framework Laptop 12 Touchpad Replacement, Disconnect the keyboard backlight (if present): step 11, image 2 of 3 Framework Laptop 12 Touchpad Replacement, Disconnect the keyboard backlight (if present): step 11, image 3 of 3
      • If your Framework Laptop 12 doesn't have a backlit keyboard, skip this step.
      • Use the flat end of your Framework Screwdriver or a fingernail to gently pry up the black locking tab on the keyboard backlight cable ZIF connector, located on the back of the touchpad.
      • Grab the keyboard backlight cable by the brown tab and slide it out of its connector.
      Ask FixBot
    6. Framework Laptop 12 Touchpad Replacement, Remove the touchpad screws: step 12, image 1 of 2 Framework Laptop 12 Touchpad Replacement, Remove the touchpad screws: step 12, image 2 of 2
      • Use your Framework Screwdriver to remove the seven 2.1 mm‑long T5 Torx screws securing the touchpad.
      • If your replacement touchpad comes with screws, you don't need to keep these for reassembly.
      Ask FixBot
    7. Framework Laptop 12 Touchpad Replacement, Remove the touchpad: step 13, image 1 of 3 Framework Laptop 12 Touchpad Replacement, Remove the touchpad: step 13, image 2 of 3 Framework Laptop 12 Touchpad Replacement, Remove the touchpad: step 13, image 3 of 3
      • Use your fingers to pop the touchpad out of the Input Cover from the underside.
      • Lift and remove the touchpad.
      Ask FixBot
    1. Framework Laptop 12 Touchpad Replacement, Disassembly complete: step 14, image 1 of 1
      • Congratulations on completing disassembly! The remaining steps will show how to reassemble your Framework Laptop.
      Ask FixBot
    1. Framework Laptop 12 Touchpad Replacement, Align the replacement touchpad: step 15, image 1 of 1
      • The replacement touchpad comes with a blue plastic alignment tool pre-installed. Don't remove this from the touchpad yet.
      • Make sure the small tabs around the alignment tool are folded down around the touchpad. Use your fingers to fold them down if they're not.
      Ask FixBot
    2. Framework Laptop 12 Touchpad Replacement: step 16, image 1 of 2 Framework Laptop 12 Touchpad Replacement: step 16, image 2 of 2
      • Lay the touchpad into its Input Cover recess.
      • The tabs on the alignment tool will center the touchpad on the Input Cover.
      Ask FixBot
    3. Framework Laptop 12 Touchpad Replacement, Install the touchpad screws: step 17, image 1 of 2 Framework Laptop 12 Touchpad Replacement, Install the touchpad screws: step 17, image 2 of 2
      • Use your Framework Screwdriver to install the seven 2.1 mm‑long T5 Torx screws to secure the touchpad.
      • If you didn't use an alignment tool, manually center the touchpad to the Input Cover before tightening the screws.
      • Tighten the screws until they're snug. Don't over-tighten them, or you may strip the screws.
      Ask FixBot
    4. Framework Laptop 12 Touchpad Replacement, Connect the touchpad cables: step 18, image 1 of 3 Framework Laptop 12 Touchpad Replacement, Connect the touchpad cables: step 18, image 2 of 3 Framework Laptop 12 Touchpad Replacement, Connect the touchpad cables: step 18, image 3 of 3
      • Slide the keyboard ZIF cable into its connector, up to the printed line on the cable.
      • Use your finger to flip down and gently press the locking tab in place.
      Ask FixBot
    5. Framework Laptop 12 Touchpad Replacement: step 19, image 1 of 3 Framework Laptop 12 Touchpad Replacement: step 19, image 2 of 3 Framework Laptop 12 Touchpad Replacement: step 19, image 3 of 3
      • Slide the touchpad ZIF cable into its connector, up to the printed line on the cable.
      Ask FixBot
    6. Framework Laptop 12 Touchpad Replacement: step 20, image 1 of 3 Framework Laptop 12 Touchpad Replacement: step 20, image 2 of 3 Framework Laptop 12 Touchpad Replacement: step 20, image 3 of 3
      • If your keyboard doesn't have a backlight, skip this step.
      • Slide the keyboard backlight ZIF cable into its connector, up to the printed line on the cable.
      Ask FixBot
    7. Framework Laptop 12 Touchpad Replacement, Remove the alignment tool: step 21, image 1 of 2 Framework Laptop 12 Touchpad Replacement, Remove the alignment tool: step 21, image 2 of 2
      • Skip this step if you didn't use an alignment tool.
      • Use your fingers to peel and remove the alignment tool from the touchpad.
      Ask FixBot
    1. Framework Laptop 12 Touchpad Replacement, Install the Input Cover: step 22, image 1 of 3 Framework Laptop 12 Touchpad Replacement, Install the Input Cover: step 22, image 2 of 3 Framework Laptop 12 Touchpad Replacement, Install the Input Cover: step 22, image 3 of 3
      • Angle the bottom edge of the Input Cover towards the base of the laptop.
      • Align and insert the bottom edge of the Input Cover into the base of the laptop.
      • Make sure the slots along the bottom edge of the Input Cover slide into the tabs in the base.
      • Lower the Input Cover's top edge onto the laptop until the magnets snap it in place.
      • Make sure the Input Cover sits neatly within the laptop frame and no corners are popping up.
      Ask FixBot
    2. Framework Laptop 12 Touchpad Replacement, Close and flip your laptop: step 23, image 1 of 2 Framework Laptop 12 Touchpad Replacement, Close and flip your laptop: step 23, image 2 of 2
      • Close the laptop lid.
      • Flip your laptop face-down on a clean work surface.
      Ask FixBot
    3. Framework Laptop 12 Touchpad Replacement, Tighten the bottom screws: step 24, image 1 of 2 Framework Laptop 12 Touchpad Replacement, Tighten the bottom screws: step 24, image 2 of 2
      • Use your Framework Screwdriver to tighten the eight captive T5 Torx screws on the bottom of your laptop.
      Ask FixBot
You finished fixing your Framework Laptop!
If you need help, contact Framework support.
Arthur Shi
352,072 Reputation
937 Guides authored
Guide Team Member of Guide Team
Staff
10 Members
62,178 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 17
Past 30 Days: 71
All Time: 1,006
