Epson Stylus Photo 1400 Paper Eject Frame Assembly Replacement
  1. Epson Stylus Photo 1400 Paper Eject Frame Assembly Replacement, Housing: step 1, image 1 of 1
    • Turn off the printer.
    • Disconnect all data connections coming into the printer such as USB, networkd cables, firewire, etc. as well as removing the power cord.
  2. Epson Stylus Photo 1400 Paper Eject Frame Assembly Replacement: step 2, image 1 of 2 Epson Stylus Photo 1400 Paper Eject Frame Assembly Replacement: step 2, image 2 of 2
    • Locate the IEEE cover in the back.
    • Gently slide the cover to the right to unlatch, then pull to remove it.
  3. Epson Stylus Photo 1400 Paper Eject Frame Assembly Replacement: step 3, image 1 of 2 Epson Stylus Photo 1400 Paper Eject Frame Assembly Replacement: step 3, image 2 of 2
    • Using a Phillips #2 screwdriver, remove the four 10 mm screws shown.
    • Remove the 6 mm screw that holds the rear housing in place.
  4. Epson Stylus Photo 1400 Paper Eject Frame Assembly Replacement: step 4, image 1 of 2 Epson Stylus Photo 1400 Paper Eject Frame Assembly Replacement: step 4, image 2 of 2
    • Remove the rear housing by pulling it backwards.
  5. Epson Stylus Photo 1400 Paper Eject Frame Assembly Replacement: step 5, image 1 of 3 Epson Stylus Photo 1400 Paper Eject Frame Assembly Replacement: step 5, image 2 of 3 Epson Stylus Photo 1400 Paper Eject Frame Assembly Replacement: step 5, image 3 of 3
    • Insert a plastic opening tool into the cutouts of the lower housing.
    • Release the two tabs of the side housing by lifting the tool in an upward motion.
    • Remove the side housing by pulling it outwards.
  6. Epson Stylus Photo 1400 Paper Eject Frame Assembly Replacement: step 6, image 1 of 2 Epson Stylus Photo 1400 Paper Eject Frame Assembly Replacement: step 6, image 2 of 2
    • Both side housings are attached by the same type of mechanism.
    • Using the same method, remove the other side housing.
  7. Epson Stylus Photo 1400 Paper Eject Frame Assembly Replacement: step 7, image 1 of 3 Epson Stylus Photo 1400 Paper Eject Frame Assembly Replacement: step 7, image 2 of 3 Epson Stylus Photo 1400 Paper Eject Frame Assembly Replacement: step 7, image 3 of 3
    • Lift the paper support.
    • Open the printer cover and front cover.
  8. Epson Stylus Photo 1400 Paper Eject Frame Assembly Replacement: step 8, image 1 of 3 Epson Stylus Photo 1400 Paper Eject Frame Assembly Replacement: step 8, image 2 of 3 Epson Stylus Photo 1400 Paper Eject Frame Assembly Replacement: step 8, image 3 of 3
    • Remove the four 10 mm Phillips #2 screws from the sides of the printer.
    • Remove the three 6 mm Phillips #2 screws.
  9. Epson Stylus Photo 1400 Paper Eject Frame Assembly Replacement: step 9, image 1 of 2 Epson Stylus Photo 1400 Paper Eject Frame Assembly Replacement: step 9, image 2 of 2
    • Detach the tabs from the pins on each side by pulling it outwards.
  10. Epson Stylus Photo 1400 Paper Eject Frame Assembly Replacement: step 10, image 1 of 2 Epson Stylus Photo 1400 Paper Eject Frame Assembly Replacement: step 10, image 2 of 2
    • Remove the two 10 mm Phillips #2 screws on the front of the printer.
  11. Epson Stylus Photo 1400 Paper Eject Frame Assembly Replacement: step 11, image 1 of 3 Epson Stylus Photo 1400 Paper Eject Frame Assembly Replacement: step 11, image 2 of 3 Epson Stylus Photo 1400 Paper Eject Frame Assembly Replacement: step 11, image 3 of 3
    • Disconnect the two cables on the side by carefully pulling it outwards.
    • You may need to gently rock the two cables up and down while pulling.
  12. Epson Stylus Photo 1400 Paper Eject Frame Assembly Replacement: step 12, image 1 of 2 Epson Stylus Photo 1400 Paper Eject Frame Assembly Replacement: step 12, image 2 of 2
    • Remove the upper housing by lifting it upwards.
