Framework Laptop 12 Audio Board Replacement
View statistics:
Past 24 Hours:
3
Past 7 Days:
22
Past 30 Days:
76
All Time:
633
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 5 - 15 minutes
Difficulty: Easy
OEM Guide
iFixit collaborated with the manufacturer to make this guide.
Introduction
Go to step 1 ↓
Follow this guide to remove and replace the Audio Board in your Framework Laptop 12.
The Audio Board contains the headphone jack and speaker connectors. If your headphone jack breaks, you can fix that by replacing the Audio Board. If you're getting intermittent sound from the speakers, you can try to remove and reseat the Audio Board.
You'll encounter some component terms in this guide:
  • The Input Cover is the part that contains the keyboard and trackpad.
    1. Framework Laptop 12 Audio Board Replacement, Power down your laptop: step 1, image 1 of 3 Framework Laptop 12 Audio Board Replacement, Power down your laptop: step 1, image 2 of 3 Framework Laptop 12 Audio Board Replacement, Power down your laptop: step 1, image 3 of 3
      • Before you begin repairs, unplug your laptop and shut it down from the operating system. This ensures that the laptop isn't in standby/suspend mode.
      • The indicator LEDs along the edges should be unlit. The laptop should be silent.
      • If you accidentally turn on the laptop during repair, hold the power button down for 10 seconds to shut it down.
      • Make sure your Framework Screwdriver has the T5 Torx bit (labeled as T-5) facing outwards. If it's not, pull the bit out and flip it.
      Ask FixBot
    1. Framework Laptop 12 Audio Board Replacement, Set your laptop down: step 2, image 1 of 1
      • Set your Framework Laptop face-down on a clean work surface.
      Ask FixBot
    2. Framework Laptop 12 Audio Board Replacement, Loosen the bottom screws: step 3, image 1 of 2 Framework Laptop 12 Audio Board Replacement, Loosen the bottom screws: step 3, image 2 of 2
      • Use your Framework Screwdriver to fully loosen the eight captive T5 Torx screws on the bottom of your laptop.
      • Most screws in your Framework Laptop (including these) are captive—they're designed to stay in place after you loosen them.
      Ask FixBot
    3. Framework Laptop 12 Audio Board Replacement, Flip your laptop over: step 4, image 1 of 1
      • Flip your laptop over so it's face-up on your work surface.
      Ask FixBot
    4. Framework Laptop 12 Audio Board Replacement, Open your laptop: step 5, image 1 of 2 Framework Laptop 12 Audio Board Replacement, Open your laptop: step 5, image 2 of 2
      • Open the laptop lid so that both the screen and the base lie flat on your work surface.
      Ask FixBot
    5. Framework Laptop 12 Audio Board Replacement, Remove the Input Cover: step 6, image 1 of 3 Framework Laptop 12 Audio Board Replacement, Remove the Input Cover: step 6, image 2 of 3 Framework Laptop 12 Audio Board Replacement, Remove the Input Cover: step 6, image 3 of 3
      • Use your fingers to grip the Input Cover in the hinge cutouts.
      • Lift upwards to swing the Input Cover up from the base of the laptop.
      • Magnets hold the Input Cover down, so you'll feel some resistance. If it feels stuck, check that you've fully loosened all the screws on the bottom of your laptop.
      • Remove the Input Cover.
      Ask FixBot
    1. Framework Laptop 12 Audio Board Replacement, Loosen the Audio Board screw: step 7, image 1 of 1
      • Use your Framework Screwdriver to loosen the captive T5 Torx screw securing the Audio Board along the left edge of the laptop.
      Ask FixBot
    2. Framework Laptop 12 Audio Board Replacement, Remove the Audio Board: step 8, image 1 of 3 Framework Laptop 12 Audio Board Replacement, Remove the Audio Board: step 8, image 2 of 3 Framework Laptop 12 Audio Board Replacement, Remove the Audio Board: step 8, image 3 of 3
      • Use your fingers to lift the right edge of the Audio Board and pull it out of its recess.
      • Remove the Audio Board.
      Ask FixBot
    1. Framework Laptop 12 Audio Board Replacement, Disassembly complete: step 9, image 1 of 1
      • Congratulations on completing disassembly! The remaining steps will show how to reassemble your Framework Laptop.
      Ask FixBot
    1. Framework Laptop 12 Audio Board Replacement, Install the Audio Board: step 10, image 1 of 3 Framework Laptop 12 Audio Board Replacement, Install the Audio Board: step 10, image 2 of 3 Framework Laptop 12 Audio Board Replacement, Install the Audio Board: step 10, image 3 of 3
      • Insert the Audio Board into the laptop at an angle to help align the headphone jack.
      • Use the two plastic alignment pins on the laptop to help with final alignment.
      Ask FixBot
    2. Framework Laptop 12 Audio Board Replacement: step 11, image 1 of 1
      • Use your Framework Screwdriver to tighten the captive T5 Torx screw to secure the Audio Board.
      • Tighten the screw until it's snug. Don't over-tighten it, or you may strip the screw.
      Ask FixBot
    1. Framework Laptop 12 Audio Board Replacement, Install the Input Cover: step 12, image 1 of 3 Framework Laptop 12 Audio Board Replacement, Install the Input Cover: step 12, image 2 of 3 Framework Laptop 12 Audio Board Replacement, Install the Input Cover: step 12, image 3 of 3
      • Angle the bottom edge of the Input Cover towards the base of the laptop.
      • Align and insert the bottom edge of the Input Cover into the base of the laptop.
      • Make sure the slots along the bottom edge of the Input Cover slide into the tabs in the base.
      • Lower the Input Cover's top edge onto the laptop until the magnets snap it in place.
      • Make sure the Input Cover sits neatly within the laptop frame and no corners are popping up.
      Ask FixBot
    2. Framework Laptop 12 Audio Board Replacement, Close and flip your laptop: step 13, image 1 of 2 Framework Laptop 12 Audio Board Replacement, Close and flip your laptop: step 13, image 2 of 2
      • Close the laptop lid.
      • Flip your laptop face-down on a clean work surface.
      Ask FixBot
    3. Framework Laptop 12 Audio Board Replacement, Tighten the bottom screws: step 14, image 1 of 2 Framework Laptop 12 Audio Board Replacement, Tighten the bottom screws: step 14, image 2 of 2
      • Use your Framework Screwdriver to tighten the eight captive T5 Torx screws on the bottom of your laptop.
      • Tighten the screws until they're snug. Don't over-tighten them, or you may strip the screws.
      Ask FixBot
You finished fixing your Framework Laptop!
If you need help, contact Framework support.
Arthur Shi
352,888 Reputation
938 Guides authored
Guide Team Member of Guide Team
Staff
10 Members
62,179 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 22
Past 30 Days: 76
All Time: 633
