OEM Guide
iFixit collaborated with the manufacturer to make this guide.
Introduction
Go to step 1 ↓Follow this guide to remove and replace the display in your Framework Laptop 12.
The display (aka display panel or screen) is the LCD panel in your laptop. The display also has the touchscreen and stylus functionality built into the part. If you crack your display or if the touchscreen doesn't work, you may need to replace this part.
You'll encounter some component terms in this guide:
- The Display Cover is the plastic bezel strip below the display.
- The Top Cover is the plastic shell that houses the display.
Before you begin repairs, unplug your laptop and shut it down from the operating system. This ensures that the laptop isn't in standby/suspend mode.
Make sure your Framework Screwdriver has the T5 Torx bit (labeled as T-5) facing outwards. If it's not, pull the bit out and flip it.
Open the laptop lid so that both the screen and the base lie flat on your work surface.
Use the flat end of your Framework Screwdriver to pry up the right edge of the Display Cover.
Use your Framework Screwdriver to remove the four 3.3 mm‑long T5 Torx screws securing the display to the Top Cover.
Insert the bit end of your Framework Screwdriver into the small hole on the display, below the Framework logo.
Slide the display down towards the hinge edge to release the tabs holding the top edge of the display in place.
Use your fingers to lift the top edge of the display from the Top Cover.
Use your fingers to carefully swing the display over so it lies on top of the keyboard.
Use your Framework Screwdriver to remove the two 3.3 mm‑long T5 Torx screws securing the webcam bracket on the top edge behind the display.
Use the flat end of your Framework Screwdriver to lift the webcam out of its recess.
Flip the webcam over and gently hold it down with your fingers.
Use the flat end of your Framework Screwdriver or a fingernail to gently pry up the locking tab on the webcam cable ZIF connector.
Grab the webcam cable with your fingers and slowly peel it away from the display.
Carefully move the cable off of the display.
Use the flat end of your Framework Screwdriver or a fingernail to gently pry up the locking tab on the touch control ZIF connector near the hinge edge of the display.
Use your fingers to grab the touch control cable by the blue tab and slide the cable out of the connector.
Slide the flat end of your Framework Screwdriver under the grounding tape securing the display cable.
Lift slowly to separate the tape from the display.
Slide the flat end of your Framework Screwdriver under the length of the display cable to separate it from the display.
Use your fingers to peel up the clear tab covering the display cable connector.
Inspect the replacement display and carefully peel off any protective liners.
Use your Framework Screwdriver to remove the two 3.3 mm‑long T5 Torx screws securing the webcam bracket on the replacement display.
Remove the webcam bracket.
Remove any protective liners that may be in the webcam recess. The liners are normally clear or colored plastic films that easily detach.
Carefully lay the display screen-side down on top of the Input Cover. The edge with the webcam should lay near the touchpad edge.
Use your fingers to slide the display off the Input Cover magnets towards the hinge edge so that the display cable can reach its connector.
Bend an inch (2.5Â cm) of the webcam cable over so that the shiny side is facing you.
Slide the webcam cable into the ZIF connector up to the printed line on the cable.
Use your finger to flip down and gently press the locking tab in place.
Use your fingers to carefully swing the display over so it lies on top of the Top Cover.
Align the display in the Top Cover such that the top edge of the display is slightly below the top edge of the Top Cover.
Use your fingers to slide the display upwards to latch the tabs on the top edge of the display.
Use your Framework Screwdriver to install the four 3.3 mm‑long T5 Torx screws to secure the display to the Top Cover.
You finished fixing your Framework Laptop!
If you need help, contact Framework support.