    • It's easier to lift the housing by gripping it from the bottom.
  13. Epson Stylus Photo 1400 Paper Eject Frame Assembly Replacement, Paper Eject Frame Assembly: step 13, image 1 of 2 Epson Stylus Photo 1400 Paper Eject Frame Assembly Replacement, Paper Eject Frame Assembly: step 13, image 2 of 2
    • Hold the ink tube and draw out the waste ink tube by pulling on both tubes in opposite directions.
  14. Epson Stylus Photo 1400 Paper Eject Frame Assembly Replacement: step 14, image 1 of 2 Epson Stylus Photo 1400 Paper Eject Frame Assembly Replacement: step 14, image 2 of 2
    • Remove the acetate tape that secure the connector cable.
  15. Epson Stylus Photo 1400 Paper Eject Frame Assembly Replacement: step 15, image 1 of 3 Epson Stylus Photo 1400 Paper Eject Frame Assembly Replacement: step 15, image 2 of 3 Epson Stylus Photo 1400 Paper Eject Frame Assembly Replacement: step 15, image 3 of 3
    • There are six screws that secure the printer mechanism.
    • Using the #2 Phillips screwdriver, remove the three 10mm screws shown.
  16. Epson Stylus Photo 1400 Paper Eject Frame Assembly Replacement: step 16, image 1 of 3 Epson Stylus Photo 1400 Paper Eject Frame Assembly Replacement: step 16, image 2 of 3 Epson Stylus Photo 1400 Paper Eject Frame Assembly Replacement: step 16, image 3 of 3
    • Using the #2 Phillips screwdriver, remove the last three 10mm screws securing the printer mechanism.
  17. Epson Stylus Photo 1400 Paper Eject Frame Assembly Replacement: step 17, image 1 of 2 Epson Stylus Photo 1400 Paper Eject Frame Assembly Replacement: step 17, image 2 of 2
    • Remove printer mechanism from lower housing by holding the handles and lifting it upwards.
  18. Epson Stylus Photo 1400 Paper Eject Frame Assembly Replacement: step 18, image 1 of 3 Epson Stylus Photo 1400 Paper Eject Frame Assembly Replacement: step 18, image 2 of 3 Epson Stylus Photo 1400 Paper Eject Frame Assembly Replacement: step 18, image 3 of 3
    • Remove the CD-R unit housing by releasing the two attaching points to the tray base.
    • Pull it outwards diagonally one side at a time.
  19. Epson Stylus Photo 1400 Paper Eject Frame Assembly Replacement: step 19, image 1 of 3 Epson Stylus Photo 1400 Paper Eject Frame Assembly Replacement: step 19, image 2 of 3 Epson Stylus Photo 1400 Paper Eject Frame Assembly Replacement: step 19, image 3 of 3
    • Remove the left frame support plate by removing the two 6mm screws that secure it.
    • Pull it out by hand to free it.
  20. Epson Stylus Photo 1400 Paper Eject Frame Assembly Replacement: step 20, image 1 of 2 Epson Stylus Photo 1400 Paper Eject Frame Assembly Replacement: step 20, image 2 of 2
    • Using the #2 Phillips screwdriver, remove the four 6mm screws.
    • Remove the two 8mm screws.
    • The screws are located on the lower sections of the printer.
  21. Epson Stylus Photo 1400 Paper Eject Frame Assembly Replacement: step 21, image 1 of 3 Epson Stylus Photo 1400 Paper Eject Frame Assembly Replacement: step 21, image 2 of 3 Epson Stylus Photo 1400 Paper Eject Frame Assembly Replacement: step 21, image 3 of 3
    • Two guide pins secure the paper EJ assy in place.
    • Remove the two guide pins on the CD/DVD tray base by pulling each pin outward.
  22. Epson Stylus Photo 1400 Paper Eject Frame Assembly Replacement: step 22, image 1 of 2 Epson Stylus Photo 1400 Paper Eject Frame Assembly Replacement: step 22, image 2 of 2
    • Remove the paper EJ frame assy by pulling the it towards you.
Larry Huang
1,004 Reputation
4 Guides authored
Cal Poly, Team 17-11, Regan Fall 2011 Member of Cal Poly, Team 17-11, Regan Fall 2011
CPSU-REGAN-F11S17G11
4 Members
12 Guides authored
Past 24 Hours: 6
Past 7 Days: 21
Past 30 Days: 85
All Time: 21,123
