ESGE Magic Wand - Bamix disassemble
  1. ESGE Magic Wand - Bamix disassemble, Remove top cover: step 1, image 1 of 3 ESGE Magic Wand - Bamix disassemble, Remove top cover: step 1, image 2 of 3 ESGE Magic Wand - Bamix disassemble, Remove top cover: step 1, image 3 of 3
    Tool used on this step:
    iFixit Precision 4 mm Screwdriver Bit
    $2.99
    Buy
    • Unplug the power cord and remove the cutter blade.
    • The top cover is fastened with two Torx TR10 security screws. These screws are different from normal Torx screws: they are equipped with a center pin. Use the right bit or screwdriver with center hole.
    • Remove two Torx TR10 screws.
    • Carefully lift off the cover. It is latched at the front.
  2. ESGE Magic Wand - Bamix disassemble: step 2, image 1 of 3 ESGE Magic Wand - Bamix disassemble: step 2, image 2 of 3 ESGE Magic Wand - Bamix disassemble: step 2, image 3 of 3
    • This is what it looks like under the cover.
    • Slide out the two buttons and the small circuit board. The buttons are only snapped in.
  3. ESGE Magic Wand - Bamix disassemble: step 3, image 1 of 2 ESGE Magic Wand - Bamix disassemble: step 3, image 2 of 2
    • The handle is fastened with a Torx T8 machine screw and a Torx T8 plastic screw. You will need a long screwdriver.
    • Remove two Torx T8 screws.
  4. ESGE Magic Wand - Bamix disassemble: step 4, image 1 of 2 ESGE Magic Wand - Bamix disassemble: step 4, image 2 of 2
    • Unclip the handle from one side.
    • Unthread the cable, the buttons and the board.
    • The motor ist exposed. However, it is not yet completely accessible, since the lower plastic housing part cannot yet be slid over the bell. The bell must first be removed.
  5. ESGE Magic Wand - Bamix disassemble: step 5, image 1 of 3 ESGE Magic Wand - Bamix disassemble: step 5, image 2 of 3 ESGE Magic Wand - Bamix disassemble: step 5, image 3 of 3
    • First try If the bell can be unscrewed. It is fastened with a left-hand thread, so turn it in the "wrong direction", clockwise, to loosen it.
    • Pull on the knife to remove it
    • The bell sits probably quite tight, as it should not come loose during normal operation. When reassembling, glue it in place with a few drops of fluid threadlocker, if needed.
    • If it does not come off easily, then slide the lower plastic part towards the bell and clamp the motor in a vice. Do not tighten the vice very much, the motor is sensitive.
    • Use a long screwdriver as a lever between the bell and the shaft. Then carefully unscrew the bell. Reminder: the wrong way round, i.e. clockwise.
    • Pay attention to the washer between the shaft and the bell, do not lose it.
  6. ESGE Magic Wand - Bamix disassemble: step 6, image 1 of 1
    • Pull off the lower case over the shaft.
Special thanks to these translators:
de en
100%
These translators are helping us fix the world! Want to contribute?
Start translating ›
VauWeh
203,741 Reputation
246 Guides authored
Repair is War on Entropy Member of Repair is War on Entropy
Community
25 Members
1,126 Guides authored
0 Comments
Past 24 Hours: 17
Past 7 Days: 67
Past 30 Days: 325
All Time: 11,195
