Framework Laptop 12 Memory Module Replacement
Views: 1.1K
View statistics:
Past 24 Hours:
4
Past 7 Days:
19
Past 30 Days:
73
All Time:
1,059
Comments: 0
Go to guide comments
Completed: 2
2 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 5 - 15 minutes
Difficulty: Easy
OEM Guide
iFixit collaborated with the manufacturer to make this guide.
Introduction
Go to step 1 ↓
Follow this guide to replace or upgrade the memory module (aka RAM) in your Framework Laptop 12.
If you're bringing your own memory, the SO‑DIMM memory slot supports up to 64 GB of DDR5 memory at DDR5‑6400 speed (Intel Core Series 3) or 48 GB of DDR5 memory at DDR5‑5200 speed (Intel Core 13th Gen). If you install memory faster than the supported speed, the laptop will work properly, but not use the full memory speed.
Click below for a list of validated memory modules:
You'll encounter some component terms in this guide:
  • The Input Cover is the piece that contains the keyboard and trackpad.
    1. Framework Laptop 12 Memory Module Replacement, Power down your laptop: step 1, image 1 of 3 Framework Laptop 12 Memory Module Replacement, Power down your laptop: step 1, image 2 of 3 Framework Laptop 12 Memory Module Replacement, Power down your laptop: step 1, image 3 of 3
      • Before you begin repairs, unplug your laptop and shut it down from the operating system. This ensures that the laptop isn't in standby/suspend mode.
      • The indicator LEDs along the edges should be unlit. The laptop should be silent.
      • If you accidentally turn on the laptop during repair, hold the power button down for 10 seconds to shut it down.
      • Make sure your Framework Screwdriver has the T5 Torx bit (labeled as T-5) facing outwards. If it's not, pull the bit out and flip it.
      Ask FixBot
    1. Framework Laptop 12 Memory Module Replacement, Set your laptop down: step 2, image 1 of 1
      • Set your Framework Laptop face-down on a clean work surface.
      Ask FixBot
    2. Framework Laptop 12 Memory Module Replacement, Loosen the bottom screws: step 3, image 1 of 2 Framework Laptop 12 Memory Module Replacement, Loosen the bottom screws: step 3, image 2 of 2
      • Use your Framework Screwdriver to fully loosen the eight captive T5 Torx screws on the bottom of your laptop.
      • Most screws in your Framework Laptop (including these) are captive—they're designed to stay in place after you loosen them.
      Ask FixBot
    3. Framework Laptop 12 Memory Module Replacement, Flip your laptop over: step 4, image 1 of 1
      • Flip your laptop over so it's face-up on your work surface.
      Ask FixBot
    4. Framework Laptop 12 Memory Module Replacement, Open your laptop: step 5, image 1 of 2 Framework Laptop 12 Memory Module Replacement, Open your laptop: step 5, image 2 of 2
      • Open the laptop lid so that both the screen and the base lie flat on your work surface.
      Ask FixBot
    5. Framework Laptop 12 Memory Module Replacement, Remove the Input Cover: step 6, image 1 of 3 Framework Laptop 12 Memory Module Replacement, Remove the Input Cover: step 6, image 2 of 3 Framework Laptop 12 Memory Module Replacement, Remove the Input Cover: step 6, image 3 of 3
      • Use your fingers to grip the Input Cover in the hinge cutouts.
      • Lift upwards to swing the Input Cover up from the base of the laptop.
      • Magnets hold the Input Cover down, so you'll feel some resistance. If it feels stuck, check that you've fully loosened all the screws on the bottom of your laptop.
      • Remove the Input Cover.
      Ask FixBot
    1. Framework Laptop 12 Memory Module Replacement, Open the memory flap: step 7, image 1 of 2 Framework Laptop 12 Memory Module Replacement, Open the memory flap: step 7, image 2 of 2
      • Use your fingers to flip open the memory flap.
