Shop the Holiday Gift Guide
Framework Laptop 12 Battery Replacement
Views: 1.3K
View statistics:
Past 24 Hours:
9
Past 7 Days:
27
Past 30 Days:
105
All Time:
1,341
Comments: 1
1 guide comment.
Go to guide comments
Completed: 2
2 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 5 - 10 minutes
Difficulty: Easy
OEM Guide
iFixit collaborated with the manufacturer to make this guide.
Introduction
Go to step 1 ↓
Follow this guide to remove and replace the battery in your Framework Laptop 12.
All batteries are consumable items—they'll wear out over recharge cycles and need to be replaced. Thankfully, you can easily replace a worn out battery in your Framework Laptop!
You'll encounter some component terms in this guide:
  • The Input Cover is the part that contains the keyboard and trackpad.
    1. Framework Laptop 12 Battery Replacement, Power down your laptop: step 1, image 1 of 3 Framework Laptop 12 Battery Replacement, Power down your laptop: step 1, image 2 of 3 Framework Laptop 12 Battery Replacement, Power down your laptop: step 1, image 3 of 3
      • Before you begin repairs, unplug your laptop and shut it down from the operating system. This ensures that the laptop isn't in standby/suspend mode.
      • The indicator LEDs along the edges should be unlit. The laptop should be silent.
      • If you accidentally turn on the laptop during repair, hold the power button down for 10 seconds to shut it down.
      • Make sure your Framework Screwdriver has the T5 Torx bit (labeled as T-5) facing outwards. If it's not, pull the bit out and flip it.
      Ask FixBot
    1. Framework Laptop 12 Battery Replacement, Set your laptop down: step 2, image 1 of 1
      • Set your Framework Laptop face-down on a clean work surface.
      Ask FixBot
    2. Framework Laptop 12 Battery Replacement, Loosen the bottom screws: step 3, image 1 of 2 Framework Laptop 12 Battery Replacement, Loosen the bottom screws: step 3, image 2 of 2
      • Use your Framework Screwdriver to fully loosen the eight captive T5 Torx screws on the bottom of your laptop.
      • Most screws in your Framework Laptop (including these) are captive—they're designed to stay in place after you loosen them.
      Ask FixBot
    3. Framework Laptop 12 Battery Replacement, Flip your laptop over: step 4, image 1 of 1
      • Flip your laptop over so it's face-up on your work surface.
      Ask FixBot
    4. Framework Laptop 12 Battery Replacement, Open your laptop: step 5, image 1 of 2 Framework Laptop 12 Battery Replacement, Open your laptop: step 5, image 2 of 2
      • Open the laptop lid so that both the screen and the base lie flat on your work surface.
      Ask FixBot
    5. Framework Laptop 12 Battery Replacement, Remove the Input Cover: step 6, image 1 of 3 Framework Laptop 12 Battery Replacement, Remove the Input Cover: step 6, image 2 of 3 Framework Laptop 12 Battery Replacement, Remove the Input Cover: step 6, image 3 of 3
      • Use your fingers to grip the Input Cover in the hinge cutouts.
      • Lift upwards to swing the Input Cover up from the base of the laptop.
      • Magnets hold the Input Cover down, so you'll feel some resistance. If it feels stuck, check that you've fully loosened all the screws on the bottom of your laptop.
      • Remove the Input Cover.
      Ask FixBot
    1. Framework Laptop 12 Battery Replacement, Loosen the battery screws: step 7, image 1 of 1
      • Use your Framework Screwdriver to loosen the six captive T5 Torx screws securing the battery.
      Ask FixBot
    2. Framework Laptop 12 Battery Replacement, Disconnect the battery: step 8, image 1 of 2 Framework Laptop 12 Battery Replacement, Disconnect the battery: step 8, image 2 of 2
      • Grab the orange battery tab with your fingers and lift straight up to disconnect the battery.
      • The battery connector can be tight, requiring some force. If it feels like part of the battery won't come up, check that the battery screws are fully loosened.
      Ask FixBot
    3. Framework Laptop 12 Battery Replacement, Remove the battery: step 9, image 1 of 2 Framework Laptop 12 Battery Replacement, Remove the battery: step 9, image 2 of 2
      • Lift and remove the battery from the laptop.
      Ask FixBot
    1. Framework Laptop 12 Battery Replacement, Disassembly complete: step 10, image 1 of 1
      • Congratulations on completing disassembly! The remaining steps will show how to reassemble your Framework Laptop.
      Ask FixBot
    1. Framework Laptop 12 Battery Replacement, Install the battery: step 11, image 1 of 1
      • Lay the battery in its recess in the laptop.
      Ask FixBot
    2. Framework Laptop 12 Battery Replacement: step 12, image 1 of 2 Framework Laptop 12 Battery Replacement: step 12, image 2 of 2
      • Use your finger to push the battery down near its connector to reconnect it.
      Ask FixBot
    3. Framework Laptop 12 Battery Replacement: step 13, image 1 of 1
      • Use your Framework Screwdriver to tighten the six captive T5 Torx screws to secure the battery.
      • Tighten the screws until they're snug. Don't over-tighten them, or you may strip the screws.
      Ask FixBot
    1. Framework Laptop 12 Battery Replacement, Install the Input Cover: step 14, image 1 of 3 Framework Laptop 12 Battery Replacement, Install the Input Cover: step 14, image 2 of 3 Framework Laptop 12 Battery Replacement, Install the Input Cover: step 14, image 3 of 3
      • Angle the bottom edge of the Input Cover towards the base of the laptop.
      • Align and insert the bottom edge of the Input Cover into the base of the laptop.
      • Make sure the slots along the bottom edge of the Input Cover slide into the tabs in the base.
      • Lower the Input Cover's top edge onto the laptop until the magnets snap it in place.
      • Make sure the Input Cover sits neatly within the laptop frame and no corners are popping up.
      Ask FixBot
    2. Framework Laptop 12 Battery Replacement, Close and flip your laptop: step 15, image 1 of 2 Framework Laptop 12 Battery Replacement, Close and flip your laptop: step 15, image 2 of 2
      • Close the laptop lid.
      • Flip your laptop face-down on a clean work surface.
      Ask FixBot
    3. Framework Laptop 12 Battery Replacement, Tighten the bottom screws: step 16, image 1 of 2 Framework Laptop 12 Battery Replacement, Tighten the bottom screws: step 16, image 2 of 2
      • Use your Framework Screwdriver to tighten the eight captive T5 Torx screws on the bottom of your laptop.
      Ask FixBot
    1. Framework Laptop 12 Battery Replacement, Plug in your laptop: step 17, image 1 of 1
      • The battery ships in shipping mode, so the laptop won't power on until you plug it in first.
      • Plug a power supply into any USB-C port on your laptop.
      Ask FixBot
You finished fixing your Framework Laptop!
Don't throw your battery in the trash. Click here to learn how to dispose of it properly.
If you need help, contact Framework support.
2 other people completed this guide.
Author
with
Arthur Shi
353,975 Reputation
938 Guides authored
Guide Team Member of Guide Team
Staff
10 Members
62,189 Guides authored
1 Guide Comment
So refreshing to see a product guide that is so friction free and has the assembly steps too. Helps Framework laptops are made to be easy to fix.
Scott Vogel - Reply Share
Past 24 Hours: 9
Past 7 Days: 27
Past 30 Days: 105
All Time: 1,341
