Shop the Holiday Gift Guide
Fingerprint Sensor Disconnect
View statistics:
Past 24 Hours:
Past 7 Days:
6
Past 30 Days:
19
All Time:
296
Comments: 3
3 comments on steps.
Completed: 0
Favorites: 0
Time Required: 25 - 30 minutes
Difficulty: Moderate
Prerequisite Only
This is a prerequisite-only guide! This guide is part of another procedure and isn’t meant to be used alone.
Introduction
Go to step 1 ↓
This is a prerequisite-only guide! This guide is part of another procedure and is not meant to be used alone.
How to disconnect the fingerprint sensor in the Xiaomi Redmi Note 7.
Tools
    1. Fingerprint Sensor Disconnect, Loosen the rear glass adhesive: step 1, image 1 of 1
      • Apply a heated iOpener to the rear glass to loosen the adhesive underneath. Apply the iOpener for at least two minutes.
      Ask FixBot
    2. Fingerprint Sensor Disconnect, Insert an opening pick: step 2, image 1 of 3 Fingerprint Sensor Disconnect, Insert an opening pick: step 2, image 2 of 3 Fingerprint Sensor Disconnect, Insert an opening pick: step 2, image 3 of 3
      • Secure a suction handle to the bottom edge of the rear glass, as close to the edge as possible.
      • If your rear glass is badly cracked, covering it with a layer of clear packing tape may allow the suction cup to adhere. Alternatively, very strong tape may be used instead of the suction cup. If all else fails, you can superglue the suction cup to the rear glass.
      • Lift the rear glass with the suction handle to create a small gap between the glass and the frame.
      • In case you have trouble creating a gap, apply more heat to further soften the adhesive. Follow the iOpener instructions to avoid overheating.
      • Insert an opening pick into the gap.
      • Slide the opening pick to the bottom right corner to slice the adhesive.
      Ask FixBot
    3. Fingerprint Sensor Disconnect, Slice the bottom edge adhesive: step 3, image 1 of 2 Fingerprint Sensor Disconnect, Slice the bottom edge adhesive: step 3, image 2 of 2
      • Insert a second opening pick and slide it to the bottom left corner to slice the adhesive.
      • Leave the opening picks in place to prevent the adhesive from resealing.
      Ask FixBot
    4. Fingerprint Sensor Disconnect, Slice the lefthand-side adhesive: step 4, image 1 of 3 Fingerprint Sensor Disconnect, Slice the lefthand-side adhesive: step 4, image 2 of 3 Fingerprint Sensor Disconnect, Slice the lefthand-side adhesive: step 4, image 3 of 3
      • If the adhesive becomes hard to cut, it has most likely cooled down. Use your iOpener to reheat it.
      • Insert a third opening pick at the bottom left corner.
      • Slide the opening pick along the left edge of the phone to slice the rear glass adhesive.
      • Leave the opening pick in its place at the top left corner to prevent the adhesive from resealing.
      Ask FixBot
    5. Fingerprint Sensor Disconnect, Slice the top edge adhesive: step 5, image 1 of 2 Fingerprint Sensor Disconnect, Slice the top edge adhesive: step 5, image 2 of 2
      • Insert a fourth opening pick under the top left corner of the rear glass.
      • Slide the opening pick along the top edge of the phone to slice the rear glass adhesive.
      • Leave the opening pick in the top right corner to prevent the adhesive from resealing.
      Ask FixBot
    6. Fingerprint Sensor Disconnect, Slice the righthand-side adhesive: step 6, image 1 of 2 Fingerprint Sensor Disconnect, Slice the righthand-side adhesive: step 6, image 2 of 2
      • Insert a fifth opening pick at the top right corner of the phone.
      • Slide the opening pick along the right edge to slice the remaining adhesive.
      • Don't try to remove the rear glass all the way yet. The fingerprint sensor is still connected to the motherboard.
      Ask FixBot
    7. Fingerprint Sensor Disconnect, Open up the phone assembly: step 7, image 1 of 3 Fingerprint Sensor Disconnect, Open up the phone assembly: step 7, image 2 of 3 Fingerprint Sensor Disconnect, Open up the phone assembly: step 7, image 3 of 3
      • Carefully fold the rear glass to the left side of the phone assembly like you'd open the front cover of a book.
      • Avoid tensioning the fingerprint flex cable during this process.
      Ask FixBot
    1. Fingerprint Sensor Disconnect, Peel the protective foil off: step 8, image 1 of 2 Fingerprint Sensor Disconnect, Peel the protective foil off: step 8, image 2 of 2
      Tool used on this step:
      Buy
      • For easier handling during repairs we highly recommend to separate the back cover including the fingerprint sensor from the phone assembly.
      • Use a pair of tweezers to carefully peel the yellow protective foil off the ZIF connector.
      Ask FixBot
    2. Fingerprint Sensor Disconnect, Open the ZIF connector: step 9, image 1 of 2 Fingerprint Sensor Disconnect, Open the ZIF connector: step 9, image 2 of 2
      • Use the pointed end of a spudger to open the ZIF connector by bringing its black flap in an upright position.
      Ask FixBot
    3. Fingerprint Sensor Disconnect, Disconnect the fingerprint flex cable: step 10, image 1 of 2 Fingerprint Sensor Disconnect, Disconnect the fingerprint flex cable: step 10, image 2 of 2
      • Disconnect the fingerprint flex cable by pulling it straight out off the ZIF connector using a pair of tweezers.
      Ask FixBot
Author
with
Dominik Schnabelrauch
267,900 Reputation
682 Guides authored
iFixit Member of iFixit
Staff
119 Members
72,954 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 6
Past 30 Days: 19
All Time: 296