      Ask FixBot
    2. Framework Laptop 12 Memory Module Replacement, Remove the memory module: step 8, image 1 of 2 Framework Laptop 12 Memory Module Replacement, Remove the memory module: step 8, image 2 of 2
      • Use your fingers to spread the clips on both sides of the memory module apart to unclip the memory.
      • The memory module will pop up to an angle when it's unclipped.
      Ask FixBot
    3. Framework Laptop 12 Memory Module Replacement: step 9, image 1 of 2 Framework Laptop 12 Memory Module Replacement: step 9, image 2 of 2
      • Use your fingers to grab the memory module by its edges.
      • Slide the memory module out of its socket and remove it.
      Ask FixBot
    1. Framework Laptop 12 Memory Module Replacement, Disassembly complete: step 10, image 1 of 1
      • Congratulations on completing disassembly! The remaining steps will show how to reassemble your Framework Laptop.
      Ask FixBot
    1. Framework Laptop 12 Memory Module Replacement, Install the memory module: step 11, image 1 of 3 Framework Laptop 12 Memory Module Replacement, Install the memory module: step 11, image 2 of 3 Framework Laptop 12 Memory Module Replacement, Install the memory module: step 11, image 3 of 3
      • Hold the memory module by its edges. Don't touch the gold contacts with your fingers. If you do, wipe the contacts with a clean, lint-free cloth to remove any finger oils.
      • Align the notch on the memory module with the ridge in the socket.
      • Insert the contact edge into the socket at a shallow angle. The gold contacts should mostly be covered by the socket.
      • Intel Core Series 3 Mainboards have the RAM flipped compared to these images. The shorter side of connectors will be on the left.
      • Press the edges of the memory module down until the side clips lock it in place.
      Ask FixBot
    2. Framework Laptop 12 Memory Module Replacement: step 12, image 1 of 2 Framework Laptop 12 Memory Module Replacement: step 12, image 2 of 2
      • Flip the memory flap back over the memory module.
      Ask FixBot
    1. Framework Laptop 12 Memory Module Replacement, Install the Input Cover: step 13, image 1 of 3 Framework Laptop 12 Memory Module Replacement, Install the Input Cover: step 13, image 2 of 3 Framework Laptop 12 Memory Module Replacement, Install the Input Cover: step 13, image 3 of 3
      • Angle the bottom edge of the Input Cover towards the base of the laptop.
      • Align and insert the bottom edge of the Input Cover into the base of the laptop.
      • Make sure the slots along the bottom edge of the Input Cover slide into the tabs in the base.
      • Lower the Input Cover's top edge onto the laptop until the magnets snap it in place.
      • Make sure the Input Cover sits neatly within the laptop frame and no corners are popping up.
      Ask FixBot
    2. Framework Laptop 12 Memory Module Replacement, Close and flip your laptop: step 14, image 1 of 2 Framework Laptop 12 Memory Module Replacement, Close and flip your laptop: step 14, image 2 of 2
      • Close the laptop lid.
      • Flip your laptop face-down on a clean work surface.
      Ask FixBot
    3. Framework Laptop 12 Memory Module Replacement, Tighten the bottom screws: step 15, image 1 of 2 Framework Laptop 12 Memory Module Replacement, Tighten the bottom screws: step 15, image 2 of 2
      • Use your Framework Screwdriver to tighten the eight captive T5 Torx screws on the bottom of your laptop.
      • Tighten the screws until they're snug. Don't over-tighten them, or you may strip the screws.
      Ask FixBot
You finished fixing your Framework Laptop!
After installing new memory, the laptop will take longer to start up for the first time, and the screen will turn on slower. This is normal—the system is performing memory training.
If you need help, contact Framework support.
2 other people completed this guide.
Arthur Shi
352,069 Reputation
937 Guides authored
Guide Team Member of Guide Team
Staff
10 Members
62,178 Guides authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 19
Past 30 Days: 73
All Time: 1,059
